Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Whirlpool Gold Quiet Partner III is dead
Once use the washer was working fine then went to use it again, and nothing. No lights no sounds nothing works. I checked the breaker at my electrical pannel and it checks out ok. Any suggestions?
  • 1 more comment
  • Anonymous Dec 15, 2008
    Our WhirlpoolGold- Quiet Partner III has worked perfectly. Did a load Friday and all was well (December 2008).
    Saturday morning--dead, just as described. It is NOT a house fuse. Can anyone help shed light on this problem?
    Thanks,
    Mindgardener@comcast.net
    We have the very same problem, suddenly (December 2008).
    Advice, help? NOT a household fuse problem.
  • Anonymous Dec 25, 2008
    December 25 (Merry Christmas to me) and I now have no power lights on my unit. HELP!!!
SOURCE: whirlpool gold- quiet partner III
I had a similar problem. So I bought a new computer for it. It didn't fix the problem. It turned out to be the button pannel. With all of moisture surrounding it steam go into the buttons and caused all kinds of faulse info that the computer could not interpt. Had to buy new button pannel and problem was fixed.
Posted on Mar 29, 2008
  • 14 Answers
SOURCE: Whirlpool Gold quiet partner III, leaves dirty, greasy dishes
Ifixall is correct. I also learned several things with the apartment buildings I maintain.
1. the screen or pump trap must also be cleaned regularly to make sure there is no debris, food etc stuck in there.
2. The spray arms must be free of debris or obstructions.
3. Jet dry solution must be filled or has some solution in it.
4. Water must be hot
5. Scraping dishes and prewash them before putting them into dishwasher.
6 install water softner sometimes helps. (I don't know how true this is, since I am unable to do this in our buildings)
7 drain line must be picked up, or secured to prevent backwash.
8. MAKE sure that the lower rack is not obstructing the sprayer arms. Sometimes overloading dishwashers will cause dishes not being cleaned properly.
9. if all else fails, a service technician can come out to determine if the dishwasher is operating properly.
Posted on May 24, 2008
tzweeb
  • 318 Answers
SOURCE: lock light will not go off
what you have to do is push and hold, i believe, the air/heat dry button for 5 seconds and that should change the control from lock to unlocked.
look for a "lock" symbol under the button and thats the one that you have to hold in on.
it may not be the air dry button but there will be one that does have the symbol.
Posted on Jan 04, 2009
appldoctom
  • 311 Answers
SOURCE: Whirlpool gold Quiet Partner III is really loud.
now you'll be able too hear under the tub if motor bearing was the noise.put a long tool to the motor and close to you ear,see if that gives you a clue[i don't want you to give up on it if its not the motor]if was to buy that motor wholesale it would be around 50 bucks or so ,retail about 100 or so.so if replacing depends on the shape of the rest of the unit.[i have sold and installed many]new dishwasher on sale 300$ or so,plus your time to install.but if new its a forsure thing.so depends how much motor,how sure you are wiill solve problem,what shape unit in.hope that helps. God bless ,tom
Posted on Jan 12, 2009
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Posted on Dec 29, 2009
Whirlpool Quiet partner V Dishwasher will not start no lights ,,,nothing
Try unlatched door and hit heated dry, normal, heated dry, normal all within 3 seconds of each ither. Close dior, latch and try again.
Mar 02, 2015 | Whirlpool Gold Series Quiet Partner Iv...
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
I have a Whirlpool gold Quiet partner III. The Normal button of the cycle is blinking and I can't start the dish washer. What is going on?
most likely the door switch is not making contact or is faulty. Shut the door tightly and see if it makes any difference.
Please provide the full model number of the dishwasher in case you need further help.
Aug 26, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a whirlpool gold quiet partner III. The cancel drain button works but nothing else. If you press any of the button for a period of time the normal button flashes; nothing happens though. Any...
Try to reset the dishwasher by using this sequence of keys within 6-8 secs.
HiTemp/ heat Dry/ Hi Temp/ heat Dry/ Hi Temp / Heat dry.
If it works all lights should turn on. Press Cancel to exit.
I am assuming you have already tried to turn the mains power off and back on.
If still no difference, then the controller or the panel has packed up.
You can locate the parts from this site.
Mar 21, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
I have a Whirlpool Gold, had 4years,had to replace
Thermal fuse mounted to the control board see if you have power on each side of it checking from post to ground,if you got power going in but none going out it's blown,and has a more serious issue somewhere.
Aug 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Won't full cycle.
Ok. Mine has started working again somewhat. I ran a rinse cycle and the pump motor started working again. I then drained it, and started a regular cycle and it's working again for now. The motor still does not sound right though.
Mar 21, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Cannot unscrew cap on rinse aid compartment in door of Whirlpool Gold Quiet Partner III
the cap doesn't come off, you just have to open the door all the way. then, when you pour the rinse aid into the dial area, it will get sucked into the dispenser. but if the door isn't open all the way it won't go anywhere and will overflow on you.
Jul 08, 2008 | Dishwashers
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
97 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
