Question about HP LaserJet 1320 Printer
Paper Jam HP LaserJet 1320
Thanks for the help.
But I had tried a different fuser out of a printer that works fine. And it did the same thing. Do you have any other suggestions?
Thanks, mikeller1982
  • mikeller1982 Nov 07, 2008
    I found out what was wrong.
    The solenoid that engages the pickup roller was bad.
    It was stuck open where that the pickup roller ran all the time.
    Thanks for your help. Mikeller
  • 66 Answers
try to check the maintenance kit of you printer, the possible cause of that are the two main parts of fuser assembly one is the upper roller which is the fixing assembly w/ fuser sleeve try to look at it if it has a silicon paste, if not apply a silicon. the other one is the lower roller which is the pressure roller. check it if you think that it's soo soft rather than the original you need to replace it..
when you done that things your unit is good condition again..
thanks,
rey
Posted on Nov 06, 2008
How do I solve this problem? My hp LJ 4345 printer experiences intermittent paper jam in fuser(accordion-like) with half of the paper out of the fuser. We've replaced the fuser with a new one but the
This error can be caused by the following:
1. Fuser that is close to end of life. Maximum print quantity is 225,000 pages.
2. poor quality paper, very thin paper never feeds well and will jam.
3. Printing an image that is almost entirely black can cause the paper to buckle before entering the fuser.
Try different paper to see if that resolves the problem.
Sep 02, 2014 | HP LaserJet 4345mfp Printer
Plain paper jaming in fuser unit
must be fuser unit, look for these signs :
1- upper roller damaged
2- does not have a "polished " finish
3-lower roller has ripples /waves on it
Apr 08, 2014 | HP LaserJet 1320 Printer
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
After cleared paper jam, HP LaserJet 1320 prints blank pages
Yes you can replace the transfer roller, but check to make sure the roller is firmly seated into its holder and that the springs are contacting the metal shaft.
Good Luck
Nov 20, 2009 | HP LaserJet 1320 Printer
I have a HP LaserJet 1320tn, after I changed the cartridge I keep getting paper jams just about where the paper meets the cartridge
Hi if you says that the paper gets jam at the fuser meeting point than i m sure that registration assembly which register the paper with toner cartridge is not working properly this is internal hardware fault.
It may caused due to faulty pickup assembly too.
There is a small **** manual feed tray try to print using manual feed and check if the problem persists then registration assembly is faulty if the it print fine from manual feed than Tray 2 pickup assembly or pickup roller is faulty.
Jun 29, 2009 | HP LaserJet 1320 Printer
Hp laserjet 1320 folds corner of paper after it prints.
Open the back of the printer - make sure it is clear. Then remove the toner check throughout the printer - reseat the toner and try to print
Jun 18, 2009 | HP LaserJet 1320 Printer
Paper Jam
hi,
maybe your fuser assembly has a problem with fuser sleeves i think it's lack of silicon paste which is causing the jam on your fuser assembly. try to apply a silicon paste if have it but if not you need to drop it on a service center
rey
Nov 04, 2008 | HP LaserJet 1320 Printer
I have 2 1320 printers, with different problems.
http://www.computercarefiles.com/hp_docs/lj_1160_1320/kit_instructions.pdf for step-by-step instructions - the fuser part is 16 pages long. Removal of 15-20 screws, a fan, duplex gears, 6-8 block connectors, and a good hour of my time, now I need to find time to strip the good fuser from the other printer and rebuild this one. Having worked on Laserjet 4s and 5s, which require the removal of 2 (TWO ! !) screws for the fuser, HP have gone right down in my estimation. Don't even start this unless the printer is vital to the situation, or you know for sure the customer will pay the labour charge, or labour is cheap.Good luck.
HP 1320 duplex printing paper jam
Managed to solve this myself: I disassembled the printer and noticed there was a paper jammed in the duplex tray. Rolls were all ok, but the paper blocked the use of the duplex pathway. For disassembly help check the HP 1320 service manual, which you can find on the net as a PDF.
Jul 14, 2008 | HP LaserJet 1320 Printer
HP Laserjet 1320 - Gray bars printing on sides of paper with dark dots
It sounds like a defective toner cartridge. Try replacing it. If that does not cure the problem, then the fuser assembly needs to be replaced, in which case it is probably cheaper to buy a new one.
Good luck
John
Dec 31, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
259 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
