Question about Hotpoint FFM90 Bottom Freezer Refrigerator
Fridge stopped cooling
The fridge has stopped cooling - power is getting to it and the freezer part is still working. Any ideas? Thanks
  • 1 more comment
  • Anonymous Feb 25, 2008
    freezer works fine, it's running no problem there. The frig part is too warm ,milk was lukewarm. I made ure the little meat,veggie keepers were at half slide. Don't know what to do. please contat me if you have any ideas. I can't afford to do much about it just now
    You can e-mail me at joysyoder@aim.com
  • Anonymous Mar 18, 2008
    Bottom freezer is working good but top refrigerator is not cooling properly. the fan turns on I can here it but it's just not getting cold enough.
  • yusafm May 20, 2008
    I have the same problem, freezer works, refrigerator part does not cool. I unscrew the back wall of the freezer and clean up the ice covered heater and surrounding area which corrects the problem. But I have to do it again and again. The problem is with the defrost system. Please advise what part to change. Thanks.
    My product is: Whirpool ER8GHKXMS Freezer top Refrigerator
    yusafm
We had the same problem today and it was because I had not closed the freezer completely a week ago and the evaporator coil in freezer was completely iced up. A blow dryer defrosted the coil quickly. It is best to empty the freezer first and shut fridge off. You need to defrost the coil enough so air will flow through the coil. To cool the fridge cold air is drawn from this coil by an evaporator fan located above this coil behind the removable cover at rear of freezer. IF you remove this cover and this fan is turning check for ice on coil. That is probably the problem. Evap. fan is about $100 - ouch. The other thing you can check is the fridge damper control at top rear of fridge. This failed on us 13 months after we bought fridge so no warrenty. Part was $44 plus service of $100. Now I fix this fridge myself. If you remove damper cover you can cycle thermostat and see it open and close. If it is not opening replace it. You can probably find the part cheaper that $44 at an apliance parts store.
Posted on May 19, 2007
  • 175 Answers
Your freezer is probably iced up, blocking airflow to the fridge part. Unplug it for 2 days and let it stand open to defrost or take the evaporater cove off and defrost it with warm water or a hair dryer. Just dont melt any plastic walls/parts. This could be because a door was left ajar, or because your defrost sytem failed if it happens again. Good Luck!
Posted on Oct 10, 2006
    Problem Solver:
  • 8 Answers
If it's a Subzero and the service light keeps coming back on and temps are rising in the refer section, then you most likely have an evaporator leak. Check to see if you see either a moist spot or ice on the back wall on the left side of the back wall of the refer. If you do, it's definetly a leak. Call a authorized Servicer.
Posted on Oct 13, 2008
I don't believe this applies to subzero fridges, as they have a separate condenser for the freezer and the fridge.
Posted on Sep 15, 2007
Our samsung side-by-side has a exibittion mode that can be accidently activated if the power freeze and freezer temp buttons are press at the same time, which considering their proximity is easy to do. This mode deactivates the refrigerator, but leaves the freezer functioning. To take it out of this mode and into full operation you need to press the same two buttons again and hold them for 8 seconds or until you hear a chime. I think this was very poor planning by the engineers and the information ofn the fix is not easy to locate. I hope this saves someone else the grief I went through.
Posted on Aug 17, 2007
4 Suggested Answers
  • 1462 Answers
SOURCE: Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
Posted on May 07, 2007
SOURCE: Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Posted on Dec 27, 2008
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
Fan not working, fridge not cooling anymore, freezer seems ok
Hotpoint Fridge Freezer RFA52 BUT I DONT KNOW WHERE IS THE FAN CAN SOMEONE HELP ME TO TELL ME WHERE IS THE FAN IN MY FRIDGE SO I CAN DEFROSE IT.
PLESAE EMAIL ME ON: RAFIK02UK@YAHOO.CO.UK
MANY THANKS
Posted on Mar 01, 2010
Hi, I have an LG refrigerator, the top freezer works fine but the fridge section has stopped cooling, I turned the unit off and next morning there was a large puddle of water on the floor, when I turned it...
When the fridge is not cooling that means the fan are not working or not working properly, need to replace or check if their is an ice bothering the fan to turn. ok
Feb 15, 2010 | Refrigerators
Hotpoint RFA52 fridge freezer
if you cant hear the motor/compressor running when energised then its likely to be a thermostat fault... but on energising the system if you hear a buzz then a click then its more seriously the main motor... turn off at mains for 5 mins then turn on... this should tell you either way
Dec 22, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Creda R335NW Fridge/Freezer. The fridge section is not cooling down anymore, The freezer is working ok. Any ideas please?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
Jul 03, 2009 | Refrigerators
LG fridge suddenly stopped cooling.
If the fan inside the freezer is running and the compressor behind the fridge is running and is hot to touch, you have a gas problem or the compressor is inefficient. This can only be confirmed by connecting refrigeration gauges to the gas system and should only be performed by a fridge tech.
Nov 04, 2007 | Refrigerators
Fridge is hot while freezer works fine
Defrost for 24hrs with doors open, turn back on it will then work ok. Regards Advisor
Aug 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire 7.5 cu.ft. Top Freezer the fridge part doesn't cool; freezer is fine.
It should be under warranty, retry he is probably right, run for 24hrs and it should work ok, if you ever defrost you should turn off for 24hrs and leave the door open. Regards Advisor
Aug 08, 2007 | Frigidaire GLRT83TES Top Freezer...
Open Questions:
See all Hotpoint FFM90 Bottom Freezer Refrigerator Questions
Hotpoint FFM90 Bottom Freezer Refrigerator Logo
1,640 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
