Question about Epson Stylus CX4800 All-In-One InkJet Printer
Changing cartridge stylus cx 4800- cartridge cover is not cleared to remove
After pressing on button as instructed and lifting up the scanner I cannot remove cartridge because it is not completely cleared to do so.How do I get it so cartridge cover is easily lifted up?
  • walkbeagle Nov 05, 2008
    help with cartridge cover not completely over to remove cartridge. Ink level is negligible from cyan and low with the other two colors. What to do?
  • Anonymous Jan 22, 2009
    CX4450 Epson all in one printer, cartridge carrier ont centering, so I can replace ink cartridge.
My Epson Stylus CX1500 printer has all leds on red. The Black ink was almost finished when it happened. I cann't change the crtridge b'cause it is not moving out.
Posted on Jan 24, 2009
I called a life person who finally showed me that the ink was not completely used up, although, it kept warning me it was so low. I guess from what he said it turns an orange color when completely out of ink and then the cartridge holder moves over so that the cartridge can be removed. I hope he's right. I can still print. The directions would be more helpful if this was explained.
I take all information that I read literally and completely. I'm not computer savvy!
Posted on Nov 06, 2008
I just replaced all my inks and it is still telling me to replace my cartridges i also turned it on then off
  1. Open the scanner.
  2. Press the cp_button_14.gif Stop button to move the cartridges to the replacement position.
    Caution: Do not move the print head by hand; this may damage your all-in-one. Always press and release the cp_button_14.gif Stop button to move it
  3. Open the cartridge cover.
  4. Press down all the ink cartridges until they click into place to make sure they are properly seated.
  5. Close the cartridge cover and push it down until it clicks into place.
  6. Close the scanner.
  7. Press the cp_button_14.gif Stop button to begin charging the ink. This takes about 2 minutes.
    When the On light stops flashing and remains on, ink charging is finished.
    Caution:
    Never turn off the Epson Stylus CX while ink is charging or you'll waste ink.
    If the ink light flashes, press the cp_button_14.gif Stop button and press down all the cartridges securely.
    If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus CX with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
    If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 22, 2011 | Epson Stylus cx7450 All-In-One InkJet...
My epson stylus cx6000 printer keeps showing -(install the ink cartridges) and I have already put in new ones. The code is E-02.
f you have just installed a new cartridge and you still see an ink related error message, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Stylus CX is turned on.
  2. Check the photo viewer screen to determine which cartridge is incorrectly installed. Then do one of the following:
    • If printer shows the ink cartridge is expended, press the cp_button_6.gif Start button.
    • If the printer shows the cartridge is low on ink, press the Setup/Utilities button. Press the cp_button_41_er.gif or cp_button_42_er.gif button to select Press Start to change cartridges. Then press the cp_button_6.gif Start button.
  3. Press the cp_button_6.gif Start button again.
  4. Lift up the scanner, then open the cartridge cover.
alert_caution.gif Caution:
Never attempt to open the cartridge cover when the print head is moving. Wait until the cartridges have moved to the replacement position.
  • Press down all the ink cartridges until they click into place to make sure they are properly seated.
  • alert_note.gif Note:
    If a cartridge is properly seated already, you may not hear a click.
  • Close the ink cartridge cover and press it until it clicks into place.
  • Close the scanner.
  • Press the cp_button_6.gif Start button. The Stylus CX charges ink for about one minute and displays Charging Ink on the photo viewer screen until charging is finished.
  • alert_caution.gif Caution:
    Never turn off the Stylus CX while the Charging Ink message is displayed or you'll waste ink.
  • Press the Setup/Utilities button to return to the previous mode, if necessary.
  • Aug 26, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    E-90 error message on Epson CX6000
    If the error code E-90 appears on your Stylus CX control panel display, the print head may not be able to move back and forth freely.
    If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
    1. Turn off the Stylus CX.
    2. Lift up the scanner.
    3. Press down on the ink cartridge cover to make sure it is completely closed.
    4. Close the scanner and turn the Stylus CX back on.
    Also
    If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
    2. Lift up the scanner to access the printer area.
    3. Remove the tape from the ink cartridge holder.
    5. Close the scanner.
    6. Turn the Stylus CX back on.
    Aug 07, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    I need to change the ink cartridges on epson stylus sx200 but i need help as instruction book doesntreally tellyou how-thanks
    buy an ink cartridge made specifically for your printer. Turn on your printer and raise the lid or press the cartridge changing button. 3 Wait for the cartridge carrier to slide out. with an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Carefully remove the tape from the ink opening on the bottom of new cartridge. Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. with an Epson printer close the cartridge holder lid and press the cleaning button to charge the cartridge. Close printer cover.
