Question about Garmin nuvi 350 GPS Receiver
Suction cup problem
I attach my garmin using the suction mechanism, i make sure i press properly and then 'click 'the clip to lock air intake, after a few minutes garmin falls. real neusance
    New Friend:
Remember when you place a suction cup mount it should not be too cold en wet. Put a little petroleum jelly at the outer rim of the mount. That works well.
Posted on Feb 14, 2015
  • Garmin Master
  • 2,130 Answers
Make sure your windshield and the bottom of the suction cup is clean. Clean it with some warter & detergent and wipe dry. Try wetting the bottom of the suction cup before applying it to the window.
I recommend not using the window mount. I recommend using the dash friction mount. You take the risk of cracking your LCD screen when it falls.
1. The dash friction mount will not fall.
2. It's easily removable/
3. It's legal in all 50 states (window mount is not).
- Jim
Posted on Nov 05, 2008
I need instructions on how to mount the nuvi 200w to my windshield
To secure the nuvi 200w to your windshield with the included suction cup mount (pictured below),
center the GPS on the clip, and tip the bottom edge on the bracket. Push the top of the GPS against the top clip until it clicks into place. Hold the bracket and GPS near the windshield where you like it best. Note where the suction cup is on the windshield in relation to the mirror, etc. Remove the GPS from the mount's clip by pushing the top tab back from the top of the GPS.
Clean the windshield (or portion that the suction cup will be stuck against) with a paper towel or newspaper and ammonia solution like Windex, etc. Clean the suction cup with the paper towel and Windex, too.
Lift the lever at the base of the mount - is shown in the picture above - if it isn't already. With the mount oriented as shown in the picture above, press the suction cup against the windshield where desired with one hand. Hold the mount firmly against the glass and use your other hand to press the lever on the base back toward the suction cup and glass. Press until it lays flat against the base / suction cup. Plug the power cord into the GPS and reinstall the GPS in the mount clips as done earlier.
To remove from the windshield, release the GPS from the mount clips, and lift the lever away from the base / suction cup. Locate the tab that is connected to the suction cup edge near the lever. Pull on the tab away from the glass to break the suction seal and remove from the windshield.
If this was helpful, please rate it 4 thumbs up. Thanks & good luck!
Sep 20, 2011 | Garmin GPS
Suction cup does not stick to the base of the tom tom..Everytime I try to attach the suction cup, it just falls over. Help
  1. If you will stick the suction cup to your windshield make sure to clean it first use dry clothe and put pressure while rubbing it to the windshield.
  2. After cleaning it before you stick the suction cup to the windshield make sure the lock is release and then put a pressure and then while pressing it then that's the time you will lock it.
Feb 06, 2010 | Tomtom ONE GPS Receiver
Mounting a transducer on a canoe
I used a suction cup with a bracket to attach the transducer.The suction cup is attached to a rope and when landing just pull.
Aug 30, 2009 | Garmin Fishfinder 140
There is a black disc but I do not see any instructions for using it.Does it mount on the windshield?
my Magellen came with a black disk with adhesive on 1 side. Intended to be adhered to any smooth surface (e.g., windshield). The mount for my unit includes a suction cup. So, mount black disk to windshield and attach suction cup to smooth side of black disk. Be sure disk is positioned where suction cup and bracket and GPS will have sufficient room to mount everything.
Jun 05, 2009 | Garmin nuvi 255W GPS Receiver
Bent lever for use of suction cup on c330 garmin
As this model is discontinued with garmin, I would suspect you would have to but the entire mount. It never hurts to have an extra kicking around.
Check the garmin site.
www.garmin.com
Hope this is of some help
Ed
Apr 25, 2009 | Garmin StreetPilot C330 GPS Receiver
LG GPS not suctioning to windhield
You must clean the window area using windex, or other cleaner, and wipe until dry. A clean winshield area provides the best suction, from the mounting bracket.
Slide the mounting bracket switch to Off & On a few times, make sure the suction cup is able to move(slightly) and that the small tap is facing the area with the notch in the metal.
After putting the switch to the middle, moisten the suction cup slightly
(saliva works bestter than water for some reason)
press it to the window with a slight amount of pressure
then move the switch, (Which should be set to Center!)
to lock it on firmly.
If this doesn't work, then there is a good chance the suction cup has become hardened by the sun. If that is the situation, you'll have to contact LG
(or a place that sells "knock off" brackets to get a replacement.)
I never leave my LG GPS in the car, when not in use. Even the bracket comes out, as I've seen what the sun can do to damage those plastic suction cups, fortunately, I learned it on a $5 replacement set for a Radar detector/Emergency Vehicle Alert device, and not a more expensive bracket.
Dec 07, 2008 | LG LN740 GPS
I have two NUVI 660's and one 360 (?) navigation systems. They all work great except all three have the same problem with the suction cup. Aftera few months, they will not stay attached to the...
Hello rkfowler,
While the suction cup mounts included with most GPS units are very effective, they certainly can fail. It sounds like you are doing everything you can to make it work: cleaning both the windshield and the cup itself. You also might try putting a few drops of water onto the suction cup before affixing it.
If the suction cup mounts aren't working out for you, Garmin does have a couple of other options including a vehicle mount that uses a super strong adhesive or a friction style mount. These are available from Garmin directly on their website (www.Garmin.com) or through your local consumer electronics store, such as Best Buy.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 08, 2008 | Garmin Nuvi 660 GPS Receiver
How does teh suction cup ball fit into the garming 360
Greetings,
There is a seperate black clip that should have come with your gps if you purchased it new. Here is a link to Amazon to get a better idea of what I am talking about:
https://buy.garmin.com/shop/shop.do?pID=8125#
If you have the clip then there is a round indent in it that requires a good measure of force to attach to the suction cup mount.
Take Care,
-WN
May 06, 2008 | Garmin nuvi 350 GPS Receiver
The screen mounted garmin nuvi sat nav now wont stay attached to windscreen
sounds like you need a new suction cup assy, check the garmin webshop
Apr 18, 2008 | Garmin nuvi 350 GPS Receiver
Holder
wet the suction cup a little, press down firmly before flipping the switch to lock it down
Apr 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
215 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
