Question about Ruud Heating & Cooling
I replaced my Rheem Ruud 62-24084-82 Ignition Module Control Board in my Rheem gas furnace last year. Has worked great until last night. Now blower purge motor starts but does not go into ignitor cycle. On board power light is ON(AN1)but green light next to it (AN2) is intermittently going on and off. I am trying to determine cause of malfunction.
  • 1dandy1 Nov 05, 2008
    Need more information on how to test and how to jumper wires to verify part is bad. This part looks like a distributor vacuum advance module only it is a switch with several wires.
  • 147 Answers
When the purge motor turns on, the controller is waiting for proof that it is running before ignition. On your model I think it a differential pressure switch and it should be in front of the furnace. Should be able to see a pressure or vacuum line running to. If it isnt there there may be a switch inside purge motor. If there is more than 2 wires running to the motor it probable is there. Anyway the controller is waiting for proof.
Posted on Nov 05, 2008
  • butch welch Nov 05, 2008
    Do you know what a single pole douple switch is. I believe before you start jumping wires I would check the line going to the control. Can you tell me if its on the pressure or vacuum side of the fan or both. Is there plenty of air coming from the fan..If you have to jump it, jump the common and the n.o.
    You have found the right part. Before you start jumping wires make sure the line going to it is good. The fittings or connections have to be airtight, no crimps, or breaks. Can you determine if its pressure or vacuum or both. Make sure you have plenty of air coming from the fan. If you have to jump it will be the common (C) to the N.O. I would take the line off and blow it out..
I have a Ruud Achiever 90 Plus Gas Furnace with Air Conditioner. I have a new Nest Thermostat. What is the correct wiring connections on the Furnace?
A Ruud Achiever gas furnace I believe came in a two stage model for heating. What this means is that you will have a high and a low setting. Your furnace should have two wires that control the heating cycle a W1 and W2. This should correspond with the terminals on the nest thermostat. You may run into issues if you do not have enough thermostat wires to control the furnace. If you are ever in the need for Ruud And Rheem Gas Furnaces we offer a great selection online. Shop Natural Gas Furnace. We also have a chat line which can provide technical support.
Dec 26, 2017 | Ruud Heating & Cooling
Need to wire furnace blower
Gas valve should only have a couple of wires...24 Volt & common. the blower will use one speed on a gas furnace & a common. If you have AC or a fan switch on your thermostat, then the high speed will also be connected on the blower.
Dec 16, 2013 | Ruud Rheem Furnace Blower Motor...
The fan inside the furnace cycles on and off several times before finally turning on completely.
You may have a variable speed blower that is not wired correctly to the thermostat or the problem could be the ciruit board.
Nov 10, 2017 | Ruud Rheem Control Circuit Board...
"RUUD Achiever 90 Plus" Propane
Hello bikejocky,
MOST LIKELY you have a "hot surface" element
with a tiny crack in it...
About 25 years ago... I put one of my poor abused
fingers on the element to see if it was at all warm...
In so doing I touched the spot where the crack was...
and it did INDEED have a full 120 volt, 60 cycle AC
current waiting for my FINGER to complete the
circuit... (not a recommended procedure)
My 25 year old RHEEM... finally kicked it.
I keep spares... and bought 2 more when I used
the last
Since these parts are pretty cheap... I get spares
62 22868 93 Rheem 62 22868 93 Hot Surface Ignitor
Take a look... There are two basic configurations
The WISEST APPROACH is to use a "meter"
to verify the "line current" is present (not finger)
and check the "SURFACE" for continuity.
Once you copy the number DIRECTLY from
YOUR OWN part... look it up... internet... eBay
and AMAZON (like Robert Shaw #41-408).
>> It is the plug & mount that is important...!!
(consider that spare you always wanted
(If you get it... you will probably never need it)).
The cycling limit & fan
(never touched a RUUD... (so... I presume)) is to clear accumulated GAS FUMES to avoid any explosive
I do know RHEEM... (ERGO... I have every confidence)
((RHEEM & RUUD, in my opinion, are design twins)).
Carnac the Magnificent
May 10, 2017 | Ruud UBHC Air Conditioner
Ruud Silhouette II Gas Furnace, the furnace lights but will only stay on for a few seconds?? What could be the problem??
Bad or dirty flame rod.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Jan 09, 2010 | Ruud Heating & Cooling
(HVAC) Furnace Not Igniting Quickly
Make sure a back draft in the flue is not happening. Wind can blow it out until the flue heats up. The flame sensor may not be close enough to the burner flame. It may be weak and need to be replaced or if its an optical one it may be dirty and not see the flame very well. Its not wasting much gas but it puts extra wear and tear on the gas controls, is noisy, and, as you said, blows cold drafty air. A gas control system that has issues of any kind is not real safe. It needs to get fixed.
Jan 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
Rheem water heater with powerglow ignition wont re-light
I have fixed mine. The problem part is the Ignition Control module. It is made by Robert Shaw part # SP10758. I paid $93 plus shipping.
Works great now. A repairman wanted to sell me a gas valve for $488.
Watch out for these people.....
Nov 06, 2008 | Water Heaters
Heating & Cooling Logo
469 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
