Question about Sanyo DVW-6000 DVD Player/VCR
DVD loader mechanism
When I put a dvd in and hit the close button it keeps spitting the dvd door open. Its like the little slider that has the red light on it that recognizes that a dvd is loaded is not back far enough so that the red sensor can detect the dvd. I opened the unit and it seems like the little slider with the red sensor on it does not slide all the way back after the dvd door is opened. If you push it all the way back and close the dvd door, it loads, the red sensor comes on and the dvd door stays shut and the dvd will start playing. If I eject the dvd and the door opens, the slider only goes part of the way back. If I close the dvd now, it spits the door back open. If I push the slider all the way back again then close the door the red sensor comes on and the dvd starts to spin and play. Does anyone know what part I can order to get the slider thing to go all the way back so when the dvd door is shut the sensor can detect the dvd? or what I can do so that the slider goes all the way back on its own?
  • wefb76 Jul 07, 2008
    the door keeps coming open, it won't stay closed so the dvd will play
    President:
  • 3,130 Answers
It is called the slider assy. The slider moves the laser assy back to home or start position. It is a small belt underneath or there is gunk or hair in the gear mechanism. A very common problem with CD/DVD players/recorders. Very good though that you saw it was not comming back to home place. I wish I had a manual to assist you but I do not. Im telling you the most common problems with the slider mechanism. Good Lck
Posted on Oct 09, 2006
Cannot close dvd door
The disc loader mechanism has the fault. Replace it.
May 21, 2012 | Televison & Video
Purchased the DP300 at the Goodwill. The DVD has the remote control;however, I do not know how to use the remote control. I used the red, yellow, and white connector to my the DVD player and to the TV but...
with regard to using the remote control :
Make sure the batteries in the remote are working (they go in the back of the remote at the bottom).
Turn on the DVD player with the power button on the DP300 itself (lower left). Open the dvd tray either with the remote (press open/close button, upper right) or with the button on the DP300. Put a DVD in the tray and close it with the remote or the button on the DP300. The DVD should load.
Use the arrow buttons in the centre of the remote to select choices from the onscreen menu of the DVD. Press Play (centre of the 4 arrow buttons) to activate the choice you want. For example, if you want to play a movie, use the arrow buttons to go up or down until "play movie" is selected, then hit PLAY, and movie will play. If you want to choose a scene/chapter of the movie, use arrow buttons to go up or down until Scene Selection or Chapter is selected (highlighted), and press PLAY. This should bring up a list of the scenes or chapters. Use the arrow buttons to select the one you want, then hit PLAY, and that scene should play.
If the DVD tray is taking less than 20 seconds to operate, there is likely no problem. If it is taking more, there may be. I think the mechanism that opens and closes the tray is often the first thing to stop working on DVD and CD players.
Jul 20, 2011 | Norcent Technologies DP300 DVD Player
I have hitachi dz-mv780e and its door opens by itself whenever I turn it on ! or put dvd in it ! I just cant close the door ! access/pc red light keeps on lightin any help plz ?
There is a faulty loading setting in the mechanism and so when the power is switched the motor moves to eject and do not come to the PARK/REST position.
So you will need to open the camcorder to reset the mechanism. check inside of the tray for any objects that have fallen into and blocked the drives. Keeping the door open tap on the body to release any objects.
Jul 13, 2011 | Hitachi DZ-MV780E DVD Camcorder
Door keeps opening on our Go video dvd player. we put the dvd in hit close it cloes says loading then opens
try to pull the dvd tray little bit before you close it. Hope this info resolve your Go-Video problem.
Mar 13, 2011 | GoVideo DV2150 DVD VCR
The recoerder is off and i am stuck on dvd 1 and cant get it to switch back to dvd 3 even if i hold the enter and 3 button down
Hi scooty69,
First you do is to unplug the cord of your DVD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the
DVD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the DVD unit and unplug the unit again to avoid electric shock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the DVD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn't return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope it may help you;
Regards;
VOTIT
Jan 29, 2011 | Sony RDR-VX560 DVD Recorder/VCR
The DVD loader will not open. The DVD player has never been used.
There seem to be a prolem with the mechanism that opens and closes the player.
Probably the player hit something really hard.
To fix this, all you have to do is to get the appropriate screwdriver, unscrew the cover of the player, take a close look at the mechanism that controls the disc tray and you will discover the fault.
Adjust the rubber and sit the tray properly, if you see any damage on the mechanism, all you have to do is change the mechanism.
Try to open it before you cover it back.
Take care
Jun 15, 2010 | RJ Tech RJ-800DVX DVD Player
On my LG RH387H dvd hard drive the dvd tray won't open fully and now it has started to open on power up and when i try to close it it keeps opening even though there is no dvd inside
mechanical timing and allignment is the prtoblem of your dvd player...you need to open the cover of the dvd player..take out the dvd mechanical loading system try to eject it manually by turning the gear with your hand..make sure that the cd loader reaches the limit switch before it closes..
May 18, 2010 | Televison & Video
Tray won't open and if you hit the button enough the light comes on thats it.
This DVD drive has a small processor in it. The button sends a signal to the processor to open the door. The processor then turns the light on and the door is supposed to open.
This unit is broken and needs to go to a shop as the IC that opens the door is probably bad.
Try this: get a paper clip and find the small hole in the door. This will manually open the door. Then use the button to close it. It could also be a mechanical failure..
Apr 04, 2010 | Lite On SHD-16P1S Internal DVD Drive
Dvd slider door won't close.
Hi, is it fully open, or just partially open?
Is it nearly shut but just jammed? If so have you tried inserting a flat peice of plastic and pulling the draw open. You could do this with no power to the dvd player, It might be that you haven't inserted the disc properly and it is wedged in.
Try all this and see how you get on.
Regards - Anthony
Feb 14, 2010 | Memorex Televison & Video
Bose 321 dvd tray stuck
First you do is to unplug the cord of your DVD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the DVD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the DVD unit and unplug the unit again to avoid electricshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the DVD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope it may help you; Regards; VOTIT DONT FORGET TO RATE;
Jun 08, 2009 | Bose (321GS) System
Sanyo DVW-6000 DVD Player/VCR Logo
389 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
