Question about GE Zoneline AZ38H12DAD Split System Air Conditioner
GE zoneline - about 23 years old
The fan and air conditioner work just fine, but when I push the low heat or high heat buttons, nothing happens. Do I need a whole new unit or is it a part that is broken? I can get heat by turning on the air conditioner and turning the temperature dial to its warmest position. Will doing that destroy the unit? Many thanks for any help you can offer
  • Anonymous Jan 17, 2009
    mine has the same problem....11 years is works fine.....but no zoneline 3100
  • 182 Answers
Theres a heat relay and also the wire used for heat.either could be bad.
Posted on Nov 05, 2008
Ge zoneline az55ho7d when i tunr on it comes on fine, but after 10 minutes the fan in back side stop running and front fan keep running so throw only air no cold air. so what is wrong . is it motor for the...
Could be lack of service. The unit depends on a clean evaporator and condenser coil. The "other" motor you hear is the compressor starting or stopping probably due to either a high pressure or low pressure switch, or thermal cut-out.
Oct 25, 2009 | GE Zoneline AZ55H07D Air Conditioner
Fan does not work,power board gets power ok
GE Zone have two boards Drive board and control board. Sounds like bad fan motor. I work on Zonelines and the motors go out more than anything else. Rusty
Jun 04, 2009 | GE Zoneline AZ28E12DAB Heat Cool Air...
Knocking Noise?
Might be the compressor. It would be a good idea to shoot it with some compressor oil.
Apr 20, 2009 | GE Zoneline AZ55H07D Air Conditioner
My ac works fine but when i turn to heat no hot air
take contuity tester to test heat protecters and inline fuse in coil area /could be that you might have to change main board
Nov 25, 2008 | GE Zoneline AZ38H12DAD Split System Air...
How to best run this thing
Hi Laurelrobin,
When the unit is on "low fan", it is fan only, and is recirculating room air. If the damper is open, it can also bring in outside air. If the space is not occupied for extended periods, it's OK to turn the unit "OFF", as long as you have a newer unit with Heat Sentinel, and the Heat Sentinel is turned on. Heat Sentinel will not let the room temp get above 85F, as long as the unit is OFF. Also, in most cases it's best to keep the damper closed. You can check your owner's manual for more info on the Heat Sentinel and other auxiliary functions. I also have an article on the temperature limiting functions of the GE Zoneline.
Feel free to contact me at greg.mcnary(at) if you need further info.
Greg McNary
Air Distributors Company, Inc.
Louisville, KY
Distributors for GE Zoneline PTAC Units, Zoneiare PTAC Units, and McQuay PTAC Units.
Aug 01, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Fan Seems To Be the Only Thing Working
no you problably have a bad thermostat on the unit
May 27, 2008 | GE AJCQ08ACB Air Conditioner
"high" vs "low" dual control
could be problem with either switch of fan. try continuity across both legs of the switch then try continuity across the fan windings.
May 25, 2007 | Fedders X Chassis A3X05F2B Air Conditioner
GE Zoneline AZ38H12DAD Split System Air Conditioner Logo
211 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
