Question about Toshiba Satellite A15-S157 Notebook
Toshiba Satellite A15-S157 PC Notebook
Wi-Fi not connecting. Tried uninstalling and reinstalling the wi-fi adapter but now get a "this device cannot start (Code 10)" Intel (R) PRO/100 VE network connection.
Dude, I have the same laptop as you, and the same problem as well ! I managed to try some things out and i figured out that your wireless settings are ****ed up as soon as your laptop runs out of battery while the cover isn't open. Just shut it down by pressing the power button 5-10 seconds, then restart in safety mode with the network reset thing. This will reset the whole network settings back to defaults... ;) i know I'm a year too late, but I hope it'll help some people !
Posted on Oct 10, 2011
    Sergeant:
    Champion:
  • 275 Answers
Go to services.msc and chk if the wireless zero is on or off
Posted on Nov 05, 2008
2 Suggested Answers
citirulez
  • 44 Answers
SOURCE: Wi-Fi not connecting on Toshiba Satellite A15-S157 PC Notebook
you tried giving it a static IP address rather than using automatic settings (i.e. DHCP). Sure enough, this cured the problem, connected fine. I looked in the dhcp server logs and while it was not complaining that the IP address pool was all used, it did seem that all the IP addresses available were being used. I increased the number of IP addresses available to be allocated by the dhcp server and problem solved. The big mystery to me is why Windows XP would report this as a problem with a weak signal? Isn't the access to the dhcp server and the allocation of the IP address at a layer above the wireless connection? Anyway, it's useful to be warned that the wireless diagnostics are misleading.
What year was toshiba satellite 2410-S203 pc notebook first launched?was it equiped by WIFI?
My sources indicate 2003.
It has > Optional
http://www.csd.toshiba.com/content/pr/html/Satellite%201410%20and%202410%20Press%20Release%20%289-24-02%29.html
The Wireless Antenna On-Off switch is on the Right side. The Wireless Antenna LED is to the left of the On-Off switch. It glows when the wireless antenna is in use.
It has to have an > optional
Turn the laptop over, Front facing you.
The Battery Compartment is on the Front Right corner.
The Wi-Fi Compartment Cover is on the Back Left corner.
Remove the single screw in the right middle of the cover. (Philips head)
See if a Wi-Fi PCI Mini Card is installed.
No?
You'll have to obtain a Wi-Fi PCI Mini Card for your Toshiba.
From a quick search just now, (Not advertising for this website),
http://www.impactcomputers.com/p000339520.html
(Remember to remove ALL power to the laptop Before installing. AC adapter {Charger} and Battery.
Also remember to observe Anti-Static Precautions before handling the Wi-Fi card, and when installing)
Here is the Toshiba Satellite 2410-S203 Notebook PC User Manual, also,
http://www.fixya.com/support/p265858-toshiba_satellite_2410_s203_pc_notebook/manual-14885
Nov 16, 2010 | Toshiba Satellite 2410-S203 Notebook
Hello
1. uninstall the wireless/wi-fi driver
2. restart the system
3. try to connect wi-fi
Dec 27, 2009 | Toshiba Satellite 1800-S253 Notebook
Problem with on or two network adapter
First make sure that wi fi switch of your laptop is turn on.
Then check that wi fi netowkr adapter driver is installed perfect and enable.
Go to device manager and enable wi fi adapter.
For check device manager right click on my computer icon then click on property then hardware ->device manager.
Then you see all driver list.
Then enable wi fi .
Also right click on my computer places icon then go to proeprty then you can see your network adapter right click on wi fi adapter then click on "view available wi fi networks."
then connect your wi fi .
Let me know if you need more assistance.Thanks.
Oct 01, 2009 | Acer Aspire 4720 Notebook
Wi fi card or adapter
First check that you have got right adapter for your laptop.
then check that your motherboard actually supports a wi fi. IF you have everthing sorted then go ahead and plugin the compatible adapter. Also, be sure to have the latest driver installation disk ready.
Start your PC, it should detect it and then ask you for the driver.
If this dosen't work or you are unsure then my best advice is to take it to an authorised vendor and let him do it, no use playig around with an expensive laptop.
Jul 18, 2009 | Toshiba P000392200 - Satellite A40, A45...
Wireless no longer works
1st Solution:
Check if the wi-fi card is properly installed under Device Manager. Go to Start then look for Control Panel on the right pane. Under Control Panel look for System and Maintenance and then click on Device Manager. Now under Device Manager look for Network Adapters and collapse or click the arrow next to it. Check if your wi-fi adapter is installed(10/100 or 10/1000 is your LAN adapter, wi-fi adapters usually indicates something like 802.11x(could be agn or g or b) or the word "wireless". If you don't see anything I mentioned above that means your computer is unable to detect any wi-fi adapters installed. Know if you found a wi-fi adapter but there is a yellow exclamation or question mark, all you have to do is re-install the drivers for your wi-fi adapter(you can download the drivers on the Compaq website for free.)
2nd Solution:
Check if the wi-fi is disabled or stopped, if you have a bulit in wi-fi adapter on your laptop they have a wi-fi switch on the side or near the function keys(F1, F2, F3 up to F12). Wi-fi button/switch will have a logo or marking of an antenna that has waves coming out of it and there is a LED light that will indicate if its on or off(for Comapaq laptops it's either a blue button at the front, near the function keys or at the front panel on the buttom edge.
If both fails then you may need to contact Compaq for further assistance.
Hope this will help you fixin the wi-fi problems on your laptop.
Regards
Nov 23, 2008 | Compaq Presario Notebook
Nov 05, 2008 | Toshiba Satellite A15-S157 Notebook
Toshiba Tecra A3-S611 Freezes
If by "turned off" you mean with the switch, the wireless adapter itself is probably bad.The cheapest solution is to buy an external wireless adapter.
Sep 10, 2008 | Computers & Internet
Toshiba Satellite A15-S157 Notebook Logo
113 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
