Question about Poulan Pro Chain Saw 46cc 20"
Poulan Super 1800 16" chainsaw .
Chain saw. poulan super 1800 16" . Chain or bar problems?Chain rotates for a few seconds, then stops.Appreciate any answers as I have cleaned, adjusted everything I can think of that might cause this. Love the saw and really want to get it running again. Thanks, Rick
  • 1 more comment
  • dortfran Nov 14, 2008
    Thanks Dennis,I appreciate the tip for future use, but, this was a new chain was put on when the problem came up. Thanks again. Dortfran
  • ryan7585 Nov 15, 2008
    I have the same problem! new chain, new bar and everything. Do I need a new sprocket?
  • Anonymous Mar 16, 2014
    my poulan electric chain saws oiler has stopped working
    Sniper:
  • 52 Answers
Hi dortfran,
My name is Dennis and I hope to be of assistance.
This sounds like a kink in the chain and I would try a new chain because this can be a very small kink and very difficult to find and straighten out. If you must put the chain saw in a vise by clamping the bar and run the chain back and forth from the sprocket to the bar grove under operating tension and locate the misalignment at the bargrove. Now you have located the problem but the fix is still sweat away, and with some luck you may be able to spring the chain straight and have the link flexable to opporate without a hitch.
Glad to be of assistance. Please rate the solution because i can learn from your rating.
Thank you
Dennis
Posted on Nov 09, 2008
Chainsaw rattles when it stops
personally too much hassle prefer Stihl Chainsaw more reliable Seizing is caused by lack of lubrication, First check all level has oil pump seized or is it sump type when running oil circulates all way round, Still there has to be a oil reservoir if this is bone dry theres your problem the rattling is metal on metal with no protection and the damage is seizing caused by lack of oil I have two chainsaws both have oil sumps and are kept full, please check hope this helps
Feb 15, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
Poulan 2150 chain saw starts after priming and dies after a few seconds
Take the exhaust off so you can see the side of the piston, if it is scored or damaged it means it has probably been run without oil added to the petrol.
That can cause the problems you are having, if it is throw it away, its not worth repairing
Dec 14, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
Cant find sproket number 76695
Super Deluxe ? Do you mean a Poulan chain saw. Check here they handle all brands of chain saw parts.
By the way Poulan is owned by Husquvana, which is owned by Electrolux.
sales@mfgsupply.com
Feb 04, 2010 | Garden
Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Where do I find a replacement chain for my McCulloch Eager ****** 2318av chain saw (model # 600038-12)?
Your friendly neighborhood chainsaw shop can fabricate one in about 5 minutes. Take your existing chain for use as pattern.
McCulloch.com
http://www.ordertree.com/modelinfo/MCC/11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318/139.11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318.1.59.1.html
If original 18" bar.
part number(pn) MCC 21927533
Oregon Bar & Chain Selector (again original 18" bar)
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Your saw with 18" bar returns
Oregon pn 91VG060G.
This can be easily crossed to other manufacturers chain. You might consider a more aggressive chain (dependent on your level of expertise). HTH
Lou
Jan 20, 2010 | McCulloch Garden
I have a Poulan Pro PP3516AVX chain saw. I used it
Their not the best saws but make sure the nuts holding the bar and cover on are tight after adjusting chain sometimes improper cutting will continue to kick chain off bar.
Mar 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Runs bad like no fuel
well assuming this is your model:
getimage.php?m=pp4620avx&s=s&t=chainsaw
--> poulanpro.jpg&s=hs
Chain Saw PP4620AVX 952802146
  • 46cc 2-Cycle Gas Chain Saw
  • 20" steel bar
  • Anti-Vibe Handle
  • Automatic Chain Oiler
  • Super clean air filter system
  • Tool-less Chain Tightening System
  • 2 Year Warranty
I would go to Poulan Directly and Voice your Complaint with them, they might make it right with You...
You can Contact them at:
Handheld (Chainsaws, Trimmers, Blowers, Edgers)
1.800.554.6723
or Via email/request form:
http://www.poulan.com/poulanpro/contactUs.do
Good Luck!
Dec 13, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
708 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
