Tonearm repair on gemini pt-2000 - Audio Players & Recorders
2 Suggested Answers
robotek
  • 1512 Answers
SOURCE: need to replace the light
Hi Scotty
Just go for it man... The light is a pop assembly, so you will have to go in from the bottom to get access to it. Searched for a service manual to link to you, but not much out there. Do you have a multimeter to do a few DC checks?
Posted on Apr 06, 2008
Missing the counter weight on my Gemini PT 2100... Anyone know how to replace it and where to get the parts?
Well this website is showing the picture of it, but you will have to enquire if they are still selling it.
It will just slide on and a screw will tighten it up.
http://www.trusound.co.uk/P/409/Gemini+TWMT-3601604+Tonearm+Counterweight+
I can't find on the net anyone else selling parts for this model, still.
Aug 23, 2016 | Gemini Audio Players & Recorders
I need a power lead
The power cord looks like this is a standard PC/Kettle power cord. Otherwise the connecting cables should be just standard phone cables. have a look at the image here..
http://medias.audiofanzine.com/images/normal/gemini-dj-pt-2000-185179.jpg
May 21, 2014 | Gemini DJ Gemini Pt2000 Turntables
I plugged my gemini pt-1000 turntable into the aux in the back of my stereo, but the sound is very low. Do I need a preamp?
If the amp doesn't have an imput marked phono, or deck, or turntable, the answer is yes. Search for a 'magnetic cartridge pre-amp' via google.
Feb 26, 2011 | Gemini PT-1000 II Turntable
How to remove the platter in Gemini PT-2400 Turntable
hi,
firs of all remove from the mains. pull out the rubber bed over the platter. check whether there is any lock washer in the center shaft. if have remove it. if not its ok. now pull the platter towards upside by putting the fingers in to the holes provided on the platter. remember pull using ur two hands in opposite direction.
ok
Dec 30, 2010 | Gemini PT-2400 Turntable
Would it be extraordinarily difficult to replace the tone arm on a gemini pt-2000 turntable?
I,ve never done a gemini pt-2000 but i've done a technics 12/10 & trust me mate it's a proper pane in the arse.
But like i said
I've never done a pt-2000....
Aug 03, 2009 | Audio Players & Recorders
Missing clip
Parts for that turntable are nearly impossible to find. As far as I know, Pacific Parts is the only place that stocks these kind of parts.
Apr 07, 2009 | Audio Players & Recorders
I'm missing the tonearm counterweight for a Gemini XL-100 turntable. Does anyone have one of these they are parting-out?
hi,
i'm too missing the tonearm counterweight for my Gemini TT01. if you haven't figuered out where to buy one, do you know at least what is the weight that is needed to counter the weight of the tonearm or how to measure the tonearm so as to make a counterweight of my own???
thank you in advance
Mar 07, 2009 | Gemini XL-100 Turntable
50Hz noise appears at the end of the disc
HAVE YOU GOT ANY OTHER EQUIPMENT CONNECTED IF SO DISCONNECT THEM THEN JUST USE THE AMP,DECK AND SPEAKERS AND MAKE SURE THERE IS NOTHING ELSE PLUGGED INTO THE SAME CONNECTING LINE
THEN ADD THE OTHER ITEMS ONE BY ONE
DEREK
Nov 16, 2008 | Philips gemini XL-500 II Turntable
Gemini cdt-05 hybrid grounding noise
Well, number #1 - it's a Gemini. So, you can rest assured that the craftsmanship is not the greatest. It's hit or miss with this company.
#2, if the issue you are having is a ground issue, then perhaps the internal ground wire might have come loose, or there is some sort of interference somewhere. Do you have your turntables next to anything that draws alot of power? Such as air conditioner, or a microwave, fridge, etc? Also, connecting to the same power outlet with something that draws alot of electricity might have the same effect. Try a different power outlet. One that is not being used if possible. If you use a power strip or extension cord, try a new one.
There could be many issues which cause feedback.. the main thing is to determine what is NOT causing the problem. So, you know it's NOT your mixer. Great. Now, move on to the next step. Check your cartridges also. Try swapping them out, see if the problem follows. Many times the tonearms aren't grounded properly. There are 5 wires coming out from the tonearm - L+, L-, R+, R- and GROUND. If the ground came off during transport, or movement, this might be your problem.
- Davis
We are the Turntable Experts!
DIGITAL ANALOG THERAPY
Aug 08, 2008 | Philips gemini CDT-05 Turntable
195 people viewed this question
 Grubhead
Grubhead
