Question about Tomtom GO 910
Where is the SD CARD LOCATED AND HOW DO i REMOVE IT.........
Please advise, how do I reset my tomtom go 910. green light stays steady, nothing comes on, very confused.......... where is the reset button located please, how do i reset the tomtom 910, do i need to remove the SD Card, if yes, where is that located and how do i remove that as well....................
Thank You for any help.....................
  • Anonymous Dec 07, 2008
    no green light. Simply will not go on after working well until last night. plug in the charger and the green light goes on, press and nothing. Hit the reset and nothing.
    no green light and will not turn on. Plug it into the charger and green light goes on but will not go on. press the reset botton and nothing happens.
Had exactly the same prob on mine. The reset button is at the back of the unit, underneath the top, above and to the right of the dock connector.
Best way to see it is to hold the tomtom upside down with the screen facing towards you. Find the dock connector (circular connection at one end, with a row of pins to it's right), look above and you'll see a cut out with a pin hole in it.
In the age old tradition, an unfolded paperclip is the weapon of choice here. Place the paperclip in the hole and that's the reset button.
Here's a pic I found on www.tomtomforums.com (posted by Pedro2NR)
Hope this helps, Yours, Paul
Posted on Nov 29, 2008
    Problem Solver:
  • 12 Answers
You do not have to remove the memory card but I would just for the fact that I would be re-seating the card and taking a diagnostic step above and beyond the call of duty.and if something is wrong with card and by coincidence it happened just as you reset the system, I would not be the object of your thoughts as a target to be practiced upon at that time.
You will find the memory card just under the TomTom logo on the front of the unit.
The reset button is a function listed in settings as a tool to Reset TomTom back to factory settings.
This process is referred to as a soft-key.
Daniel
Posted on Nov 15, 2008
TOM TOM 910 TURNS ON BUT IMAGE OF TOM TOM STAYS ONSCREEN WILL NOT TURN OFF
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds .
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Jan 27, 2011 | Tomtom GO 910 GPS Receiver
Problem with my tomtom go 910, was working perfectly until i went on vacation for five weeks. Went to use it and could not switch it on so i thought the battery must be low, so i was going out in the car...
1. Connect the GO to your home charger and charge it for at least two hours. You need to charge your ONE or GO300 for at least 2 hours using the 12-24V cigarette lighter adapter in your car.
2. Check if the green light on your GO lights up when connected to power (RIDER does not have this light).
3. Leave your GO connected to the power cable and RESET it using a straightened paper clip
4. Press the ON/OFF button for at least 3 seconds.
To reset your TomTom device:
1. Charge your device.
Charge your device for at least 2 hours. Make sure the charging light on your device is on (except RIDER which has no charging light).
2. Remove the SD card.
Use a straightened paper clip, or something similar, to push the reset button. For a visual representation of the reset button, see below.
Press and hold the On/Off button for at least 4 full seconds.
5. Insert the SD card.
Always make sure that you are using the latest version of the TomTom application on your device. You can update the application through TomTom HOME. If you use more than one storage card you need to update the application on each card.
Apr 04, 2008 | GPS
It sits in the dock with green light on but wont turn on. TomTom 910.
I'm presuming that it use to turn on,yes? try doing a soft reset by removing it from the dock and turning it over and removing the sd card (if you have one installed), and then, using a straightened paper clip or straight pin, locate the reset hole (about 1" to the left of the sd card slot) and push it for about 15 seconds. Hopefully after that you will be able to turn the unit on. If that doesn't work, you'll have to call tech support.
Jan 28, 2010 | Tomtom GO 910 GPS Receiver
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
Basic screen when turned on...can't do anything else.
You will need to do a soft reset here are the instructions:
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
Oct 16, 2009 | Tomtom GO 910 GPS Receiver
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
Tomtom go 910
take out the docking arm and it it a little hole above the gold chip set in the casing...do not touch the chip with your resetting tool
Nov 05, 2008 | Tomtom GO 910
Tomtom 910
reset button located where the mount goes use paper clip to reset, then connect to computer and download updates
Aug 13, 2008 | Tomtom GO 910 GPS Receiver
Tomtom go 910
I have seen the green screen problem a few times before and this was caused by corrupted data / software or an error in booting up.
If you can't turn any TomTom off then perform a reset by inserting a paper clip into the rest hole and give 1 short press of the reset button ( it's a tactile switch so you should feel it click ) then try switching the TomTom on again the normal way. ( reset buttons are normally found through a small hole underneath the TomTom ).
If the TomTom does switch on but continues as before with the loading up problem , then it's best to format and reload all files from your backup copy.
A RED CROSS indicated a loading fault / corrupted files / incomplete files / corrupted or damaged media . ( media , meaning SD card or hard-drive )
Aug 05, 2008 | Tomtom GO 910
Tomtom GO 910 Logo
475 people viewed this question
Top Tomtom Computers & Internet Experts
Tom Chichester
Moazzem Hossain
Moazzem Hossain
jamie alexander
jamie alexander
Level 1 Expert
Are you a Tomtom Computer and Internet Expert? Answer questions, earn points and help others
