Question about KLH DVZ-2500 System
Preset password Is there a factory preset password for parental controls?
  • Derrick D Nov 15, 2007
    the password is set and the reset password from the manual dosent work
  • Faithe22371 Jan 27, 2008
    Tried to change the parental controls and the password is already set. I have tried every number combo I can think of and nothing works. I do not know the factory reset becase there was no manual.
    Problem Solver:
  • 7 Answers
3308
Posted on Feb 13, 2010
Try 2001
Posted on Oct 09, 2008
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
Jul 07, 2013 | Televison & Video
My son blocked everyone out of the tv with parental control. He can't remember the password he used and I can't get the reset to do anything. How can I fix this?
If you have reset the TV back to factory settings, you can use the factory unlock code, which is 0000.
To Reset the TV:
  1. Press the MENU button on the remote control to display the Main menu, and select SETUP.
  2. Highlight Reset Default, and press the OK button.
To Remove the Parental Control Block:
  2. Highlight Parental, and press the OK button.
  3. To use the Parental function, must enter a four-digit password. The factory password is 0000.
  4. Select Program Block, and press OK to display the Program Block menu.
  5. You can remove the parental control in this section.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
May 25, 2011 | Polaroid TLA-01911C TV
Needs password to change parental level
If you did not set the password, then there are two factory presets that may have been used. The first is 0000... and the other is 1234... If neither of them work, then it is likely that you have set your own password previously.
Mar 14, 2011 | Sanyo DWM-380 DVD Player
How do I reset the parental control password on a govideo dvd player?
Parental Control
Blocks playback of rated DVDs based on
their content. Not all discs are rated.
1. In DVD Stop mode, press SETUP.
2. Select Others > Parental.
3. Select the desired Parental Control
rating from "1 Kids" to "8 Adult", then
press ENTER.
4. Enter your password using the 0-9
keys, then press ENTER.
• The factory default password is
3308. If you forget your password,
this will always work.
Password
Changes the Parental Control password.
2. Select Others > Password.
3. Enter your old password using the 0-9
keys.
4. Enter your new password.
5. Re-enter your new password and
press ENTER.
Mar 05, 2011 | GoVideo DV2150 DVD Player/VCR
Trying to get local channels through an external antenna I cant get the tv to switch from cable to air. Also, I never programed a parental control password. Is there a factory preset number? I wanted to...
No,must ask Sharp,reset back to factory will not reset password,only setting.Tv should set simple password to easy to remember that the best.Can't switch back to free air,because the password stuck in cable mode.
Jan 10, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Parental lock
the preset password is 3308. but first goto set up menu select rating press enter/play, select rating agin press enter/play, chose rating you want, then enter password 3308, press set-up to exit, press enter/play to start.
Apr 27, 2009 | KLH KD1220 DVD Player
My ps3 is displaying green and purple waving lines and is effecting my games and movies
If the DVD or Blu-ray Disc™ (BD) cannot be played, or the picture is distorted: Back to top
  • When outputting DVD content or PLAYSTATION®3 system format software in SD resolution, only discs recorded in the NTSC standard can be played.
  • If the PLAYSTATION®3 is connected to a VCR or a combination TV/VCR unit, copy protection encoding on some DVDs and BDs may cause image distortion, or may cause the image to become lighter or darker. In such cases, connect the system to the TV directly.
  • If the DVD or BD does not match the region code set in the PLAYSTATION®3, it cannot be played.
  • Some DVDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to temporarily increase the viewer age restriction level.
  • Some BDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to change the parental control level.
  • The BD may be disc-locked. Enter the password that was set when the disc was created.
and the contact info is 1-800-345-7669 (SONY)
Mon - Sat 6:00AM - 8:00PM PST
Sun 7:00AM - 6:30PM PST
May 29, 2008 | Video Game Consoles & Games
Parental control
i posted the site on tips and tricks where you will find the manual.parental control 8 is the default setting. the factory setting password(enter this in the new password bar)is 3351 and youll have to take it from there.it seems you have a password on your machine you can change it to your own with the factory setting number.good luck, SLEWEY.
Feb 16, 2008 | Cyberhome CH-DVD 300 DVD Player
Parental control code that i didnt set
The factory preset override code for the parental lock is 3308. This code, however, will NOT remove the parental lock code in place. This is just a code to get around the lock. I'm not sure how to dissable to code someone else entered...still trying to figure that out!
Feb 06, 2008 | Televison & Video
Parental Control Passwords
According to the owner's manual, if you forget your code, just reenter ?7777? to reset to factory preset code.
May 28, 2007 | Zenith IQB50M90W 50" Rear Projection...
KLH DVZ-2500 System Logo
110 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
