Question about Tomtom GO 910
Tomtom go 910
Please tell me where the reset button is located on the tomtom go 910.
I only see the green light on, and after pressing the on/off button for two seconds, nothing. would appreciate your help........................
Take out the docking arm and it it a little hole above the gold chip set in the casing...do not touch the chip with your resetting tool
Posted on Nov 08, 2008
Tomtom 910 power problem
It is very small - a pinhole. Use a paperclip to press the button which is sunk inside the small hole.
Jun 27, 2009 | Tomtom GO 910
Tomtom 730 doesn't switch on!
Hopefully all you need to do is a soft reset. To do this use a streightened paper clip and insert it into the small round hole marked reset on the bottom of your tt. Gently press the reset button in until you feel a click. Hold the reset button in for 20 seconds. Hope this does the job.
Jun 07, 2009 | Tomtom GO 910
Power to same, but not turning on, can't locate so-called
look at the base of your unit with the screen facing away from you, just in front off the rubber bung is flat piece of plastic with a tiny curved out cection on the left hand side, below there is a tiny hole just big enough to poke a pin in their.
May 30, 2009 | Tomtom GO 910
try lower right hand corner of screen
should reboot will ask you if you want reboot
Power to same, but not turning on, can't locate so-called "reset" button on bottom????
Looking at the docking area note the gold connection terminals and which end the round coaxial connector is at. You should also be able to see the green circuit board that the terminals are mounted to. Then next to that you'll see a section of the plastic casing that has a little rubber piece in it. At the end of that part of the case opposite the coaxial connector mentioned earlier you should see a small notch in the plastic. That is the reset button. With the unit on use a regular size paper clip and gently press it in and you unit should reboot.
May 26, 2009 | Tomtom GO 910
Where is the SD CARD LOCATED AND HOW DO i REMOVE IT.........
Had exactly the same prob on mine. The reset button is at the back of the unit, underneath the top, above and to the right of the dock connector.
Best way to see it is to hold the tomtom upside down with the screen facing towards you. Find the dock connector (circular connection at one end, with a row of pins to it's right), look above and you'll see a cut out with a pin hole in it.
In the age old tradition, an unfolded paperclip is the weapon of choice here. Place the paperclip in the hole and that's the reset button.
Here's a pic I found on www.tomtomforums.com (posted by Pedro2NR)
Hope this helps, Yours, Paul
Nov 05, 2008 | Tomtom GO 910
My tomtom go 910 will not switch on it has the green light on at the top left when plugged into a charger but nothing turns on when pressing button for 2 seconds any ideas??
In general I find these sort of problems can be fixed by the below
If the Tomtom loses battery power it might cease to function with a blank screen but will show a green light when you charge it. The trick is charge it on the mains charger for at least two hours. Then reset the device with a paper clip. If you get no reponse hold down the on button for at least 20 secs and the device will show the Tomtom logo and play a drum roll and startup normally.
Sep 03, 2008 | Tomtom GO 910
Tomtom go 910
I have seen the green screen problem a few times before and this was caused by corrupted data / software or an error in booting up.
If you can't turn any TomTom off then perform a reset by inserting a paper clip into the rest hole and give 1 short press of the reset button ( it's a tactile switch so you should feel it click ) then try switching the TomTom on again the normal way. ( reset buttons are normally found through a small hole underneath the TomTom ).
If the TomTom does switch on but continues as before with the loading up problem , then it's best to format and reload all files from your backup copy.
A RED CROSS indicated a loading fault / corrupted files / incomplete files / corrupted or damaged media . ( media , meaning SD card or hard-drive )
Aug 05, 2008 | Tomtom GO 910
Tom Tom shows green light but won't power on
HAVE YOU TRIED THE RESET BUTTON? IF SO PRESS THE RESET BUTTON THIS SHOULD RESET THE ERROR WITH IT
Jan 23, 2008 | Tomtom GO 910
Back light of the LCD display is not working
Get a RMA by TomTom by callinging them directly (see on TomToms webpage) I've solved by shipping my unit to Neaderland with UPS at no cost, they replaced the motherboard (not the display, this  just remained the same!) I've received the repaired 910 after 5 days and I've spent no one cent! And I've got also the battery, AC power supply and software replacement! Other problems of the software are still present: the unit won't cange colors by night-light changes (only one time after a reset...), tryes to connect to phantom computers, after a power on it get off and then on if connected on the car support,... The 910 is a crazy device, not stable at all. I think I'll change it with the new model Go930T Ciao (sorry for my bat english)
Oct 23, 2007 | Tomtom GO 910
Tomtom GO 910 Logo
165 people viewed this question
Top Tomtom Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Tomtom Computer and Internet Expert? Answer questions, earn points and help others
