Question about HP Officejet 6310 All-In-One InkJet Printer
Setting the time
How do I set the correct time?
  • 7 Answers
On my 6310 all in one printer ------> Hit "Setup" key (with the question mark next to it >> Select Tools (menu item 6) with OK button >> Date and Time (menu item 3) with OK button.
Then set the date and time using the keypad on the printer and the ok button. Either the arrow keys or the setup button move through the various menu options.
Posted on Jan 30, 2010
    Genius:
  • 1,124 Answers
On the printer ------->> Hit menu button >> Select Basic Fax Setup >> Date and Time
And configure your time there.
Posted on Nov 05, 2008
SOURCE:
How do i set the date?
Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting:
Date & Time: Press the Mode button. The Hour will start blinking. Press the Setting button
until the correct hour is displayed. Press Select to set the hour shown.
The Minutes will blink. Press Setting until the correct minutes are displayed. Press Select
to set the minutes shown.
The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select.
The Year will blink. Press the Setting button until the desired year is shown. Press Select
to set the year shown.
The Month will blink. Press Setting until the correct month is shown. Press Select to set
the month shown.
The Day blinks. Press Setting until the correct day is shown. Press Select to set the day
shown.
Print Method: Press the Mode button until P5 (Program Mode 5 for Print Format) is displayed.
Press Setting to choose one of the following Print Methods.
The TC100 has two settings for print activation: Manual or Automatic
1 = Automatic (default setting) - The TC100 automatically prints when the time
card is inserted.
2 = Manual - After inserting the time card, press the Print Button to activate
printing.
Press Select to confirm the Print Method chosen. Press Mode to return to normal operational. hope this Help : - )
Dec 11, 2011 | The Times ROYAL TC100 TimeMaster Time...
I need a manual for the royal tc 100 time clock
the month shown.
shown.
card is inserted.
printing.
Press Select to confirm the Print Method chosen. Press Mode to return to normal operational. hope this work for you best regards happy holidays : - )
Nov 08, 2011 | The Times ROYAL TC100 TimeMaster Time...
How do set the time and date on machine
Press and hold CLOCK until the message window displays C, and the default day is announced.
To change the day setting, press MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
Press CLOCK. The current hour setting is announced. The correct day setting is saved.
To change the hour setting, press MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
To change the minute setting, press MEMO/REPEAT or ANNC/SKIP until the correct minute is announced.
Press CLOCK. The current year setting is announced. The correct minute setting is saved.
To change the year setting, press MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
Press CLOCK. The new day, time and year are saved. The correct year setting is saved.
To check the clock, press CLOCK.
The above is from page 5 of the manual at
http://att.vtp-media.com/ecp/documents/product_Product/223/UserManual/944/1739_manual.pt2_i6.pdf
Jun 21, 2011 | AT&T ATT1739 Digital Answering Machine
Royal Time Master TC100 Time Clock - power went out How do I reset the date, day and time?
the month hope this help : - )
Jun 09, 2011 | The Times ROYAL TC100 TimeMaster Time...
How to set the date
1. Open the front cover to show the programming buttons:
Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting: Date & Time: Press the Mode button. The Hour will start blinking. Press the Setting button until the correct hour is displayed. Press Select to set the hour shown. The Minutes will blink. Press Setting until the correct minutes are displayed. Press Select to set the minutes shown. The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select. The Year will blink. Press the Setting button until the desired year is shown. Press Select to set the year shown. The Month will blink. Press Setting until the correct month is shown. Press Select to set the month shown. The Day blinks. Press Setting until the correct day is shown. Press Select to set the day shown
If you need additional instructions the manual can be found here: TC100 Manual
Hope this helps, Myridom
Mar 04, 2011 | The Times ROYAL TC100 TimeMaster Time...
How to change the date
the month shown.
shown.
card is inserted.
printing.
Dec 20, 2010 | The Times ROYAL TC100 TimeMaster Time...
Will not print date 11-19 sample
the month shown.
shown.
card is inserted.
printing.
Nov 19, 2009 | The Times ROYAL TC100 TimeMaster Time...
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
Jan 08, 2009 | AT&T 1717 Digital Answering Machine
How to set date on time clock tc 100 royal master
Date & Time
the month shown.
shown.
Oct 13, 2008 | Computers & Internet
When I go to messages, it says the time and then says "POWER FAILURE."
Set the Clock
You must set the clock once so that the
with your messages. After this, if you
subscribe to Caller ID, the system will
automatically reset the clock each time new
Press Pto exit at any time while
setting the clock.
1 Press and hold Cuntil the Message
Window displays C, and the default day
is announced.
2 To change the day setting, press and
release ror auntil
3 Press and release C. The current
4 To change the hour setting, press and
release ror auntil
5 Press and release C. The current
minutes setting is announced.
6 To change the minutes setting, press and
release ror auntil
the correct minutes setting is announced.
7 Press and release C. The current
year is announced.
8 To change the year setting, press and
release ror auntil
9 Press and release C. The new day,
time, and year are announced.
To check the clock, press and release
C.
Nov 14, 2007 | AT&T 1738 Digital Answering Machine
HP Officejet 6310 All-In-One InkJet Printer Logo
237 people viewed this question
Clive
Clive
Thomas F. Schneider
