Question about Laplink Software PCmover for PC
Pc mover i cant get the pc mover to down load
On the download page there should be a toolbar below the address bar.Right click on it and click on download file.
Posted on Oct 16, 2009
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
You can try downloading from a more rliable source.
Have you checked whether the source was fine.
You can try downloading from this link :
http://tinyurl.com/7sqgh2
http://tinyurl.com/ayoss5
Or You can register here to get the download link :
http://www.laplink.com/business_solutions/pcmover.html
Good Luck.
Live, Love, Laugh.
Posted on Dec 28, 2008
Which is the best mover and packer service if I have to shift to a new home?
The best Packers and Movers I would suggest you is Findmovers.in. This is the best portal you can check the all packers and movers company list across India Also see the company rates, reviews and prices. The best part is the friendly, uniformed and professional certified employees move packages, loading, transporting, unloading, unpacking and placing your belongings with care and perfection. More Information Visit This Website:- www.Findmovers.in
Nov 23, 2016 | Miscellaneous
Why Should You Hire the Professional Movers and Packers for Relocation?
professional movers and packers belong to an association that accredits them to do the job properly
that gives you a place to redress any issues that the company disputes
they also carry an insurance against damage and loss
they know their job
if you move a full house it is packed in the one container or van and that is not disturbed until it arrives at your destination at a time to suit you
non accredited movers load your gear on any truck going your way and any left over goes on the next available truck
basically it is your responsibility to get quotes and talk with the companies as to how they operate , read forums on their service and then make a decision
remember it does more damage to move just down the street that to move across the country as the care factor is lower for a local move
Jun 21, 2016 | Miscellaneous
Pls am used to hp laptop all my life but just
How did you copy? When I change computers, I often use a product called, "pc mover". Pc Mover works very well, transfers everything, including programs. It's not free.
Sep 03, 2014 | Computers & Internet
Agitator only works on bottom half. can I repair
if the clothes mover section on top quit,remove the detergent cup and with a 9/16" socket remove the bolt down inside,this will let you remove the clothes mover part,then you need to order the thrust bearing and dogs cam rebuild kit for this model
Mar 23, 2010 | Kenmore 22422 Top Load Washer
Everything works but the agitator
The small plastic pieces that are located under the agitator center cap that grip the agitator and turn it during the wash cycle are worn out. They are called agitator dog ears or clutch dogs. They must be replaced.
  1. Unplug the washer.
  2. Remove the fabric softener dispenser, if there's any, by pulling it off the agitator top. cf99d03.gif
  3. If no dispenser is installed, insert a flat screwdriver between the agitator and agitator cap. Pry the cap off the agitator then remove the upper part of the agitator. cae2ce0.gif
  5. Use a socket wrench with extension or nut driver to remove the stud and seal holding the agitator to the shaft. 96cc7e9.gif
  7. Turn the agitator mover over on your palm. The cam and agitator dogs will come out on your palm. Pay attention to how the agitator dogs are installed. Remove the worn agitator dogs and install the new ones. c8eb889.gif
  8. If the agitator dogs are not worn, check the agitator shaft. Remove the round rubber seal off the top of the agitator and remove the agitator by lifting it straight up. Call up service if the shaft is worn. ca89530.jpged86a35.jpg
  9. Reinstall the agitator. Rotate it until the grooves on the agitator matches the grooves on the shaft then push the agitator down.
  10. Place the round rubber seal in the groove on the top of the agitator. 5314b95.gif
  11. Turn the agitator mover over and carefully insert the cam and agitator dogs up into the agitator mover until it stops. c55998d.gif
  12. Carefully turn the agitator mover over in upright position.
  13. Place the agitator mover with the cam and dogs over the agitator, lining up the tabs. The cam has a cut-out and tabs across from each other. The agitator has tabs across from each other. All of these must line up in order for the cam to slide down on the agitator.5f7e245.gif
  14. Push the cam down until the tabs snap together.
  15. Put the upper part of the agitator back.
  16. Using a socket wrench with extension or nut driver, insert the stud and seal through the agitator into the shaft and tighten it.
  17. Push the barrier cap and seal down into the agitator mover all the way. Make sure the round gasket is in the groove in the barrier cap. The barrier cap must be pushed down past the holes on the mover to allow the liquid from the dispenser to flow.
