posted by NarniaQueen on Oct 09, 2006
I'm having difficulty with my Shark Euro-Pro 373. The bobbin won't thread with the top thread, and the top thread keeps collecting under the bottom of the material. I haven't tried much regarding fixing it since I can't find my manual. I'm not sure if pushing down on the peddle all the way makes a difference or not. Thanks!
Solution #1
posted on Apr 03, 2008
Sounds like the bottom tension is to slack.
Look at the side of your bobbin case, when you thread the bobbin thread part of the route it runs is under a flat leaf spring. There is usually 2 very small scews on this leaf spring one screw holds the spring onto the casing and will be tight. The other is the tension adjuster screw, turn this screw clockwise half a turn at a time. After each half turn pull the bobbin thread until slight resistance is felt. Then try sewing if bunching/tangles still occur more tension is required, this is trial and error until the tension is corrert.
If you want a new manual try this website if your machine is not listed email them and they will try to help.
www.sewusa.com
www.sewusa.com
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Euro-Pro 373 Mechanical Sewing
Email this problem
Email this problem
Can you Help with these Sewing Machines problems?
Euro-Pro 373 Mechanical Sewing Machine
threading instructions for the...
I purchased the above mentioned... Answer This...
how to thread a Euro
how to thread a Euro Pro X... Answer This...
Euro Pro 373om sewing machine
The feed dogs aren't working.... Answer This...
Euro Pro Model 384 Type of...
I don't know what size/kind of... Answer This...
threading my serger
threading my serger
i can't get the upper looper on... Answer This...
Repair Service
Find Sewing Machine Repairman Near You:
