Question about JVC AV-48P575 48" Rear Projection HDTV-Ready Television
JVC Problem We have a bunch of lines all over the screen. It looks like the red is all messed up. I have a pic but I can't find a place to poast it.
  • Nigel Bentley Oct 09, 2006
    no they are only red lines. Here is a pic
  • NENENENANO59 Aug 22, 2008
    MY SCREEN IS BASICLY THE SAME.I WAS WATCHING THE OLYMPICS ON MY HD CHANNELS AND SWITCHING BACK AND FORTH FROM HD TO REG CHANNELS AND THEN IT HAPPENED!THE IMAGE WENT BERZERK AND I WENT TO THE CONVERGENCE OPTION. THE BLUE CAN GO UP & DOWN BUT THE RED ONLY GOES SIDEWAYS.THATS WHAT I NEED TO FX THE MOST, CAUSE THOSE LINES SEEM TO BE THE ONES OUT OF WHACK. THANKS!
    President:
  • 3,130 Answers
If they are green, red and blue lines, you have a typical convergence problem that happens in almost every rear tube projection set ever made. There are two IC's that need replacing to correct your problem. If you do not know how to solder, unsolder, work on solid state electronics, you really should call out an experienced tech to assist you in this repair. These sets now a days have no user replaceable parts inside of them. A TV set as this one, should not be a place to experiment around inside of. Good Luck
Posted on Oct 09, 2006
Got the TV 4 free so lets start at that. Was a very poor picture so checked the guns saw the green/blue was very foggy and changed the CRT Fluid in Green and blue red obviously was fine. Now tv up and...
are the lines slightly curved and go from the botom to top across the screen. If so it sounds like retrace lines from the CRTs being turned up too far. You can add the pic by clicking the camera Icon next to where it says Insert below the text box.
Nov 03, 2011 | Philips 50P8341 50" Rear Projection...
JVC AV-56WP74 56 in. Rear Projection red projector is not showing images and big red line in tv
If the red line looks like a swoosh of red across the screen it may be the convergence Ic having an issue.
Jul 04, 2011 | JVC AV-56WP74 56" Rear Projection...
JVC I'Art Pro the color's don't line up in the corners its like the red has a concave shape so there is a perfect picture in the middle but the corners are off, anyway what i need to know is how i can...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 23, 2011 | JVC AV-56WP30 56" Rear Projection...
There is double vision at times, then it goes away.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking pic
*White looking pic
*Halos around objects
*Red/Orange looking pic
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 07, 2010 | Televison & Video
When taking pic in sunlight - lcd screen is whited out!!
I think that's normal. I also have experienced the same always when the screen is exposed to sunlight. Try adjusting its brightness or use an anti-glare protection.
May 26, 2009 | Olympus FE-20 Digital Camera
Red bowed horizontal lines
Projection sets have two very common problems outlined below.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*Dull looking picture
*White looking picture
*Red/Orange looking picture
bb0cf99.pngSOLUTION
May 17, 2009 | Hitachi 43GX01B 43" Rear Projection...
MITS WS-65869 The green CRT is creating a warped image.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 13, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Red lines won't line up
The problem is your convergence IC's. They can be found behind the front speaker grille. The will part number STK392-110. You may see a burnt resistor beside then also. If not experienced, it may be best to have a qualified tech look at it. Please take the time to rate this solution and if I can be of further assistance let me know
Dec 13, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48P575 48" Rear Projection HDTV-Ready Television Logo
96 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
