I have an Optoma EP 739 projector. I turned it on and heard a 3 second grinding noise--it stopped for 3 seconds and made the noise again. The bulb did not come on during this grinding period.
I used justanswer.com and received an immediate response. Thank you.
Posted on Nov 06, 2008
Why would my projector refuse to start with a seemingly intact light bulb?
If you only have 300 hours on it it should still be under warranty. Before doing something to void that I would check with Optoma techs.
Jul 23, 2014 | Optoma HD20 DLP Projector
My EP 758 is 4 years old and has 1500 hours on its second bulb. I use it for home use with a satellite input (dish network). It just started flickering a couple days ago. The main picture is still there...
It sounds like the projector itself has a fault. Sadly it's often uneconomic to repair budget projectors which are out of warranty when the cost of repair is compared to that of replacement. You should speak to Optoma support and see who their local agent is, and then ask for a quote.
UK support can be found here
They will usually charge a fee to have a look and then they'll offer an estimate for repair.
Feb 14, 2011 | Optoma EP758 - HDTV Compatible DLP...
OPTOMA HD70 projector turns off in a few seconds
my 3m projector turns off as soon as it is turned on
Mar 05, 2010 | Optoma HD70 DLP Projector
Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Jan 31, 2010 | Optoma HD65 DLP Projector
I have an optima EP 739 projector and I just replaced a bulb in it but it does not come on just green light whats up Any input would be appreciated
if the fans come on and the lamp doesn't, it's the ballast or the colorwheel. if no fans either, it's the power supply. also, did you reset the lamp timer?
Dec 07, 2009 | Optoma H30 Multimedia Projector
I have an Optoma EP745 projector. I heard a 'pop'
check all the fans, if still working. if the problem occur get assist to the nearest technician im sure your lamp balasst was deffective.
Oct 22, 2009 | Optoma EP738 Multimedia Projector
Program Optoma EP-739 remote to Bell Express Vue 3100 remote
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Feb 23, 2009 | Optoma EP739 Multimedia Projector
Dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Sep 26, 2008 | Optoma H30 Multimedia Projector
Need new color wheel for EP 759
i would try to email optoma or parts guy localy that sell or fixes these see if he can order u it ok best way thx nick
Feb 12, 2008 | Optoma EzPro 739 Multimedia Projector
47 people viewed this question
k24674
jasbo
jasbo
