Question about Frigidaire GLWS1233A Top Load Washer
Frigidaire Gallery trouble
My washer will not completely drain and smells like wires burning
Took off the front panel, opened up the hoses to the pump, found a small metal magnet from my son's pocket that had been stuck in the pump. Once it was removed, the washer worked just fine.
Posted on Nov 07, 2008
Will not drain has strong burning wire smell
check weather the power cord get burnt or the motor get stuck up.
Oct 14, 2012 | Frigidaire Washing Machines
Cant open frigidaire gallery washing machine door
Hi.... if you can't open your door you have something in your drain pump or you need a new pump ... If your washer can't drain the water out yoru washer will lock you out ... till the water is gone
Mar 24, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
First we had a musky smell almost mildew smell, now we have water at the bottom that will not drain. Tried drain and spinn and sometimes it works.
You have have some debris in the drain boot. Remove the back access panel on the washer. Look on the bottom of the tub and you will see a hose (boot) the comes off the tub going to the pump. Remove the boot and clear any debris that may be hampering the draining. Also, while you have the boot off, stick a finger up into the tub to check if there may be a small article of clothing that may be blocking the drain hole.
Feb 11, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire gallery stackable heavy duty washer stopped spinning and there was a electrical burning smell. what is this?
the problem will be in the motor. most of the time if burning smell comes due to coil burn only please change the motor
Dec 23, 2009 | Washing Machines
Mildrew, stale water smell in laundry
Run a very hot wash on your machine with no load
Fill a bucket with a strong solution of soda crystals and pour it into the machine first
Add some more crystals to the soap dispenser
Use an old fashioned soap powder for a couple of washes as well and reduce the load slightly
Modern soap powders do not contain certain bleaches and soda and the 40 degree wash leaves body fats and oils inside which cause odours
Jul 03, 2009 | Frigidaire ATF6000ES Front Load Washer
The washing machine has a very bad musty smell.
The drain plug needs to be cleaned before it burns up your pump. There should be an access panel at the bottom that you have to remove the screws from and drop the panel down and then you should find a cap that you twist and pull that is the filter. Make sure you have something underneath it to catch the water or you will have a mess.Good Luck
Jun 15, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire Washer machine with burning smell
burnt belt, tight center tub bearing, motor going bad, loose idler pulley spring, wiring issues at the motor, a lot of could bees
Apr 12, 2008 | Washing Machines
Frigidaire GLTF1670ASO is cycling fast and not spinning
Hi , try to check timer small motor .,also available in appliances store.
Feb 15, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLWS1233A Top Load Washer Logo
142 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
