Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung HLN5065W I need to change the lamp on my tv can anyone tell me where it is and how to change it? helpless thanks
Order the lamp by calling 1-800-726-7864 (1-800-SAMSUNG) The lamp is on the back left of the TV ..... not too hard to replace
Posted on Nov 22, 2008
I have a 50 inch hLn5065w ,when i turn it on a very lous noise and vibration seem to be coming if your looking at the back of the tv its coming from the right side looking from the back.i know its not a...
Problem is the Color Wheel, Located behind the Lamp .
You will need a Flash Light and Pull Lamp out ,Look inside and you will see Color Wheel.
Color Wheel PN# BP96-00250A Price $82.66
Encompass Parts Distribution 1-800-638-3328
Samsung Parts 1-800-627-4368
Feb 25, 2011 | Samsung HLN5065W 50" Rear Projection...
I have the Samsung HLN5065W DLP television, and if I press the power button the TV will act like it is going to power on but won't. The lamp light will blink but I never get a picture. It seems like it...
It seems tv needs lamp replacement, please check lamp in tv and if lamp has not been replaced in last 2-3 years or lamp is broken, replace it to solve tv problem.
Thanks.
Jan 22, 2011 | Samsung HLN5065W 50" Rear Projection...
Last week , my 6-7 yr old Samsung hln5065w dlp tv went blank. When I turned the tv back on after trying to reset it there was a winding noise but no picture. I replaced the lamp and still no picture. The...
Sounds like the old lamp blew and took out the ballast. I believe that you need a new ballast for your unit. The other possiblity would be a problem in the low voltage power supply but if the indicator lights are blinking the most likely problem is the ballast.
I have a tip at http://www.fixya.com/support/r4977572-when_change_ballast_in_dlp_tv which explains the problem, how to repair it and where to get the parts. If you need more help let me know.
Thanks for using FixYa and the generous rating.
hardrocko
May 28, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
May 01, 2010 | Samsung HLN5065W 50" Rear Projection...
My samsung hdtv is really dark not matter how i try to adjust the tv.
Hello! In this case, it can be two things either your lamp si goping out, or the ballast is. They're not that expensive http://www.discount-merchant.com/SAMSUNG-9137-008-22705-Lamp-Ballast-Driver-p/1138029.htm/?Click=48427 Of course you need to get the right part number. http://www.discount-merchant.com/Samsung-HLN5065W-OEM-Replacement-LAMP-BULB-p/samsung-hln5065w-lamp-oem.htm/?Click=48427 also for the lamp you need to get the right one you need.
Dec 06, 2009 | Samsung Televison & Video
Samsung HL-R4667W black screen, display says "Lamp"
it means you need to replace a lamp when it says that
Jan 30, 2009 | Samsung HLN5065W 50" Rear Projection...
A Samsung Tv model #HLN5065W
Model # HLN5065W Digital Main Assembly Board should be part # BP94-00385A. Here's a link to a major Samsung distributor:
Samsung HLN5065W Replacement Part Digital Main Assembly Board
***There's also a manufaturer's notice: If you replace the digital main board (BP94-00385A) you must replace the main analog board (BP94-00434A) per mfg bulletin# ASC20040728004.***
Samsung HLN5065W Replacement Part Main Analog Board
Dec 30, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
65 people viewed this question
Henry  Thomas
Henry Thomas
