Problem is with a Sony KP-46WT510. I have the factory service manual. Originally it had no luminance and that was diagnosed as a defective "D" board, replace the board or replace the two circuit modules (IC8001 and IC 8002). I replaced the ICs with the same part numbers STK392-560 from BIC, not Sony. I had trouble in removing the high voltage leads from the fly back transformer (T8005) following the manual’s instruction to “twist, etc.” After I pulled one of the leads (thinner) from its tower, I cut the thicker one. Later I wasn’t sure which tower the pulled lead went into but I thought the dust marks showed the right one. I couldn’t find any markings shown by the circuit diagram (11, MV and HV) on the fly back transformer towers. After having placed conductive glue on the exposed lead, I pushed it as far as it would go into the tower and then soldered the other (thicker) leads together with some heat shrink tubing bridging the gap. The problem now is that circuit board D appears to be working because I get sparking noises from sparks (jumping between one of the rear projection tubes and its mounting frame?) but no illumination. I suspect that the voltage ground from the fly back transformer is misconnected. The other possibilities are that I need to replace the D board (hopefully the fly back transformer comes with high voltage leads attached) or there are more problems with this set.
  • g6u79st Nov 05, 2008
    Well, I seem to have mixed up old technology (the ICs are the fly back transformer!) and T8005 is a combined HV rectifier and transformer. Before I buy a new D board for >$130, I'm going to go back and look at the set and perhaps move the wire I reinstalled to a different tower on T8005.
    Sergeant:
    Champion:
  • 275 Answers
Try using this 400 Watt Metal Halide bulb try soldering it on the pcb and see if u are getting the illuminiation and if u are getting that ... that means that the pcb and the bridge is functional and the voltage capacitors are fine ... if u want u can use the same 400watt bulb for the projector but u will have to do some modifications on the chassis ... other than that if not than you will have to get a similar led tourch and break it down as a work around
Posted on Nov 05, 2008
    Genius:
  • 1,550 Answers
You need to replace the D board . You have done almost everything but i think the board is malfunctioning .
How old is your tv ?
What's your problem?Hi, I have a Sony projection TV KP-46WT510 theres no picture or sound, but it still turns on and I can see the the on screen menu. When I turn it on the led blinks four times
You can Google and find the service manual which will explain what the 4 blinks means.
If you have the Sony remote with the set off:
Display, 5, Volume down, Power
If the set has it you will see a box appear on screen with a list of items--all should have a zero to the right of each---one with a number indicates the number of times that error has been detected.
Let me know if you have questions or cannot find what the four means and I will research it.
Mar 28, 2012 | Sony KP-46WT510 46" Rear Projection HDTV
Need a manual for a model kp-46wt510 tv sony
Click Sony Support to download User Manualof KP-46W510
and
Click Manual Zone to buy service Manual of same model.
Feb 22, 2009 | Sony Televison & Video
6 bliks on sony kp-46wt510
KP46WT510 Shutdown 6 Blinks. 6 Blinks = Low B+ OCP/OVP
SOLUTION: Replaced Flyback transformer. It had no rings on the ringer test.
HQ
Comments: Any load on the B+ line can cause 6 Blinks.
Example: If the 200v line is loaded down will cause a drop in B+ due to bright picture current demand.
Click Here! to download the Sony Kp-46wt510 full service manual.
Nov 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence issues
The full downloadable service manual located Here! will have a list of all parts.
Below are a few remedies for convergence:
Subject
Poor convergence, IC8002
Symptoms / Customer Description
Customer hear a popping noise.
[Primary Symptom Code: 1436 ]
Solution
Found IC8002, IC8003, and fuse PS8006 defective on the D Board.
If you need repair assistance, go HERE!
Nov 05, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46wt510 Convergence issue
convergence ic's replace all 3 be carefull make sure to reapply the thermal compound to the heat sinks after cleaning the old stuff off stk's can be had from global
Oct 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Having a problem with my Sony KP-46WT510 46 in tv
Very minor. Horizontal deflection is stopped Q8035 or Q8038 on the D board is defective. Change both just to be sure. If you need more assistance let me know.
Jul 04, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence IC's
Your symptoms sound like a pincushion problem. Do you have the service manual for for your set? If not you can get one instantly emailed to you at the following link. It cost just 12.99 and they supply free tech support to help you diagnose and repair your set. Here's the link in case you need the service manual.
http://servicemanuals.vstore.ca/
Mar 31, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
KP-46WT510 Service Manual
I am posting a link where you can get the complete service manual with parts list for your model it cost 12.99 and they provide free support to help with diagnosis. They will email it within minutes of you placing the order. I have used them many times. Here is the link.
Feb 27, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sont kp-46wt510 blinks 4 times
Four blinks is a "vertical stop error" I have a pdf file of the service manual and troubleshooting guide. If you want it,let me know where to send it.
Sep 27, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
