Question about Lexmark Office Equipment & Supplies
Need program to down load printer - Lexmark Office Equipment & Supplies
  • Lexmark Master
  • 6,487 Answers
You can go to this link and search for the model number of your printer so you can download the software for it
http://www.lexmark.com/lexmark/sequentialem/home/0,,204816596_652569478_0_en,00+en-USS_01DBC.html
Posted on Nov 06, 2008
How to use the *2670 lexmark scanner
Please follow the steps below on how to scan using your Lexmark X2670 printer:
Using the printer control panel
1. Open the top cover, and then load an original document face down on the scanner glass.
2. Close the top cover to avoid dark edges on the scanned image.
3. Make sure that the printer is connected to a computer, and that both the printer and the computer are on.
4. From the printer control panel, press the scan button.
5. Follow the instructions on the computer screen.
Using Windows
3. Do one of the following:
• In Windows Vista, click > All Programs, and then select the printer program folder from the list.
• In Windows XP, click Start > Programs or All Programs, and then select the printer program folder from the list.
4. Click Lexmark Productivity Studio.
5. On the main screen, click Scan.
6. Follow the instructions on the screen.
Using Macintosh
3. From the Finder desktop, double-click the printer folder.
4. Double-click the 2600 Series Center.
5. From the "What is being scanned?" list, choose the type of document to be scanned.
6. Click Scan.
Source: Lexmark X2600 Series User's Guide
Oct 09, 2011 | Lexmark X2670 All-In-One Printer
Paper won't feed through printer. (Lexmark X2690). Can't see anything stuck in printer. Paper won't go down past rollers, but I can't see down inside etc
Loading paper and original documents
1. Make sure:
• You use paper designed for inkjet printers.
• If you are using photo, glossy, or heavyweight matte paper, you load it with the glossy or printable side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
• The paper is not used or damaged.
• If you are using specialty paper, you follow the instructions that came with it.
• You do not force paper into the printer.
2. Before loading paper the first time, slide the paper guides out toward the edges of the paper support.
3. Load the paper vertically in the center of the paper support, and adjust the paper guides to rest against the edges of the paper.
Align the print cartridges
In Windows
  1. Load plain paper.
  2. Then do one of the following:
    - in Windows Vista, click pattlnk_852008_1527-vista-start-button.gif.
    - in Windows XP and earlier, click Start.
  3. Click All Programs or Programs, and then select the printer program folder from the list.
  4. From the printer folder, click Maintenance - Align Cartridges.
  5. Click Print.
  6. Follow the instructions on the computer screen to finish.
To clean the print cartridge nozzles:
In Windows
  2. Do one of the following:
    - in Windows Vista, click pattlnk_852008_1536-vista-start-button.gif.
    - un Windows XP and earlier, click Start.
  4. From the printer folder, click Maintenance - Clean Cartridges.
  5. Click Print. A page prints, forcing ink through the print cartridge nozzles to clean them.
  6. Print the document again to verify that the print quality has improved.
Oct 28, 2010 | Lexmark Office Equipment & Supplies
I downloaded the installation for my HP Officejet 7210 - it does everything but scan?????
hello, sorry, but you will need to retrun to hp's web site and down load the un-install tool, it will remove its programs from the regestry, you might run this tool at least 2 times before you try to re-install the hp software, i have found that the basic program from hp does not always work, so down load the entire program, its larger in size. it has more garbage in it, but its seems better.
Oct 14, 2010 | HP Officejet 7210 All-In-One InkJet...
Samsung SCX 4623F cannot scan even its already installed and connected to PC
Dear
Pl. down load and install the driver for scanner also the application smar thru you can also down load EDC (easy document creator0, after installing make repair on maintenance at program of pc.
Printer Support SAMSUNG India
Thanks.
Jul 17, 2010 | Samsung SCX-4300 Monochrome Laser...
Red and green lights flashing alternatively
Down load a program from Intenet. "SSCSERVICE"
Install to your computer.
Open the program
Select printer driver and install driver.
close the program. found a icon right-bottom corner.
click right button.
clear Protection counter.
Now enjoy ready to print your printer.
Thanks
Nov 29, 2009 | Epson Stylus C46 InkJet Printer
How to scan from dell926 printer
Hi here is the user guide for your printer
Download it here
http://support.dell.com/support/edocs/systems/prn926/en/ug_en.zip
How to Scan
Scanning Single-page Documents or Photos
  1. Turn on your computer and printer, and make sure they are connected.
  2. Load your original document or photo.
  3. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 926.
  4. Select Dell All-In-One Center.
    The Dell All-In-One Center opens.
  5. From the Send scanned image to: drop-down menu, select the program you want to use.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add the program to the list.
  6. Click See More Scan Settings to customize your scan.
  7. When you finish customizing your settings, click Scan Now.
Scanning Multiple Photos or Multiple-Page Documents note-dell.gif NOTE: Some programs do not support multiple-page scanning.
  2. Load your original document. For more information, see Loading Original Documents on the Scanner Glass.
    note-dell.gif NOTE: You can also open the Dell All-In-One Center from the operator panel on your printer. For more information, see Using the Dell All-In-One Center.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add your program to the list.
  7. Click the Advanced button.
    The Advanced Scan Settings dialog box opens.
  8. On the Scan tab, select the Scan multiple items before output check box.
  9. Click OK.
  10. When you finish customizing your settings, click Scan Now.
    After you scan the first page, a prompt appears requesting the next page.
  11. Place the next sheet on the scanner glass, and click Yes. Repeat until you finish scanning all pages.
  12. Click No when asked for another page.
    The program opens with the multiple pages scanned.
Oct 06, 2008 | Dell Photo 964 All-In-One InkJet Printer
HP PSC 2175
go to the Hp website and down load the software for your printer.
Jul 14, 2008 | HP PSC 2175 All-In-One InkJet Printer
I just got a new Dell with Vista.
most probably the driver that you are loading for your lexmark is incompatible with vista and you need to load the vista compatible drivers. you can download them from the link below
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:405::0
Jan 21, 2008 | Lexmark (09A1501) for Optra T Series...
Trying to get my printer working
go to Lexmark X2350 - Drivers and Downloads and select your Operating System:
http://search.lexmark.com/printer/US/en/19M0000
Nov 24, 2007 | Lexmark X2350 All-In-One InkJet Printer
15 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
