Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Refrigerator side by side neither will won't stay cold
We cleaned it all out and there was a thick sheet of ice on freezer waiting for it to all defrost. We used a hair dryer but there is still ice behind the shield
  • PamandGaryKn Feb 07, 2009
    where is the defrost timer located
    President:
  • 1,462 Answers
Keep going with the hairdryer till all ice melted off. do not point dryer at any stats.
ice should not build up. check heater and thermal cutout in series with heater for a start. you may also have the return air duct frozen as well and this is usually hidden behind the evaporator. safest way to deal with this is to turn off and leave for a day with doors open
Posted on Nov 05, 2008
You have an automatic defost malfunction. There is a timer (or circuit board) which controls the run and defost modes of your refrigerator. Once in defost, there is a heater that comes on to melt frost behind back panel. Once a certain temperature is reached behind the panel, a defost thermostat (or bi-metal) cuts off the heater. This maintains your frost-free operation.
2 Suggested Answers
  • 1122 Answers
SOURCE: refrigerator side by side neither will won't stay cold
your defrost toimer ,defrost heater or defrost sensor,has failed,do you have a meter to check these parts?also is the freezer fan running?mike
Posted on Nov 06, 2008
Fridge not staying cold and build up of ice on back piping
One of you fans is not running and causing the compressor to eventually making your compressor overheat and eventually shut off
Apr 14, 2013 | Refrigerators
Roper # RS25AGXNQ00 the freezer side too cold around -22+ and the fridge side 51+ also found ice forming inside the air diffuser. Any suggestions?. Thanks
Make sure the settings are on the recommended setting, If so check to see if the freezer bottom is frozen over with sheet ice, if it is than you either have a leek in the ice maker or a clogged defrost drain line. The excess ice obstructs the air flow from the freezer to the refrigerator making the freezer to cold and the refrigerator not.
May 20, 2011 | Whirlpool Refrigerators
The freezer side quit staying cold today. No
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 28, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Maytag MBB1952HEW won´t make ice. Where is the fuse to icemaker located? It´s not in the bottom freezer coil area.
back wall of freezer has thick layer of ice frosting over, freezer not cold frig compartment seems to be ok.///????
Oct 14, 2009 | Maytag 22.1 cu. ft. Bottom Freezer...
Nov 05, 2008 | Refrigerators
Freezer not freezing
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Sep 28, 2008 | KitchenAid Superba Architect KSCS25INSS...
KENMORE COLD SPOT REFRIGATOR/FREEZER,MODEL 106 52542101,WILL NOT EJECT ICE (SIDE BY SIDE)
hi thanks for the question if the ice cubes are formed in the tray nicely then you need a new ice maker if the whole ice tray is a smooth sheet of ice the freezer might not be cold enough empty out the ice manually ant try again &lower the freezer temp thanke the appliance doc
Sep 17, 2008 | Refrigerators
Bottom of freezer icing with thick sheet of ice
you have a froen drain thats why it is allways getting ice on the floor. you need to remove as much as you can then remove the back of the freezer so you can clear the drain pan and clear the drain. its not hard to do just you will have a lot of water on the bottom and your floor maybe. once you remove the ice from the pan have some very hot water and pour it in the pan utill the drain is free and the water go's down into the drip pan. shut the unit off untill tour done and be carefull around the coils. once its clear put the back on and plug the fridge back in. you will now have no more ice build up. make sure there is no food back there that can block the drain either. its a god time to clean the freezer out
Aug 10, 2007 | Zanussi ZEBF250W Bottom Freezer...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
149 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
