Question about Wasp WCS 3905 Scanners
Laser width is there a way i can change the width of the laser. i am scanning barcodes close together and the laser is to wide. I have another wasp 800 that has a much thinner laser. i want it to be like that one.
How do I narrow the scan beam on the n410
The scan beam is fixed and can not be adjusted. However moving the n410 closer to the bar code will reduce the width of the beam itself. The narrow beam is designed to accommodate static stands as well as manual use.
Simply hold the n410 a few inches away from the bar code and the beam will be able to read the code underneath. No adjustment except the distance between the n410 and the barcode is required.
Nov 24, 2014 | Computers & Internet
Tip
How do I make Barcodes Online?
<p>The best-known lines from the supermarket, bar codes are graphical representations of data that a computer using an optical sensor can read. There are many ways to encrypt data barcodes, such as the width and number of parallel lines or representations of 2D points and squares, which are still being considered as a bar code. Encryption of data in bar code symbols that would be very difficult, but fortunately there are many free tools online for encoding data in barcodes. These online resources are simple and you can print a barcode on a product to sell or an object just for fun. For example, you can use your name in bar code format! <br /> <p>Instructions using Soft Barcode <br /> <p><br /> <p>1. Visit Online Barcode Generator Bar Code Soft. Unlike some barcode generator online, such as the Vespa, the generator you select the file type of the barcode is generated within <br /> <p><br /> <p>2. Choose the desired settings for your bar code, including the width of lines, the symbolism - or Code 128, Code 11, Code 25 and many other options - and the bar width and height. These settings determine to some extent, the size of the barcode will be generated in order to keep in mind that your bar will. An object the size of a skateboard can also be larger than the institutions of an object like a watch, for example. <br /> <p><br /> <p>3. Enter the data you want the generator to encrypt. This information can include letters, numbers and special characters. <br /> <p><br /> <p>4. Please read the disclaimer, you agree to the terms and conditions and press the "Generate". Save the generated barcode by right-clicking on the image and the file name and location to be stored. <br /> <p><br /> <p>Wasp using instructions <br /> <p>1. Wasp Barcode Generator visits the Resources section. <br /> <p><br /> <p>2. Follow the prompts to choose a barcode symbology from the drop-down, data is encrypted and your e-mail. <br /> <p><br /> <p>3. Choose whether you want the barcode to be sent to your e-mail or to generate an image in the window. If the image is sent to your email, you are good, when closing the window on page generator barcode will lose the image file and force it to regenerate. <br /> <p><br /> <p>Instructions for Terry Burton Barcode Generator <br /> <p>1. Visit Terry Burton Barcode Generator in the Resources section. <br /> <p><br /> <p>2. Select the barcode symbology you want the code to generate 128 inches, for example, parallel lines familiar in supermarkets. <br /> <p><br /> <p>3. Clean fill the text "0123456" and enter the data you want the generator to encrypt. Changing the height of the text, if you want the parameter to adjust. The height of the text determines the appearance of text in the generated barcode. Click the "Options Reference" link to read more adjustments, such as ink and fountain. <br /> <p><br /> <p>4. Click the "Make Bar Code" button and wait for the new barcode will be generated. Click on any of the links file, such as BMP or JPEG format, the captured image to download to your computer. <br />
on Jun 26, 2011 | Computers & Internet
My Wasp wws-800 works while in the docking station but not when removed, suspect li-ion battery but have not been able to find a replacement. Any ideas
your wws800 should have come with two batteries. One goes in the reception base and one goes in the scanner itself. You should allow for four to 6 hours to fully charge. When charged, scan the setup barcode on the bottom of the reception base and then the BASE code. This will allow your scanner to create a connection with the base. Give it 5 secs or so, you should hear three beeps.
Jul 20, 2011 | Wasp WWS800 Handheld
Total available char can be scan
The number of characters read is defined in your application and the width of the printed bar code. Also the width of the laser or ccd. One program to develop applications JobGen Plus de Unitech.
Roberto Martinez
Aug 16, 2009 | Unitech PT630 Portable Terminal
Laser beam too short
We can change the scan engine for you if you'd like - it's the only way to solve your issue. You would need a Lorax scan engine (scan up close up to approx 32feet).
Let me know if you'd like more information:
Ian
DC Solutions
ianv@dcsolutionsonline.com
Sep 24, 2008 | Zebra Symbol Technologies MC909X-G Series...
Problem with scanner
Yeah, from the manual, scan the following settings:
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
It's best to copy the necessary barcodes from the manual at 200% zoom, into a Word document and print it out.
Feb 07, 2007 | Wasp WWS800 Handheld
Wasp WCS 3905 Scanners Logo
55 people viewed this question
Top Wasp Office Equipment & Supplies Experts
k24674
Are you a Wasp Office Equipment and Supply Expert? Answer questions, earn points and help others
