Question about Avaya 700340193 Corded Phone
Merlin phone system
I have 20 ext lines and they do not light up when that ext is in use. what can I do to fix this
Well, what system do you have? You indicate a "Merlin" phone system, but have posted this under a "Partner" phone forum.
What system do you have?
Posted on Nov 18, 2008
How many lines does the at&t bis-10 phone have?
It depends on how the control unit is programmed. The BIS 10 can't be used as a stand-alone phone (as can't connect it directly to a telephone line).
The BIS 10 will work with the following systems:
AT&T Merlin 206
AT&T Merlin 410
AT&T Merlin 820
AT&T Merlin 820D2
AT&T Merlin 1030
AT&T Merlin 3070
AT&T Merlin II (with the proper modules installed)
AT&T Merlin Legend (with the proper modules installed)
Jan 27, 2011 | AT&T Merlin BIS 10 Phone
Will the AT&T Merlin BIS 10 Phone work on my home phone line? I work from home and love this phone, but need to know if it will work with a regular phone cord to the jack. Thanks!
The BIS 10 and related telephone units need to be connected to one of the following AT&T Merlin telephone systems:
AT&T Merlin 206
AT&T Merlin 410
AT&T Merlin 820
AT&T Merlin 820D2
AT&T Merlin 1030
AT&T Merlin 3070
AT&T Merlin II (With the proper modules installed)
AT&T Merlin Legend (With the proper modules installed)
Oct 20, 2010 | AT&T Merlin BIS 10 Phone
Phone rings only once then is silent. How do we
This is a symptom of a feature that has been activated. It could be the call is forwarded, it could be the voice mail is programmed to pick up on the 1st ring. On some systems ext's can be programmed to ring elsewhere after a set number of rings. The do not disturbe feature could be activated. If it is an outside line, call it from your cell and see what you get (voice mail-continious ring-another ext etc.) Find out if it does it on an in houes intercom call. Look for a DND button the it lit up? Does the display show calls forwarded or DND? Hope this helps. Good luck.
Mar 24, 2010 | Lucent Merlin Legend MLX-20L Phone
My church has an older AT&T Merlin 5 button 8 pin 2 line phone syatem with 4 phones. Need to upgrade the equipment with modern feathers but need to stay with the 8 pin wiring. Can you recommend new...
The Avaya Partner line was one of the branches that AT&T took in phasing out the merlin system. It's been out for at least 20 years and is now up to the ACS with a version number of 8.0 (its not going away anytime soon).Although it doesn't use all 8 pair to activate a set (it uses 4) it still uses an 8 conductor interface on the cards so changing over to it should be fairly simple.
Feb 12, 2010 | AT&T Merlin BIS 10 Phone
Divice goes to intercom not a outside line
just dial 9.
If this is more of an issue of auto line select, we need to know the model of the phone system. Merlin 820? 410? 1030? 3070?
Sep 29, 2009 | Avaya AT&T Merlin Basic Telephone & Modem...
Lines 1 & 3 won't break dialtone on Merlin 410
Unfortunately no. The merlin 410 was an early phone system that didn't have much in the way of programming.
Sep 10, 2009 | AT&T Merlin BIS 10 Phone
This will be an easy fix. It is your night AA selector code. Did you resolve this?
Apr 07, 2009 | AT&T Lucent Merlin SP 34 Phone
Intercom doesn't make beeping sound only flashes Merlin phone sy
Depending on the type of merlin system you have, you should be able to turn the ringers on by moving the switch on the left side of the phone marked T . P to the "p" position. All the lights should light and the set should ring every couple of seconds. Press the line you want to ring and enter *37, repeat for all lines you want to ring. If you want all lines to ring , press any line button and enter *347, slide the T . P switch back to the center "." position.
Hope that helps
Mar 27, 2009 | Inter-Tel Axxess Corded Phone
New guy with a project ( lucent MLX-10D)
On the Merlin Mail system the password is usually either the same as the extension or 779. Let me know.
Jan 15, 2009 | Lucent Merlin Legend MLX-10D Phone
Incoming calls to office cause all phones to ring in classrooms
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Hope that helps
Dec 02, 2008 | Lucent PARTNER18 Corded Phone
Avaya 700340193 Corded Phone Logo
64 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
