Question about JVC AV-32D305 32" TV
Television problem Plug it in, here a relay. See a green LED shining (showing me that it is in standby) on the front panel. Push power and nothing happens. Replaced Horizontal Output Transistor. Still no change. Replaced a zillion caps. Still no change. Any ideas? Can you help me? You seem to be very serious about repairs...anything specific for this model as far as notorious components going bad? PLEASE HELP or point me to someone who can! Thanks in advance.
  • cp12912 Nov 05, 2008
    What is the a 1 control? Also, the crt heaters are not lit. Thank you for replying. Anything else I can do?
  • 85 Answers
The green led actually means its out of standby.advance the a 1 control to see if you have field collapse.dry jonts on the regulator ics is a common problem too....steve.ps.if the crt heaters are lit ,the psu and line stage is functional...
Posted on Nov 05, 2008
  • Steven Hill
    Steven Hill Nov 06, 2008
    hi there once more.check to see if the ht voltage is present and correct,meter across the 100uf/160v cap on the secondary side of the psu.should be 130 volts. or in that region.dc,that is.. was the old line transistor actually faulty or just replaced "just in case"....anyhow,assuming that the transistor was short circuit,meter between the positive side of the 100uf cap and the collector of the line transistor.this should present a relative short cicuit.unplug tv for that,as you may fry your multimeter.no reading on say 200 ohm setting means the fusible resistor inbetween has snuffed it...regards,steve.
Kdl32l5000 no power
Sony 32L5000 Power supply not likely gone bad unless the fuse blow. If there is a click sound and vold meter read 3.3v (standby) on the far top right terminal mean you power supply still good. If no led light on the front that is the bad main board (board with tuner box and RCA, hdmi plug) My replace and work like a charm.
Nov 18, 2011 | Televison & Video
Power Issue
Now,u plug in the tv u get a solid red standby power red LED light in the front of the LCD panel right?When u push the power button on the remote u hear a clicking sound?Only one clicking sound,not the power supply board problems.It the Tuner board problems.But u can make sure it the power board problems or not.By taking the tv aparts check the power board,that board where the a/c power cord goes into it.Look all around the power supply board check for these leakage capacitors,they alway bulges up it top or puff up it top.No bad leakage capacitors,then it not the power supply board problems.
May 14, 2010 | Haier HLH406BB 40 in. LCD HDTV
Tv will not power on!!!
most likely will need a new power supply, google it
Jan 01, 2010 | LG 32LG30 32 in. LCD HDTV
Av 32d305 JVC tv
has the problem solved a little yet?
Oct 31, 2008 | JVC AV-32D305 32" TV
Mitsubishi VS-5075
Your standby power supplies are most likely at fault you should check the low voltage regulators and see if they are functioning they may be defective.
Jun 16, 2008 | Mitsubishi VS-5075 50" Rear Projection...
Relays click. That's about it
try unhooking the wires coming off the power board you should be able to unhook every thing except the switch wire and se plug if the green lights stay on and the red don't come on then you have something loading down your power supply if it still shuts down you need a new power supply
Nov 20, 2007 | SVA-USA HD4208TIIIBU 42 in. HD-Ready...
Sony KE37XS910
MODEL: KE37XS910, KE42XS910
SUBJECT: 9 Blinks of StandBy LED
CAUSE: Change the Switching Regulator part number 1-468-794-12.
Oct 29, 2007 | Sony WEGA KE-37XS910 37 in. HD-Ready...
JVC AV-32D305 32" TV Logo
65 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
