Question about Ricoh Aficio CL3500N Laser Printer
Ricoh CL3500N not printing black?
Color is working perfectly fine, it doesnt rub off, and and comes out clean.
The black is not printing (well), even with a new toner cart. There are occasional spots where the black will print, but it is very faint, and then is repeated down the page. For instance, the "Windows Test Page" header will show up faintly on the top, and then again a few inches down.. and then again and again at the same distance.
Thanks!
  • OoteR Nov 05, 2008
    Oh,
    I forgot to mention that there are no errors or warnings being thrown by the printer.
  • OoteR Nov 18, 2008
    What exactly is a Dev unit? What do I check for these?
  • Ricoh Master
  • 691 Answers
Sounds like the Dev unit is about worn out. May also be a transfer issue.
Posted on Nov 09, 2008
What is causing my Ricoh CL3500N to allow vertical streaks of faded color on my copies?
This is usually caused by defective, or empty, toner cartridges. A good cleaning and replacing the old waste toner drum as will as the defective cartridge with a certified manufacturer's cartridge usually fixes the problem.
Apr 07, 2015 | Ricoh Aficio CL3500N Laser Printer
My ricoh printer cl3500 will not print lettering, color is fine
Replace the Black ink cartridge wth an original type.It's empty.
Apr 15, 2014 | Ricoh Aficio CL3500N Laser Printer
We have a Ricoh Aficio CL3500N. We are getting a
Never clean or touch the Transfer Roller (spongey rooler) unless your using a dry cloth or vaccum as last measure.
Usually the transfer roller sits on a drum/pcu specific to that color. If you can tell which color is sitting on to of the roller replace that drum/pcu.
Jul 15, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh cl3500N printing with blank streaks in middle of page and faded quality black printing and black ink blotches on sides
The voids and blotches can be a bad black pcu, the voids san also be toner on the glass slat obove the pcu,s there are 4 slats one for each color, on the pcu itself on the upper side is a narrow long opening, the glass slat is above this opening when the pcu is in the printer. It will take a flashlight to see any toner on the glass.
-Carl
Jun 28, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N PCU issues
These machines were actually made by Panasonic and they eat PCU's there is no rhyme or reason, they just do. I would replace all of them as soon as possible. These printers were pretty much interim technology for Ricoh until they developed thier own engine. I highly recommend the new 400 color series, low cost per page, vg color and consumables last a long time!
www.mfpsolutions.blogspot.com
http://www.websitetoolbox.com/mb/copierquestions
Jan 19, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio cl3500n reads replace colr pcu what is this?
The PCU is the photconductor unit. There is a black pcu and a color pcu. Did you replace these or replace the toner cartridges??
Thought I would ask you, since u have answered Ricoh CL3500N
According to the maintenance manual, broken lines are caused by the "dithering" setting. Also there is an in depth color calibration process you can execute. Have you checked the PCU unit?
Here is the maintenance manual:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/cl3500/cl3500en.htm
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | Ricoh Aficio CL3500N Laser Printer
Stops Printing Entire Page After Around 50 sheets
First, check the text in your records for odd characters. It is sometimes possible in data entry to hit a ctrl-"letter" combination that embeds printer codes in your text and these are invisible in many cases to the application. The easiest way is to break up your print job to sections of records and see if a particular record consistently causes an error.
If your sure however that the printer is the problem...
Then I would check the RAM. The printer has 128MB upgradable to 512MB. Normally you can pull the ram and run jobs on the internal memory, but in this case you would need to swap it out.
Jun 05, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio Color Registration Error
One of our Ricoh CL3500N printers- less than a year old- gave us a "color regist error" after changing the transfer belt.
Ran the "adjust color regist" without results. It would just finish and pop back up with the same error.
Color test page printed no color, just BW
I reseated everything, and even replaced the PCU without positive results.
A couple hours later I went back, took everything out (be sure to keep the pcus out of the light!), and vaccuumed the heck outta that printer.
For whatever reason- maybe there was a chunk of toner hanging out, maybe I knocked something loose or back in place, whatever- but when I put all the parts in and turned it on, the error was gone and color printed great!
Dec 11, 2007 | Ricoh Aficio CL3500N Laser Printer
Vetical lines printing on page
If the lines are blue, check the color PCU.
Oct 25, 2007 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
225 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