    Dec 09, 2008 | Epson Stylus Multifunction Inkjet Printer/...
    Error inkcartridge
    Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
    Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
    Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
    Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
    Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
    Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
    Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
    Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
    Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
    Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
    Error Message: Scanner unit open -- > close the scanner unit
    Solution: Carefully close the scanner and press it down until it clicks securely into place.
    Error Message: Scanner error -- > See your documentation and call service if necessary.
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
    Error Message: Printer error -- > See your documentation and call service if necessary.
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
    Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    How do i change the ink cartridge on my epson cx6400?
    I am assuming that you already have a replacement ink cartridge.
    • Make sure the printer is on.
    • If the LCD screen says that your ink cartridge is empty than
    you can simply press the Color button (the button looks sorta like a diamond with a line in the middle of it).
    • If you wanna change the ink cartridge but the printer does not say that it is empty then
    press the setup button, then press the top left button until Replace ink is displayed. Finally, press the Color button.
    • Lift up the scanner section
    • Wait for ink cartridge holder to move to replacement position then open its cover.
    • Identify which cartridge you want to replace. Press in the tab to release the cartridge, then lift straight out.
    • Before unwrapping the new cartridge, shake it gently four times. Then remove from wrapper.
    • Lower new cartridge into holder, press down firmly until clicks.
    • Close cartridge cover
    • Carefully lower the scanner section and press it down until it clicks
    These instructions were found in http://files.support.epson.com/pdf/cx64__/cx64__pg.pdf on pg 12.
    Oct 12, 2008 | Epson Stylus CX6400 All-In-One InkJet...
    Epson stylus cx 7400
    Epson includes step-by-step instructions on changing the ink cartridges in the Printing Preferences menu:
    Click the start button and open the Control Panel.
    Right click Printers and select Printing Preferences.
    Click the Maintenance tab.
    You should see a button that says Ink Cartridge Replacement.
    Just follow the instructions and it walks you through it.
    Sep 19, 2008 | Epson Stylus Multifunction Inkjet Printer/...
    Epson Stylus DX7400 - Ink cartriges
    Lift the scanner up to expose the inside of the printer. Thers a button "stop" top left face of printer, press and release and the print cartridge holder will move, press again and it will stop at the colour that needs replacing, press again (total four times) to show if other cartridges are ok. Press again and the cartridge carrier will return to right of the machine. Lift the lid (grey colour) to show the cartridges, remove and replace the ones that have been shown to be empty. Close the lid, it should click. Close the scanner down again. Press "start" to recharge the cartridge. ANy other problems try the epson support site. Good luck.
    Aug 31, 2008 | Epson Stylus C86 InkJet Printer
    Changing Cartridges
    I inspected the users manual, there it writes:
    The steps below to replace an ink cartridge: Caution: Leave the empty cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. To ensure good results, use genuine Epson ink cartridges and do not refill them. Other products may cause damage to your CX6600 not covered by Epson’s warranty. 1. If an ink cartridge is empty: Look at the LCD screen to see which cartridge is empty, then press the x Color button. If an ink cartridge is low: Press the Setup button to enter Setup Mode, then press the green button next to the LCD screen until Replace Ink is displayed. Then press the x Color button. 2. Lift up the scanner 1314127a0e502194c0d970046a123efc.png 3.Wait for the ink cartridge holder to move over, then open its cover.
    4. Identify the cartridge you need to replace. Press in the tab at the back of the cartridge, then lift it straight out. Dispose of it carefully.
    5. Before unwrapping the new cartridge, shake it gently four or five times. Then remove it from its wrapper.
    6. Insert the new cartridge into the holder. Press down firmly until it clicks into place.
    7.
    Close the ink cartridge cover.
    8.
    Lower the scanner.
    The CX6600 begins charging the ink delivery system and “Charging . . .” appears on the LCD screen. Wait for charging to finish before using your CX6600.
    Caution: Never turn off the printer while “Charging . . .” appears on the LCD screen, unless the CX6600 hasn’t moved or made noise for more than 5 minutes.
    Jan 23, 2008 | Epson Stylus CX6600 All-In-One InkJet...
    Changing ink cartridge/s
    The scanner cover is on one set of hinges. Below the scanner bed, you can lift the front edge and the scanner bed will lift up on another set of hinges. Do not attempt to manually position the ink cartridge holder to replace individual cartridges, but follow the instructions from the print dialogue box, under Epson Printer Utility and Epson StatusMonitor.
    Dec 11, 2007 | Epson Stylus CX5800F All-In-One InkJet...
    Epson Stylus CX4800 All-In-One InkJet Printer Logo
    122 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
