Question about HP Office Equipment & Supplies
HP D145 need new print head (magenta) - HP Office Equipment & Supplies
    Scholar:
  • 137 Answers
You can purchase a magenta printhead from HP's site here. Before you do that make sure it is the printhead - this model uses separate ink and printheads. Are you receiving an error message that the printhead is defective?
regards,
Bob Headrick, MS MVP Printing/Imaging
Posted on Nov 05, 2008
3 Suggested Answers
SOURCE: HP Officejet d145 print head problem
Did you replace the PRINTHEAD, or did you replace the INK CARTRIDGE? They are not the same on the D145.
Good chance that you may have replaced the ink cartridge, not the magenta PRINTHEAD which sits under the ink cartridge.
PS - in my experience, non-HP ink cartridges clog up HP printers with separate printhead mechanisms... any possibility here?
Posted on Aug 12, 2008
  • 1218 Answers
SOURCE: Loaded print brand new black/yellow and
This issues looking printer head problem. check the following Steps for cleaning printer head :
  • Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
  • Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
  • Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
  • Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
  • Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
  • Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Posted on Oct 12, 2010
HP all in one won't print - magenta ink level shows a ? Magenta level was low -maybe ran out I installed new hp magenta cartridge, but I don't remember taking any tape off it. Do I need a different...
Is it a genuine HP cartridge.
refilled one will show ?
Some model will not print if it thinks there is no ink.
There are reset devices for refill ink cartridges. cost very little of ebay etc.
Feb 05, 2011 | HP Office Equipment & Supplies
My printer is not printing magenta. I have changed the cartridge (hp one), cleaned the print heads and
The magenta print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked magenta print nozzles. Also check the magenta cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 13, 2010 | Computers & Internet
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
No I see no solution noted here. again Photosmart D7360 error message 0xc18a0001 ink system failure.
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Also this may help...
HP 145 Sequence HP D145 all-in-one printer
http://magicinkjetflush.com/images/PDF/HP_135_Sequence.pdf
or smaller file
http://magicinkjetflush.com/images/HP_135_Sequence.jpg
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | HP Photosmart D7360 All-In-One InkJet...
Can not get printer to print keeps saying that it is idle in the que
Hi Pull the power cable. And leave out for 1 minute it should reset to default factory settings.
However, if like most... and yourprinter has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Magic is ideal for unclogging the tiny jets on any Canon,Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to usethe MagicInkjet Flush kit to soak the print head and you should beprinting again like new.
or smaller file
Good Luck!
Tinteiros (Ebay)
Oct 30, 2009 | HP Photosmart D7460 Printer
HP Photosmart C6180 Magenta Inks Not Printing
However, if like most... and yourprinter has just been left unused for some time? You probably have an ink clog on magenta.
Magic is ideal for unclogging the tiny jets on any Canon,Epson HP and removing those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the MagicInkjet Flush kit to soak the print head and you should be printing again like new.
or smaller file
Good Luck!
John P Bradley
Tinteiros (Ebay)
Oct 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
I replaced all my printheads. Also Both the black
call the manufacture or tech support. Maybe there is a printhead reset on the printer??
Sep 26, 2009 | HP OfficeJet d145 InkJet Printer
Jul 26, 2008 | HP OfficeJet d145 InkJet Printer
Cleaning printer head
Usually found on a maintenance tab in the printer's properties.
Jan 11, 2008 | HP OfficeJet d145 InkJet Printer
81 people viewed this question
Seeker5211
Seeker5211
