Question about Dell Inspiron 1300 Notebook
Will not boot
Hard drive lite blinking on ac power will not turn on mother board ?
Will not turn on, will not start
Posted on Nov 30, 2008
  • 59 Answers
Try changing the jumper settings of motherboard
Posted on Nov 05, 2008
My CPU shows a yellow lite but won't turn on it doesn't boot on
Computer no boot means -a bad cmos, bad hard drive, corrupted OS, bad peripheral, bad memory, bad power supply. Start with the hard drive and perform diagnostics on it. Disconnect everything from mother board - leave just the memory and hook it up to a monitor and turn on. If it does not post cmos is bad - if it does post then something that was disconnected is the cause of the issue.
Sep 16, 2017 | Computers & Internet
No power when press the power button
After checking the ac adaptor and battery;
L300 series boot problems
L300 series laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre. www.Toshiba.com will help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Apr 02, 2011 | Toshiba Satellite Pro L300 Notebook
Laptop dont turn on i get 6 flashing orange lights and ideas
Feb 13, 2011 | Toshiba Satellite L305-S5891 Notebook
Laptop will turn on,but wont boot up
L300 boot problems
Feb 12, 2011 | Toshiba Satellite Pro L300 Notebook
My laptop won't turn on
L300 boot problems
Jan 24, 2011 | Toshiba Satellite Pro L300 Notebook
Wont turn on
L300 boot problems
Dec 31, 2010 | Toshiba Satellite Pro L300 Notebook
Compaq Presario F756NR - I go to turn on the laptop, it blinks a couple of times like it is booting up and then turns back off. Could this be the mother board?
With an extensive use of the notebook,
some times notebook would store some static charges which
indeed will stop the notebook from powering up or charging
the battery. The procedure to remove this static charges from
the notebook is known as power drain. Performing a power
drain procedure will not effect any personal data or delete
any pictures from the hard drive on your notebook.
I recommend you use Power Drain procedure by following these
steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter.
5. Turn on the Notebook power.
Dec 12, 2010 | HP Compaq Presario F756NR Notebook
HP Pavillion dv2500 laptop won't turn on
Kinda strange. Not turning on indicates a hardware problem, you made software changes. If the software changes caused a problem, it would start, just not boot to windows. I would first tryy to reset the laptop. Unplug it and remove the battery, hold down the power button for 60 seconds, then try again. If still no go, start removing hardware one at a time, hard drive, rem, wireless card, dvd rom. You may have a bad hard drive. Your pc should boot to bios if there is no hard drive installed. If that happens, run a diagnostic on your hard drive from your bios. Let me know if you need anything else.
seth
Jul 29, 2009 | HP Pavilion dv2610us Notebook
Dell XPS 600 turns itself on to solid amber
Hi. the mother board seems to be having some initialization issues during boot up. this is common when the mother board is failing. i would check to make sure the battery on this board is working. if it is, the board my be ruined.
power board seems to be fine.
please rate and god bless.
Mar 17, 2009 | Dell XPS 600 PC Desktop
Dell Inspiron 1300 Notebook Logo
167 people viewed this question
Alun Cox
