SOURCE: 2001 Hyundai elantra. Headlights, electric
check for any circuit brakers near the fuse box, if theres any of them reset them by introducing a paperclip in the small hole and press, you will hear a click.
SOURCE: 1989 Saab 900 low level fuel light
You don;t say whether the fuel gauge is reading accurately, or whether it's always on empty. If the gauge is always showing empty, it's most likely a problem with the sending unit in the fuel tank. Check the resistance across the two terminals of the sending unit.
On a C900, the fuel sender level unit is separate from the fuel pump
and located on the right side top of the tank, accessible by removing
the trunk floor lift up panel (the pump is located on the left side top
of the tank.
Possible problems are: electrical line off or broken, float not working (it's fairly delicate); or gauge not working.
Test
the resistance of the sending unit with the lines disconnected, the resistance should be
2.6 to 3.8 ohms full tank, 63.3 to 67.5 ohms empty tank; and test for
voltage across the top of the sender unit, if no voltage, that's likely
the problem!
If the gauge is otherwise reading accurately (showing 'full' for a full tank, etc) then the problem is likely a gauge malfunction and can be simply replaced.
Saabreur
SOURCE: heater quit working 2001 Hyundai Elantra. Checked
If the heater is blowing cold air, it could be your thermostat. They cost $20-50 at an auto parts store. Also, after the car has been ran for awhile does it come up and stay at normal operating temperature? Is your coolant level normal? If the car is high in mileage and the cooling system has never beeen flushed, it may just need flushed.
SOURCE: hi i have Hyundai Elantra 2007 its EPS light
Hello... This light indicates that you might have a problem with your Electronic Power Steering (EPS)...
Have a shop check it out...
