Question about O2 Xda IIs Pocket PC
Internal back up battery status: NONE
Hi everyone, few weeks ago I noticed there were still two horizontal battery status in the Main Power Settings Menu of my xda II mini...one for the main battery (which ranges from 100%-fully charged to 5%-almost drained) and one for the backup battery(which is usually 100%-assuming main battery does not completely drain).
today, i just noticed that my internal backup battery status bar was not shown and instead, the word NONE appeared. Does this mean that the internal battery was drained or not detected?is there anyway i could replace this? or it could only mean I have to replace my old battery? please help..thanks ahead
Burn it...
Smack oN the Floor..
It gonna be Oc...
Posted on Nov 06, 2008
I just moved in here 2.5 weeks ago. At first the none of the numeric buttons on the Emerson mw8119sb worked. Then, after punching them for a while, the 6 worked.
First of try to disconnect it, wait for a minute, then re-power it. After internal tests it's supposed to come up with initial settings (like time/date etc.)
May 13, 2015 | Emerson Mw8119sb Microwave Ovens
Right edge fades to black (Approx 2")
ok! you have defective horizontal linearity check horizontal section then check capacitors! like 180uf 200v or 200uf 200v. the problem is defective capacitors!
Sep 28, 2007 | Toshiba 44NHM84 44" TV
I have a HP Pavillion dv6449 that refuses to turn on. it will continually power its self on and then off immediately after. i already checked the power supply. what now?
sounds like it may be an internal component like the main board. if you've already tried another AC adapter, try another fully charged battery. If none works, try to disconnect all components that can be removed like memory, battery, disk drivers and attempt to turn on the system. If this allows it to stay powered on, connect the internal components one by one starting from the memory and see if you can isolate which part may be preventing the system from turning on. Else if no change on status even with the components removed, it would point to the main board. If you can try to reseat the coin-cell battery, you may try it, else, a replacement of the main board or a service repair will be required
Nov 04, 2010 | Computers & Internet
A few weeks ago I noticed that the drivers head light had burned out. I replaced it, but never checked to see if it was fixed. A few nights later I noticed it was just barely burning again. I figured I...
This is a poor ground connection to the bulb or to the unit. Since the main battery + is coming in the bulb glows but it idoes not receive a good negative which has to come from the ground of the car. So have the ground wires taken out , cleaned and fixed back.
Nov 01, 2010 | 2000 Volkswagen Jetta TDI
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
The dc power plugin is not working. I have had the pink acer aspire one mini laptop since christmas 2008. I've never had trouble with it before. Two weeks ago I noticed that sometimes when I plugged in the...
If your power adapter is still putting out the correct voltage when it is plugged into the wall, then you can safely assume that the adapter connection on the motherboard has come loose.
It can be replaced, but it is sort of tricky. You are probably looking at buying a new motherboard.
Oct 12, 2009 | Acer Aspire One AOA150-1504 Netbook
No picture
I disagree with given info, this tv has no horizontal output transistor because it is dlp tv.
3 red light blink means lamp cover is not placed back properly after lamp replacement/ lamp checking. Make sure lamp cover is fixed back in its place securely and tight.
Jul 16, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
My Toshiba Satellie P15-S470 turned off by itself and I can not mak it to run.
Sir:
Is your laptop connected to a power source? If not it needs to be recharged...
Check also the battery of your laptop, it might be dead already... meaning even if it is charging the battery doesn't charge anymore... it may need replacement.
To check the battery... remove it from the laptop and find a flat button to check if the battery is charged, or half charge, or none at all. If below half then the battery needs to be replaced.
Jan 23, 2008 | Toshiba Satellite P15-S470 PC Notebook
Sylvania 6842-PEM Flickering Problem
Something is breaking down. Possibly a specific ceramic capacitor on the main power pcb that has been troublesome. Usually there is just a loud pop and the screen goes dead. If the set is less than a year old it is still on parts warranty and the technician could just change circuit boards until the problem is gone.
Aug 30, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
O2 Xda IIs Pocket PC Logo
552 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
