Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Washer spin cylcle leaves clothes wet
Hi, after the spin cycle is complete, my clothes are still wet, and sometimes there is some water left inside. The other cycles work fine. Any idea what the problem may be?
  • 4 more comments
  • Anonymous Mar 12, 2014
    I have to slamm the door to spin and sometimes clothes are still wet
  • Anonymous Mar 15, 2014
    The drum does not seem to be spinning, clothes come out dripping wet and must be rung out by hand. I even place three folded shirts and let them run in a rinse and spin cycle and they did not appear to move. The drum does turn freely by hand. Do not hear any noises and the washer seems to stay on 8 mins left on timer.
  • Anonymous Mar 20, 2014
    clothes still wet after cycle completes
  • Anonymous Mar 22, 2014
    Since buying this, some clothes don't get totally wet in the wash and there is always lint left on the dark clothes and I have to rinse them by hand. Can't rinse in hot water either! Suggestions?
  • Anonymous Mar 23, 2014
    WILL SPIN AND DRAIN BUT LEAVES CLOTHES WET
    after complete cycle clothes are still wet
Mine did the same thing. Solution. I took it back to the store where I got it. Fortunate for me they gave me my money back. Now I am looking for another one. What a nightmare. There is nothing that has a consistently good recommendation except Miele. Where I live they are not available. Well!! We could always go back to the scrub board. je
Posted on Sep 13, 2007
I Think you need a new drive belt. I'm having the same problem.
Posted on Apr 23, 2007
Washer is completing all cycles, but water from wash cycle.is left.in washer and clothes are still soaking wet. No water drains out.
check the Lid safety switch, if its shorted the spin cycle won't work, so your left with wet clothes ,, you can jumper the 2 wires together to test the switch , if that makes the cycle work, Replace that switch
Jul 06, 2011 | Washing Machines
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Will not totally spin
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 16, 2010 | Whirlpool LSR5132PQ Top Load Washer
Clothes are not completely rinsed (they're soaking wet) at very end of spin cycle.
Try to fill minimum water level in your machine with out adding detergent or clothes and complete cycle and see if it is any watter inside. Could be a water pump.
Dec 29, 2009 | Roper RAX7244KQ Top Load Washer
Only spins slow
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
May 06, 2009 | Washing Machines
Wet clothes after spin cycle
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 05, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Spin cycle leaves clothes very wet
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Feb 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Clothes still too wet after complete cycle
I would suggest that the filter wants cleaning.
To access it, remover lower rear panel of washer.
Locate and remove the large black hose on to the tub.
Be careful, as there will be water in the hose.
Remove and clean plastic filter inside hose.
Refit hose and filter..
I would also suggest that you remove motor and check the brushes for wear, whilst you have the rear panel off.
If there is less than 10mm showing, then they need replacing..
Please leave a rating for my fixya solution.
Thanks.
Feb 07, 2009 | Hotpoint WMA54 Front Load Washer
Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Nov 09, 2007 | Admiral AAV7000A
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
390 people viewed this question
Sal De
Marvin
Marvin
jimorris77
