Question about Dymo DateMark Date/Time Stamper
Not printing I changed my ink refill and I cannot get it to print still. The old one may still be good. Cannot find manual or CD for it. Can someone help? m
  • mlcomer Nov 07, 2008
    I said that I cannot find a manual in the office or a CD to help me with troubkeshooting, but thank you for trying.
I have changed the batteries and put in new ink cartridge i see what i want to see but it only clicks and will not print.
Posted on Nov 18, 2008
See page 7 of the user manual!
Posted on Nov 05, 2008
After refilling my black cartridge, my lexmark X7170 AIO (on printer copy setting) prints out a blank page even after printing an alignment page showing black bars & blue dashes (no other colors?) I...
Try to print some more pages. The ink will take time to go down as it is not free flowing. This is due to the air beetween the new ink and the old ink, after some printing the air is push out and then you can have a clear print.
Sep 11, 2010 | Lexmark Office Equipment & Supplies
Canon PIXMA MP 500 ink refills stop working
you have to reset the ink cartridge.. you have to use a ink refill reseter which come along when you buy a refill kit..
thank you.
May 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
Tip
Printer Ink refill ....
Well, in general I recommend not using refills. They are probably OK for printers with ink nozzles that are NOT built into the cartridge (like Canon printers), but I would still be careful. The ink may not be the same quality as what you would get from the manufacturer.
If you are using an HP printer, the ink nozzle is built into the printer cartridge and is not meant to be run for refill after refill. When you replace your ink cartridge, you also replace your old nozzle with a brand new one. Helps keep the print quality good (especially important if you're trying to print out photographs).
Another point to consider is that when you bought your printer, you were probably looking at print quality. Why take a chance on compromising that print quality to save a few bucks?
on Dec 01, 2009 | Office Equipment & Supplies
I've refilled my black ink cartridge #36 and put it into my Lexmark 5650. My computer will not let me print - not even to "complete a page" print. It says that I need more ink. I have windows vistas. What...
Lexmark 36 and 37 cartridges cannot be refilled. When your ink levels drop below a certain point your printer deactivates the electronics on your cartridge so you cannot refill them. I own a Cartridge World ink refilling shop and I sell Lexmark originals for the 36 and 37 because of this reason. Unfortunately you purchased a machine that you have to buy expensive original ink for. You need to buy Lexmark original 36 and 37 to get your printer to work. As a refiller I never recommend someone buy a Lexmark printer if they ever want to use refills.
Jan 20, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Unable o clean
HTML clipboardHi If your brother printer has been left unused for some time it is probably clogged? And the inbuilt cleaning facility does not help then you will probably need to buy a Magic Inkjet Flush Print Head Cleaning Kit.
Which you can find on Ebay.
http://tinyurl.com/yfx2y5k
Although it is possible to take the Brother printers apart, it is too difficult for most people.
To view what´s inside a Brother Printer click on next line...
Click again to enlarge photo.
http://magicinkjetflush.com/images/Unclog_Refill_Brother_Printers.jpg
Therefore, what we suggest is to make cleaning cartridges using the Dr.EpSUN Refill Tool...
Then use them to flush the print head (usually at the end of long tubes near to the back of the Brother printer)
*NEVER TOUCH THE WHITE star shaped PIN... under ink cartridges... because once pessed in... it cannot be used !
Also in most cases a single cleaning cartridge for black and 1 for colour is all you will need.
If you only have FULL INKS and need to make a cleaning cartridge use Dr.EpSUN Refill Tool to empty ink cart...
Save the ink in a clean glass jar or similar make cleaning cartridge then once unclogged simply use Dr.EpSUN Refill Tool
to refill with your saved ink.
How to make Brother Cleaning Cartridges
If you wish to see photos? You can also follow the procedure for Epson C80 in the Magic Inkjet Flush Manual.
Using FREE Dr.EpSUN Refill Tool.
To refill Brother inks... or if printer has been left unused and you need to unclog print head? (To make a cleaning cartridges *Fill empties with Magic Inkjet Flush instead of Ink / Then print rectangles using Magic Inkjet to FLUSH print heads once prints appear without white lines simply replace with inks and continue printing rectangles untill all Magic has been flushed out of print head.)
How to refill Empties...
1. Secure empty Brother ink cartridge UPSIDE DOWN in a vice or similar.
2. ONLY HALF fill Dr.EpSUN Refill Tool with warm Magic Inkjet Flush (or correct color Ink if refilling with ink)
3. Then Holding Dr.EpSUN Refill Tool upright... cover metal tip with a tissue and expell any trapped air until ink appears.
4. Insert metal tip into circular ink outlet hole of upturned cartridge... until black rubber makes a GOOD seal.
Holding both securely...
