Error codes elba washing machine - Washing Machines
4 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: I need a user manual
Hi and welcome to FixYa, I am Kelly
I am having difficulty with your model number cross reference. Is your washer ELB xxxxx. These Elba series washers are sold exclusively to Sears and you can get the manual from Sears.
Here a direct link to the US top loading model manual:
http://www.elbaappliances.com/admin/pdfs/pdf_usecares/4157_Sears_Washer_UG.pdf
Here is a direct link to the AU / NZ Front loading model:
http://www.fisherpaykel.com//admin/pdfs//pdf_usecares/4417_AUS_NZ_SGP_Frontloader_Washer_UG2_LRES.pdf
Here is a direct link to the AU / NZ top loading model:
http://www.fisherpaykel.com//admin/pdfs//pdf_usecares/790718A_AUS_6kg_7kg_8kg_Washer_UC.pdf
Thanks for choosing FixYa,
Kelly
Posted on Feb 19, 2011
richroth
  • 9472 Answers
SOURCE: we bought a ELBA wash
Sounds like a problem with the door switch. What is your model number of your unit?
Posted on Aug 18, 2011
ginko
  • 19396 Answers
SOURCE: How do I adjust the
Hi.
Unfortunately the service documentation for Elba is not available. Although the machine has been built by F&P and although is similar to a Fisher & Paykel Smartdrive there are some small difference. The clutch system may be similar to the smartdrive. I have uploaded the service manuals for two smart drive models below, see if that can help. Check section about disassembly.
F&P top load smartdrive smI.zip
Regards.
Ginko
Posted on Sep 06, 2011
My Elba washing machine, when reaches the rinse cycle, water is very loud, never before, but it never stops adding water. Water is draining fine but water does not stop to cycle to rinse.
The water inlet solenoid valve is being held open. Take off the hose and look in the opening to see if you can find anything. Otherwise replace that solenoid valve.
Sep 02, 2016 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Elba washing maching wa65tm stops at rinse
have u got a rinse hold switched on.this is to keep clothes from getting creases it holds until someone tells it to complete cyle
Nov 20, 2015 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Elba washing machine wont drain or spin
The pump filter is blocked ,so it wont empty,remove filter cap and clear out lint, coins etc.
Jan 03, 2014 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Wa50t54w1 elba
this can be a motor control fault, and sometimes a fault with the motor itself, test motor windings for equal resistance, and check motor physically for wear / damage. replace motor controller.
Oct 24, 2013 | Fisher and Paykel IWL12 Top Load Washer
Elba washer is not washing or spinning right...the only thing its doing is adding water
I couldn't tell if the water was draining. When you advance the cycle to spin the first thing it should do is drain the water. This will happen for a short time before it spins. If it is not draining then you need to check the drain pump for blockages( and pipes) the machine will not spin with water in it! If it is draining but not spinning then it is probably a faulty lid switch and needs replacing. There are a couple of other causes but they will usually create a fault code which you don't seem to have. Most likely blocked or faulty drain pump.
Jul 05, 2013 | Washing Machines
Error code 3
Error code 3
Your motor controller module is faulty.
Has a memory error & needs replacing.
Jan 26, 2013 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
How do I adjust the clutch on an ELBA Model WA50T54W1 top loader washing machine ?
Hi.
Regards.
Ginko
Sep 05, 2011 | Washing Machines
Washing Machines Logo
969 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
