Question about Microsoft Wireless Optical Notebook Mouse 4000
Microsoft 4000 optical mouse
My screen saver won't operate with the mouse attached. Works fine otherwise. I can't see what to change in preferences.
  • jobizion Jan 16, 2009
    Screen saver wont work when wireless mouse is connected
  • 2,712 Answers
Try this - Go to control panel > mouse > hardware tab > properties > power management tab
Make sure the entry "Allow this device to bring the computer out of standby" is checked.
If you meant that your screen saver doesnt come on because the mouse is plugged in, it could be because the surface on which your mouse is rested is uneven or extremely smooth, causing the mouse to move, or that the mouse sensitivity properties are set very high. When not in use, try placing the mouse on a piece of dark cloth and see if this helps. Or in the steps mentioned above, make sure "Allow this device to bring the computer out of standby" is UNchecked. Note that you cannot use the mouse to get out of screen saver mode in this option. you will have to tap the spacebar..
Let me know how it goes.
Posted on Nov 05, 2008
  • Swilin Sampson
    Swilin Sampson Nov 08, 2008
    I'm sorry, but why a Thanks for trying rating? That's negative here on Fixya. If the solution I offered did not help, kindly post back as to what you did, and a detailed explanation of the issue, so we can troubleshoot further.
    Its not always possible to solve an issue in the first try itself, a bit of to and fro dialogue may be necessary to nail the issue :)
My microsoft wirless optical notebook mouse 4000 is not working i bought it nov 26 2010 and just changed the battery and it is still not working
These need to be cleaned regularly and the surface where they are used as well. I clean mine with a windex wipe or a paper towel dampened with windex. Do not get it wet! If this does not help try going to the Microsoft website to check for an updated driver to download. You should be able to find your mouse and corresponding software download here:
Dec 27, 2010 | Microsoft Wireless Optical Notebook Mouse...
MS Wireless Notebook Optical Mouse 4000 won't scroll in Word 2007
1. Goto COntrol Panel > Mouse properties
2. Then goto wheel tab - exception
3. Then add the programs that arent working.
4. Click apply then ok.
If you don't have the exception area in the mouse properties. Then goto add/remove programs and remove the mouse manager that came with the mouse.
One of these solutions should fix your problem.
May 07, 2009 | Microsoft Wireless Optical Notebook Mouse...
Microsoft wireless mouse 4000 doesnt select tabs/icons
Normal 0 Try disconnecting the camera from the USB port and reinstall the CD software program that came with the mouse. When the program asks you to connect the camera to the USB port, do so and it should work. Hope this helps. Bud
Jan 21, 2009 | Microsoft Wireless Optical Notebook Mouse...
MS Optical Mouse 4000 problem; computer mouse pad no longer functional
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Aug 08, 2008 | Microsoft Wireless Optical Notebook Mouse...
Help with Microsoft Wireless Optical Desktop 4000
it seems like your keyboard n mouse combo is failing take it back and get a new one....ive had that happen a couple times and that what i had to do.
Aug 07, 2008 | Microsoft Wireless Laser Desktop 4000...
Screen Saver no longer runs when Microsoft wireless mouse 3000 is installed.
this is a common problem when using wireless equipment in windows. Especially on Dell notebooks. The PCMService.exe program starts when the computer starts and interaction at some level between this and the Wireless reciever prevents the computer from becoming idle. Therefore, the screen saver and the other idle-related features do not start. this issue may also occur if the PCM and DVDLauncher services are running in the background. This issue also occurs in Windows Vista premium and in Windows Vista Ultimate because of the media center functionality that is built in.
Microsoft reccommends plugging in your wireless device and visiting to get the "optional hardware update" named "Microsoft HID Non-User Input Data Filter." This should fix the problem.
Microsoft also reccommends two possible "workarounds" for this problem if you do not want to install the update or if the update does not work, both are relatively simple:
1- turn off the PCMService.exe program. to do this, first you open the system configuration (start->run->msconfig.exe). on the startup dab of the configuration window, click to clear the PCMService startup item check box. Apply, Close, and if/when prompted, restart your computer.
2- Remove the PowerDVD Software (not advised if you use this software for watching DVD's on your notebook). To do this, open the add or remove programs window (start->run->appwiz.cpl), locate PowerDVD, click change/remove, and follow the steps through for removal of the program.
Jun 30, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft wireless 4000
Screen saver mode, as you know, is entered when the computer senses no activity (including mouse) for a defined period of time. for some reason, the computer thinks there's been some kind of activity. If you have an extreamly sensitive mouse, vibrations could be being picked up "tricking" the computer into thinking there is activity.
The other possibility is that the computer might not be able to respond to the mouse if it went into screen saver mode (perhaps a preference setting with the wireless mouse) and has decided that while operating using a wireless mouse screen saver will be deactivated. Look into your preferences or settings relating to the wireless mouse.
Apr 15, 2008 | Microsoft Wireless Optical Notebook Mouse...
Microsoft Wireless Mouse and Windows Vista
I'm having pretty much the same problem with my Microsoft Wireless 4000 mouse and my hp-compaq 8510p laptop. If I shut my machine down, or restart, my mouse no longer works. I have to uninstall/reinstall the Intellipoint software. The synaptics touch pad continues to work, but the mouse fails.
Dec 19, 2007 | Microsoft Wireless Notebook Optical Mouse...
Dear Nealteresa:
Please click on the link below and download the drivers for Microsoft Wireless Optical Desktop 4000 and select IntelliPoint 6.2 (32bit) for Windows Vista. Or you can also customize by selecting product and operating system. Note: However the Microsoft Wireless Optical Desktop should work with the native drivers of operating system.
Dec 08, 2007 | Microsoft Wireless Laser Desktop 4000...
Microsoft Wireless Optical Notebook Mouse 4000 Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