5. Do NOT TRY TO FILL Instead. PULL UP on the plunger of Dr.EpSUN REFILL TOOL.
6. Air will bubble up through the Magic/ink whilst escaping from cartridge creating a vacum.
7. Now... Simply allow plunger to retract and the Magic/ink will automatically refill the cartridge for you.
8. STOP filling before the Dr.EpSUN Refill Tool is empty otherwise air will entering.
9. Repeat until ink cartridge is full.
How to FLUSH a BROTHER print head.
10. Place filled cartridge into printer and you are ready to print.
Use print head cleaning to prime which will also fill the ink tubes... then....
11. Print rectangles of the problem colour(s) using test sheets (see below) to prime ink.
As found in the manual, here are the print test sheets for printing rectangles depending on colour(s) with problem.
Just choose... Yellow, Magenta, Grey Tones etc...
PRINT TEST SHEETS FOR USE WITH MAGIC INKJET FLUSH
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Once prints appear to be normal simply replace the Magic Inkjet Flush with ink cartridges and continue printing rectangles untill flushed.
Hope it helps. If you need any further help Click Here then choose "Ask a Question"
Thanks
John P Bradley Tinteiros (Ebay)
Nov 23, 2009 | Brother DCP 115C All-In-One InkJet Printer
Canon IP4200 printed great photos when new. My
Although refill inks can be quite good, it is likely the cause. Several companies do make good refill inks for canon but they are specific to model lines and you have to be sure you get the right ones for photo colour.
The inks you're using are likely "universal" inkjet inks and are fine for everyday printing but are rarely ever colour corrected properly for photo.
My recomendation to all of my customers is always to keep a new cartridge handy for photos but to use the refilled ones whenever they are printing anything else as it will give you the best balance between print cost and print quality.
Chris
May 18, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I...
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
Streaky printing
At most cases of printer, especially which have done refill at cartridge, print quality is poor or streaky. Many factors influencing this printed result. To overcome print quality is poor, maybe following tips can usefull to prevent printed pages are missing lines or streaky.
First step is ordinary to be done many people when print quality is streaky that is doing cleaning. To get good printed result, sometime this facility is used more than once.
Use Ink Refill with Quality Nicely
For printer have refilled, sometime the quality of printing is also influenced by ink. If will fill your printer again, use ink which the was quality of nicely. I have tested some refill inks at cartridge which have been ascertained still nicely ( sorry: I do not want to publicize result of this attempt). In the reality result make me surprise, there ink of refill making the printed quality is crummy. To choose ink refill read following tips :
  • See viscosity of ink, every merk of ink refill have difference of viscosity. Don’t use Ink refill too jell. Difference of this viscosity is no measure reference viscosity of ink from factory maker of printer
  • Don’t fear to try some inking merks. Done this, you’d find refill ink fitt with your printer. I now only using one merk of refill ink ?.
  • This suggestion of forum, but I still not yet proved. May believe or not. Good ink aroma of soft usually.
Change Original Cartridge
This is last choice. A lot not like to do this ways, because price of original cartridge still costly. Alternative, you can use compatible cartridge which the was price of cheaper than original cartridge. At newest printer, usually there are two until four cartridge in one printer. And price four same cartridge almost at the price of printer even there are some costlier.
Let me know !
Thanks
Fame !
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Cartridge
This is independent of every printing ink type and there usually is good instructions with the refills you get for the ink cartridge.
Have you purchased a refill cartridge?
Assuming not - there are 2 options; one is to buy a replacement ink tank same as the one which has run out, the other is to buy refill inks which you "inject" into your existing cartridge.
Personally, I use refill inks, as the running cost is about 1/5th of buying new and I have a copious supply of print cartridges. Some people really don't like using refills, because it's easy to get stuck with a refill kit and the ink cartridge dies or heads become clogged, forcing you to buy a new cartridge anyway. Your gamble, ahh, I mean choice....
I doubt it's computer/CPU related, but, just in case, you could try going to Start>Control Panels>Administrative tools. Double-click on 'Services', a window opens that show all the optional services for your Windows, some running, some not. Scroll down to "Print Spooler" and across from that you'll see "Started", 'Right-click' on this and change it to "Stop". This stops any printing instances that are stuck, jammed, frozen, just will not go away. Now 'Right-click on "Stopped" and change it back to "Start", close your open windows and try printing again.
If you go to Start>Control Panel>Printers and 'Right-click' on the printer in question, go down to "Properties" and when that opens click on "Print a test page" button. If you machine fails to print, a dialog box/window will open to help you troubleshoot it - must admit the questions asked are very basic and it has never helped me but may open some ideas for you.
Please let us know how it went.
**.The best way to acknowledge contribution is to rate it's relevance.**
Jan 26, 2009 | HP Deskjet 3845 InkJet Printer
Installing print cartridges
refilling catridges is not advisable it is better always go for new one .bcoz the ink which is used for refilling it is not good which is damaged the print head and the the catridge nozzle . i will advise you to buy a new actridge and install . bye
Sep 21, 2007 | HP PSC 1210 All-In-One InkJet Printer
190 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
