Question about Roper RAS8445KQ Top Load Washer
Roper washer cotton straps from cotton handbag caught under agitator - On another washer I could just unscrew (turn, that is) and remove, but that doesn't appear to work on this one.
  • farmormor Nov 06, 2008
    Duh - I thought of that as well - immediately upon seeing the problem, and I debated and debated and very gently tried to release straps and purse, but it's a neat little purse, my favorite, and patched-up items don't appeal to me. As I previously indicated, years ago in order to lubricate agitator, I was able to just lefty-Lucy and the entire one-piece unit was readily removed. However, a 78-year-young greatgrandmother appreciates your time and effort. I'm still pondering. Have a few more days before clothes hamper spills over.
Just cut the strap out. It will be much cheaper to cut a silly strap than to need a repair person or ruin the seal in the agitator. this is not a problem worth fooling with. you must be a female.
Posted on Nov 05, 2008
Machine not spinning dry
Top-loading washing machine has an outer tub that fills with water and sits stationary as well as an inner tub with holes in it. The inner tub has an agitator that attaches to the drive shaft. A drive belt turns the drive shaft, causing the agitator to move back and forth. Broken seals at the bottom of the agitator, or a broken belt, may cause the agitator to perform inefficiently and leave your clothes dirty
In order to properly wash clothes and prepare them for drying, a washer must agitate or spin the load. This helps wring excess water out of the clothing. If your washer has suddenly stopped spinning properly, you will notice that your clothes will be sopping wet when the washer is done. Typically, there is a simple reason for this problem that you can fix without calling in a professiona
1 Check the lid switch. You will notice on the lip of the lid there is a small stem that hangs down. This fits into a hole on the top of the washer housing and tells the washer the lid is closed and it is safe to spin the load. If the switch is faulty or has been blocked, the washer will not agitate or spin.
2 Clean out the switch receptacle. Use a multipurpose cleaner and a sponge (not a paper towel, it can shred and get caught in the switch receptacle.) Thoroughly clean the area around the switch and the receptacle.
3 Test the washer. Close the lid, allow the washer to fill with an inch of water, and move the selector to the spin cycle. Pull out on the selector. If it does not spin, stop the cycle (push the selector in) and turn the washing machine off. This means there could be three problems with the washer: the switch might be broken, something might be caught in the agitator, or the motor for the agitator may be burned out.
4 Check underneath the agitator. Small items such as underwear, panty hose or bra straps can become caught underneath the agitator and keep it from moving. Run your hand underneath this area and see if you feel anything. If you do, unwrap the item and test the washer again. If it still does not work, move to Step 5.
5 Contact a repair person. If the washer still will not agitate or spin, it will need to either have the switch replaced or the motor replaced. Contact a certified appliance repair person to have the machine inspected. If it is still under warranty, the repair person's visit should be covered.
However if its only the agitator arm, then
Instructions to Remove/replace the Agitator
1 Unplug the washer.
2 Slide a putty knife under each side of the washing machine top to release the springs holding the top in place. Lift up the top on its hinges.
3 Pull the tub clips from the inner tub using a pair of pliers.
4 Pull up on the agitator top to expose the nut holding it in place. Remove the nut using a socket wrench. Lift up on the agitator to remove it from the machine.
5 Turn the agitator upside down and remove the seals from the bottom. Replace them with a new set of seals. If the agitator is cracked, replace it.
6 Reassemble the washer.
Removing the Belt
7 Unplug the washer from the wall outlet.
8 Pull out on the bottom panel on the front of the machine. Look underneath to locate the drive belt.
9 Pull on the drive belt at the washer tub to remove it. Push down on the idler pulley near the motor to remove the belt from the machine. Route the new belt around the pulleys in the same way as before.
10 Reassemble the machine, plug it in and test.
Apr 20, 2012 | Whirlpool Washing Machines
How do I remove the agitator to allow release of an item stuck under it?A cord is caught in the holes under the agitator.
Most of thes simply unscrew counter clock wise. Some have the top part that unscrew and the a keeper of some sort under the top piece that has to be removed before you can lift it out. Try to unscrew it counter clockwise and see if it will come off. there may even be a nut under the top peice that will have to be removed.
Nov 14, 2010 | Whirlpool LSR5132PQ Top Load Washer
Baby sock caught under agitator
funny thing is the two most common things to block a water pump hose are a small coin and a babys sock yet your the first person ive seen belive it to be a sock. yet as i said that will only block the drain hose to the water pump if the washer is pumping out water then its not that if it is that the bin! wont spin you have other problems it could be a loose belt the gear box or the main motor has simply strarted to give out a small sock wont stop it from spinning
hope it helps some
Apr 24, 2010 | Roper RAX4233PQ Top Load Washer
Agitator not moving like it should on roper top loading washing machine.
Pull off the softener cup
remove the small cap
unscrew the bolt
remove top half of agitator
replace the plastic DOGS
Feb 07, 2010 | Roper RAS8445KQ Top Load Washer
Hot point washer heavy duty 7 cycle jewelry caught under spinner
if the unit is just a few months old the agitator has not seised the the shaft. the very top of the agitator should unscrew and with a little effert you should be able the lift the agitator off the shaft collect the jewlry and put it back together all should be find
Aug 10, 2009 | GE WBSR3140DW Top Load Washer
I have a Whirlpool Ultimate Care II Washer. I was unloading it this morning and my ring got caught and the stone popped out. I think it is under the agitator and I would like to take it out to look, but...
Remove the frabic dispenser from the agitator. Reach in and grasp the small raised handles of the inside dome cover and pull it out. The bolt showing is a 7/16th size. You'll need to hold the fin of the agitator to unbolt it. No need to remove it completely, just unscrew it until it moves freely. Lift up the agitator. Reverse the process to re-assemble.
Jun 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator barely turns, especially with a full load. It's a Roper Washer top loader.
Remove the agitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have a square in the middle that the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove thebolt holding down the bottom 1/2 of the agitator, lift up on the agitator.
May 04, 2009 | Washing Machines
Shirt caught in the agitator
The top of the agitator should unscrew then pull off.
Feb 21, 2009 | GE Spacemaker Washer and Dryer Electric...
Drawstring tangled under agitator on an older GE washing machine.
You should be able to unscrew the top cap of the agitator ( may be left hand thread ) and lift off the agitator once the cap is off... They sometimes stick so you may have to muscle it to remove that cap..once lifted off..you should be able to untangle the string that is caught..
Sep 21, 2008 | GE WBSR3140DW Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
37 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
