Question about Husqvarna Zero Turn Mower Z5426
Z5426 my z5426 keeps moving even after its engaged in neutral
  • 163 Answers
Under the seat should be 2 black adjusting knobs, left and right control arms, these are for adjusting the neutral lock position
Posted on Nov 30, 2008
2013 Honda 420 Fourtrax. After sitting won't go into neutral to start
Hey Judy,
Will it go into neutral after you move it forward or backward a little? Sometimes the transmissions in a motorcycle/ATV will be very hard to get into neutral,,, the dogs on the transmission gears are undercut a tiny amount to keep the gears engaged under power. Try this and reply to me.
Jun 17, 2017 | ATVs
It will run backwards but not forward
If you are able to move in reverse but not forward, you need to adjust the levers. First you will need to elevate the rear wheels and set the neutral. This will then allow you to set the levers for proper forward and reverse movements.
May 03, 2015 | Husqvarna Zero Turn Mower Z5426
I can shift into drive but it won't engage
sounds like a broken shift cable. (the connection between the shifter and the gearbox) common symptoms are the shifter move easier than normal.and does not move to any gears (not even park or neutral).
Nov 23, 2013 | 2004 Chevrolet TrailBlazer
My vehicle was moving then later indicate neutral and stop I try to engage the gear but the vehicle won't move why
If the gear indicator changed to neutral without you doing anything, I would say the transmission selector switch has failed. The switch tells the computer what position the shifter is in.
Jul 04, 2013 | 2004 Mitsubishi Endeavor
96 ROVER DISC. Has strong reverse - won't engage any forward gears. Fluid seems full even when warm.
Make sure the 4wd shifter is in correct position and hasn't slipped out of correct spot to get you moving forward.
Mar 27, 2013 | 1995 Land Rover Discovery
The van will start but when put into gear it will not engage or move even if it is in neutral.
Have you checked the emergency brake to make sure they are not engaged.
Nov 11, 2012 | 1999 Plymouth Voyager
How to shift into 4 LO in 2004 jeep grand cherokee
The correct procedure should be described in detail in your owner/operation manual.
For a 2004, 90 % sure that if it's a quadra trac you have to immobilize the vehicule, put your transmission shifter to neutral keeping foot on the brake obviously, engage the low on transfer case pulling the transfer case shifter, engage the transmission to drive
If it's a select track, normally you have to keep the vehicule moving very slowly (2 mph), move the transmission shifter to neutral, push the transfer case shifter to the right and pull it firmly. Once transfer case engaged, put back the transmission shifter to drive.
It could take few seconds to engage and disengage depending on the temperature and road condition. Do not try it on dry surface (preferable on mud, snow and wet surface). Drive at low speed because you will feel that it's very low geared.
By the way, follow the reverse process to reestablish normal mode
Hope it will help
Dan
Dec 21, 2009 | 2004 Jeep Grand Cherokee
John deere lt120 , 2004
My bet would be a saftey switch. On most riding mowers there are several switches that must be actuated before it will start. First, make sure that blades are disengaged. If there is a handle that engages and disengages them, you might try holding it in the dis-engage position in case the switch is out of adjustment. There is probably one under the seat also. This switch kills everything if you are not sitting in the seat for safety reasons. Also, make sure the parking brake is set, and the gear is in neutral, and not forward or reverse.
Hope some of this helps.
C
Sep 27, 2008 | Husqvarna Zero Turn Mower Z5426
Husqvarna Zero Turn Mower Z5426 Logo
398 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
