Question about Plumbing
Office chair makes grinding noise when I sit down or get up.
There is a piston like thing in the support of my chair that raises and lowers my chair as I sit or stand.
I had a squeak when I would rock back and forth, so I used some shredder oil (which consists of mineral and soybean oils). This ran down the "trunk" of the chair and got into the "piston" and now it is not gliding smoothly anymore and making a bad noise when I get up or sit down. Did I ruin my chair? My co-workers can hear the noise! Please help!
Hi this is Sachin , spray on the piston the silicon spary and leave for some time the grinding noise will be eliminated
Posted on Jun 30, 2010
Why doesn't chair remain at desired height?
Failure of the height adjustment mechanism
Feb 16, 2016 | Furniture
Why does it make a crunching noise?
Your chair is NEW! So, return your chair to the store where you bought it and complain!
Aug 01, 2015 | Furniture
How do I lower the back?
To lower the back, lift it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.
(This definitely applies to Tempur-Pedic TP4100 Office chair.)
Nov 01, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
How do I lower the back of my chair
Sep 09, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
What can be doene with our executive office chair as it will not remain in the raised position. After raising it, then sitting, the chair slowly sinks down? What is the problem or what can be done.
The hydraulic gas lift is broken. If you want to fix it, you will need to find/buy a replacement. This is a common problem that happens with most all chairs, even if they are rated for heavier weight/long term use, they still do not seem to last more than 1-2 years of use at the most.
Sep 06, 2014 | Serta Big & Tall Executive Chair, Black...
How to adjust the back of the chair?
To lower the back, <b>lift</b> it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.
Jul 01, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
HELP ! My Rascal joystick has option to raise & lower height of chair; I raised it to get in my freezer and now it will not lower. When it is in the RAISED position, the speed is less than a ONE a
This device either is hydraulically operated or operates use a motor and jacking screw, which is much more common. Take the seat off the jacking post. Put a piece of wood on the top where the seat was mounted. It should make the same kind of motor noise going down as it makes going up. If it never made noise going down it probably because its a hydraulic system so the down button activates a valve opening a hydraulic line allowing fluid to flow out of the chamber holding the piston up that your chair is mounted on. If it did make the same kind of noise going down, its a screw jack type mechanism. In either case hit the top of the wood once with moderate force. I like using a 5 pound hammer. I call it my master calibration tool. Make sure you strike the top of the wood piece straight down in order to avoid bending things. Try operating it now sometimes things get stuck when moved to their limit. So push the reverse button, then tap the piston down. You can check to see it the motor is getting voltage you will need a 24v circuit tester
http://www.amazon.com/OEM-25886-6-24V-Circuit-Tester/dp/B0014WIVX6
I would like to see pictures of his devise. Any tag or stickers with who made it, model number?
Jul 28, 2012 | Electric Mobility Rascal Scooters,...
How many levers do office chairs have?
Office chairs usually have two levers. One is used to raise and lower the seat. The other lever is used to determine theangle of the back rest.
May 29, 2012 | Furniture
How do you raise the metro to make it sit higher off the floor? Is it adjustable
This mnaual wheelchair has dual position rear axles and caster forks to allow seat to floor height changes with no additional components. What this means is that the wheelchair is adjustable in height based upon the position of the front caster wheel axles and rear wheel axles. Raising the axles lowers the chair. Lowering the axle postion raises the chair. If the rear axles of the rear wheels are in the top position you can lower the wheels and raise the chair. Likewise, if the caster axles of the front wheels are in the top hole of the fork then put the wheels and axles in the lower hole to raise the chair. It is easy to accomplish this with basic tools.
If the front and rear wheels are already in the lower holes (the chair is in its highest position) you have another option. This option is a more expensive way to raise the chair by buying 4 new wheels. Lets say for example you have 24" diameter rear wheels. If you purchase new 26" diameter wheels you will raise the chair 1". If you have 6" casters and put on 8" casters this raises the chair 1" in the front. Hope this helps.
Nov 23, 2010 | Everest & Jennings 18" Metro Ic3...
Plumbing Logo
1,650 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
