Question about Garden
Hydrostat pump leak,cub cadet garden tractor
My cub cadet is leaking fluid out of both valve assembly on top of the hydrostat pump,,is there any thig that I can do to fix this. This is a cub cadet 1872 super garden tractor. The year is a 1989
  • Anonymous Mar 29, 2014
    series 2500 tractor hdgt 2550 oil light flashing on of constantly just serviced done 51hours.
One... these are pressure relif valves. There are O rings that probably need replacing is all, the valve can go bad but since both are leaking it will probably be just O rings from heat that went bad.
Remove the valves and replace O rings. Use a 'good' pipe thread dope on threads when re-installing.
Two... never use teflon tape on hydralic systems.
Three... boscia is no guro for sure.... lmao
Posted on May 21, 2009
  • 163 Answers
Try tightening the connections. if that doesnt work you can disconnect and wrap the threads with teflon tape but this requires draining the hydro system
Posted on Nov 30, 2008
Cub cadet gtx 1054 cutting grass and the tractor stop running. Will not start
check wires and connectors--check the inline fuse --seat switch -battery look over the wiring possible wire damaged or disconnected
Aug 14, 2016 | Cub Cadet GTX1054 54 in. 27 HP Kohler...
A diagram of the transmission on a cub /zero turn/tank
Michael, The dealer may print the diagram off for you, just try asking them nicely. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Cub Cadet Riding Lawn Garden Zero Turn Tractor transmission diagram Google...
Cub Cadet Riding Lawn Garden Zero Turn Tractor transaxle diagram Google...
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
Jul 02, 2016 | Cub Cadet Riding Lawn Garden Zero Turn...
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling
Because I didn't know they used 2 belts in the diagram on parts . I bought the 79" belt and not the 78" belt.
Aug 22, 2014 | Cub Cadet Garden
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
Hydrostatic Transmission
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
I hope that this can help. Tom
you need to change thr hydr fliud in the transmission and the filter
Cub Cadet IH 382 Hydro
There is a drain plug on bottom of transmission.I believe it had a 9/16 head I know my Cub Cadet required me to remove the seat to make it easier.
Apr 10, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My cub cadet i1042 drive shaft won't engage ... The clutch or coupler is bad ???
hello reut... most of the cub cadets have a hydrostatic transmission. that said, keeping the transmission fluid full is key to good operation. Check the tranny fluid and add as much as you need to bring it to spot on full. joe
May 22, 2011 | Garden
Cub Cadet (105, I believe) hydrostatic transmission problem
you may want to pull the check valves out and make sure the ball arnt stuck if thay are it will do that just lube theme up with some wd40
Apr 20, 2010 | Garden
I have a cub cadet 1250 hydrostat drive. It just
No your trans is getting too hot clean the dirt and grass and fluid off of it and make sure the fan on top has all its blade and is turning with the belt.
Aug 22, 2009 | Garden
Garden Logo
508 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
