Question about Dishwashers
I have a Diplomat ADP 8520 dishwasher (possibly SMEG manufacture) which will not stop trying to empty. There are 4 leds lit reading left to right and it beeps. I have read on some forums about pressing the programme button 4 times or holding it down for ten seconds to clear the fault but neither of these solutions work. I thought maybe that the drain was blocked but I put the pipe directly into the sink and it empties ok, problem is, it does not stop.
    President:
  • 1,462 Answers
Fault is probably water in the bottom tray operating the anti-flood device. take bottom front panel off and mop out the water and it will work. if fault reoccurs then you have a leak
Posted on Nov 05, 2008
Why does my Diplomat ADP 8902 dishwasher beep twice when i switch it on and the 4th wash program light flash and do nothing else?
Can I say thank you for the above advice. Hit the programme button 4 times and closed machine. Now running rinse cycle. Let hope it works afterwards. Will post ant let you know.
Nov 20, 2010 | Dishwashers
I have a Diplomat Fully integrated dishwasher model ADP 8242 when put on any program it fills and seems to be washing then stops after 5 minutes and the dispenser door has not opened. There is a lot of...
Check the small drain pump. Possibly its asking the pump do drain to allow for fresh water, but because low level is not detected it shuts down. The dispenser draw normall opens when the hot wash cycle starts.When you think its washing,briefly open door and see if eater is spraying out of the nozzels.If no water visible, check the main wash motor for sticking
Sep 24, 2009 | Dishwashers
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
Diplomat adp 8242 beeps twice one flashing light not working. turn off leave for hours then might work.
Turn off plack power button, turn back on, then press cycle selection button 4 times very quickly. flashing lights should change, shut machine and it should fire up and work...... it worked for me. May have to try it several times as getting the 4 button press timed right can be a bit tricky.
Jul 13, 2009 | Dishwashers
My dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Dec 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Diplomat adp 8520 dishwasher no hot water
two things to check
check continuity thru heater
remove outer door panel and check for faults in wiring loom
get back to me is these are both ok
Nov 14, 2008 | Dishwashers
I need a detailed diagram for the timer control unit for a diplomat adp 820 dishwasher
there is no manual or circuit diagram online
you will have to contact the company for the service manual or the wiring diagram
Aug 28, 2008 | Dishwashers
Diplomat Dishwasher Model ADP 8132
Please can you give me the dimentions of this Dishwasher Diplomat Model ADP 8132, as I have got to get a replacement and have been told that the Hotpoint FDL570X is the replacement offered,Many Thanks,
Mar 28, 2008 | Dishwashers
Diplomat dishwasher adp 8322
i had same problem and have found that under the lower basket the connecting bar to the spray arm had become detached this can be reattached by inserting the two nozzles back into position and pushing down youll see what i mean ! however i have found i now have to do this after every wash ,am currently onto diplomat to rectify this completely , hope this is any use.
Mar 09, 2008 | Dishwashers
Dishwashers Logo
266 people viewed this question
Top Dishwashers Experts
