Question about JVC AV-36D503 36" TV
Can't get rid of clock dispaly
I lost the original remote to the sharp 35 LD956 and have a universal remote. somehow i hit a button that brought up a clock display and i can't get rid of it, what can i do.?
    Problem Solver:
  • 6 Answers
Without the original remote or a universal remote that does not have a display button, try unplugging the television for at least 2 minutes and plug the tv back in. This should reset the tv. If the universal remote has a display button, depress the button until you get the desired display results.
Posted on Jan 03, 2009
Sharp tv 25g s100 power button doesn't work, no original remote
The remote may or may not be the real problem, it is possible on most of these to gain access with back removed directly to the tiny button switch that is in back of the plastic power button on the set and press it with something not sharp (a micro switch is what the button activates) and if set comes on get the remote programmed.
Your best bet if the set will make it on that way is to get the original remote----if in North America with the model number of the set contact either Sharp or Andrews Electronics---usually the original is under 35 dollars and no headaches with programming.
If set does not turn on manually with the micro button you may now have a actual circuit problem in the set.
Dec 10, 2012 | Televison & Video
Tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
My FPA Lock is on and we cant find the remote and we us comcast cable. Can you help or do I need to get a new remote?
Same thing happened to me recently. I tried everything from going to answersolution.com and RCA solutions... to NO avail. I brought an original universal remote and that didn't work. I went to radioshack and brought a RCA universal remote and hit the power button and it came on. I hope this works for others. RCA kept telling me that I would have to buy another RCA remote. Nope! the RCA universal remote from radio shack worked just fine and cost only $7.00.
Dec 13, 2009 | RCA TruFlat 27F520T 27" TV
The power button on the tv is broken and i lost the remote
You can just try programming the remote with the Sharp codes they list in the instructions until you find the one that works. Follow the procedure for entering a code and try it. When you find the right one it will turn the set on when you hit the power button. The remote's instructions tell you to turn the set on to make finding the code easier (when the set shuts off you know you found the right one), but you can work without it.
Mar 27, 2009 | Sharp 27N-S100 27" TV
The digital clock on my 30"JVC is showing in the bottom of screen
The menu screen does not function the display. Without the original remote or a universal remote that does not have a display button, try unplugging the television for at least 2 minutes or more and plug the tv back in. This should reset the tv display. If the universal remote has a display button, depress the display button until you get the desired display results. Reference the user guide below for the display button.
neww.gif JVC AV-36D503 36" TV - User Guide (page #43)
Dec 20, 2008 | JVC AV-36P902 36" TV
On Screen Clock Display
Without the original remote or a universal remote that does not have a display button, try unplugging the television for at least 2 minutes and plug the tv back in. This should reset the tv display. If the universal remote has a display button, depress the display button until you get the desired display results.
Nov 28, 2008 | JVC AV-36D503 36" TV
I need to program my remote to my tv
hit the stop button after it has found the code..
May 10, 2008 | RCA Universal Remote Control
Can't clear channel off screen of Sony Trinitron with remote
Press (on your regular remote for your satellite) the t.v. button, then press info, this worked for me and I tried everything. another viewer posted this solution and it worked great! this is not the original remote, it is the satellite remote.
Nov 22, 2007 | Televison & Video
SANYO TV
The DISPLAY button on the remote will remove the on-screen display, so you either have to order the original remote or look for a universal remote with a "display" button and hope it works.
Aug 02, 2007 | Sanyo AVM-3659S 36" TV
Sharp TV/video toggle problem
FLYBACK TRANSFORMER FOR SHARP TV MODEL 21 REQUIRES REPLACEMENT WHERE CAN IT BE URGENTRLY OBTAINED
Jul 11, 2007 | Sharp DVHR300U 109-Hours Video Recorder
JVC AV-36D503 36" TV Logo
188 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
