Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
Bissel 3593Handle Release Lever/Pedall replacement
Anyone know how to replace the Handle release pedal. I have ordered another but am unsure how to replace
  • 107 Answers
You need to replace slider release not just the handle. Take off the screws holding the black plate under the removavle canister the you will be able to see the slide release.
Posted on Dec 08, 2008
Handle Release Lever/Pedal 203-2347
Hi Chris! I'm sorry; You'll need to contact one of our Authorized Service Centers for assistance.
Here's a quick link to help you locate one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
May 18, 2013 | Bissell Model 3910 Upright Vacuum Cleaner...
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
How do you replace Hoover Handle Release Pedal on
The handle pedal is snapped in to the base, where it pivots.
The pedal needs to be pried away fron the base, exposing the pivot pin to release it for removal. On your model, you will likelly have to remove the lower handle from the base (where it pivots) to get room to release and replace the pedal.
Mar 11, 2010 | Hoover Vacuums
Foot controlled handle release lever is broken. Where to get parts?
I had same problem - the foot release pedal would not spring into place when unit was upright (but would work if you nudged in place with your foot). I installed a replacement part, and it didn't fix the problem. I cut out a small sqare of sponge and jammed it behind the flat end of the bent plastic spring on the release pedal, and it now springs back as it shoud. Hope this helps.
Jan 11, 2010 | Hoover U6630-900 WindTunnel Bagless...
Stand up lever is plastic, broke when stepped on to release handle, can it be repaired, replaced with a better one, plastic breaks too easily?
The pedal release can be replaced but the base will need to be checked for cracks as well. if the base is broken most common is the socket the pedal release snaps into. some of the plastic parts have been made with better materials
Oct 20, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Kenmore 31913 Foot pedal release lever broken-need to replace
FixYa techs - thank you for your response but I solved the problems. It took me 2 hours of continual searching but I finally found the parts - listed under the tab sew machines of all things!? There is one pedal in stock and I called the service company and will pick that up and do it myself. I took that part off my vac and put it back on so know I can do it. I've been fixing stuff all my life and it just takes some logic - anyone can do it if they have a tool kit.
Nov 24, 2008 | Kenmore 31913 Progressive Direct Drive...
Bissel 3594-1 release lever
Flip over the vac and use a long skinny screwdriver to spread the tabs that capture the two nubs on either side of the lever then pull the old part out. Then simply align the new part, and press it down into the slot till it clicks in place.
Jul 29, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Foot Pedal Broken
For the handle release, part number is Detent Lever 2030052 Try bissell.com, or call a local repair shop, if they repair Bissell's, then they may have this part in stock. You shouldn't have to take it aprt, there 2 tabs on the release that fit into slots on the base, there move the slots so as to release the tabs.
Jun 21, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
601 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