  18. Press down on the fabric softener dispenser or cap until it is all the way down on the agitator.
Nov 30, 2009 | Kenmore 24622 Top Load Washer
I just moved and I cant find the drain hose or where to connect it to the washer. I'm willing to go buy a new hose but need to know where it fits. Also, the dryer has worked great over the last 2-yrs;...
The drain hose goes on the back of the waher down at the bottom by the pump. On your dryer if if it is electric your heating element needs to be checked to see if it is coming on
Aug 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
One part of agitator moves the other part doesnt.
Two-Piece Agitator: Bottom Works, Top Does Not - Whirlpool brands
Some Whirlpool brands washing machines employ a two piece agitator. The bottom is call the agitator and the top is usually referred to a 'Mover'. A multi-piece cam and bearing assembly connects the two and allows the top portion to index.
If the bearing or cams become stripped or damaged, the mover will often not work. Fortunately, Whirlpool produces a cost effective agitator repair kit that replaces all of the critical components in this cam assembly. There are three different repair kits. They differ in the height of the cam.
Agitator Removal Instructions:
Remove Dispenser or Cap:
Some models of washing machines utilize a fabric softener dispenser that resides on top of the agitator. This dispenser simply snaps onto the top of the agitator. Other styles utilize a decorative cap. To remove the dispenser, simply grab it and firmly pull up. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (mover). Use a twisting or prying action to pop the cap off of the agitator.
Remove Internal Debris Cap:
Inside the agitator you will see a cap with a raised handle, much like that of your automobile. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring.
Remove Agitator Stud:
When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt (agitator stud).
Remove the Upper Agitator (Mover):
With the bolt removed you should be able to remove the upper half of the agitator (mover) by simply pulling up. Sometimes pulling up will actually remove the whole agitator assembly. If this happens, place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator.
Remove the Cam and Clutch Dogs:
When you remove the upper agitator (mover) it contains the cam and clutch dogs. Tun the assembly upside down. The cam and dogs should then come out.
-- Stop Here if Replacing Cam Kit --
Remove O-ring:
The lower agitator remains on the transmission shaft. On the top of the agitator, there is an o-ring. Remove this o-ring.
Pull the Lower Agitator:
All that remains is the lower agitator. This can be removed by simply pulling straight up on the agitator.
Agitator Installation Instructions:
Set Lower Agitator:
Slide the lower agitator onto the transmission shaft. Rotate the lower agitator until the splines in the shaft match those in the agitator. Once aligned press the agitator down. Install the o-ring into the top of the lower agitator.
-- Start Here if Replacing Cam Kit --
Assemble Cam and Dogs:
Turn the cam upside down. Place the small round ear of the dog into the corresponding slot on the cam. Repeat this for each of the four cams.
Install Cam and Dogs into Upper Agitator:
Invert the Upper Agitator (mover) and slide the cam/dog assembly inside. The cam should be pushed into the mover until it shoulders. Then rotate the whole assembly upright.
Install the Upper Agitator (Mover) on the Lower Agitator:
The lower agitator has two tabs that stick up that are 180 degrees apart. These tabs fit into two slots on the bottom of the cam. Align the matching tabs and slots and place the Upper Agitator (mover) and cam assembly onto the lower agitator. Push down until the cam snaps onto the Lower Agitator. If the dogs fall out during this step it is necessary to return to the 'Assemble Cam and Dogs' section above and start over.
Install the Agitator Stud:
Place the bolt (agitator stud) into the hole in the bottom center of the cam. Use a socket kit or nut driver to tighten the bolt .
Install Internal Debris Cap:
Install the o-ring into the groove on the OD of the debris cap. With the o-ring in place, push the cap into the Upper Agitator (mover). It is important that the cap is pushed past the ports in the Upper Agitator (mover) so that the wash water can enter and exit as designed.
Install the Dispenser or Cap:
The final step is to replace the top cap. Both the cap and the dispenser simply snap into place. Just make sure they are installed as far down a they will go and are firmly in place.
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Laplink Software PCmover for PC Logo
165 people viewed this question
Top Laplink Software Computers & Internet Experts
Mike
dhnguyen
Are you a Laplink Software Computer and Internet Expert? Answer questions, earn points and help others
