Question about HP Computers & Internet
Monitor gives recomended settings then puts itself in sleep mode.I cant even get the computer to go into safe mode.
    Genius:
  • 1,124 Answers
Your computer is in hibernate mode.
Start up your computer and do this
Start >> Control Panel >> Power Options
Select the tab "Hiberbate" >> Uncheck hibernate mode
Also you can adjust there your power setting and monitor settings
Posted on Nov 05, 2008
My Dell monitor goes to sleep right after windows xp starts to load and it won't come on after that. my computer is still running but the monitor is a sleep. I have hit f8 and f12 with nothing happening....
Go into safe mode
Under settings, control panel, power options set "turn off monitor to never
reboot
I think this is not a sleep problem but the incorrect monitor settings were set. This will cause the screen to go black when the OS comes up. Boot in safe mode and change the display settings
to 640x480
OR
in safe mode, delete your monitor. When you reboot it will load a default monitor and you should be OK
Oct 13, 2010 | Dell XPS 410 PC Desktop
Monitor going to sleep upon Bootup.
Open your cpu cabinet.
refix your RAM memory .
Pull cmos cell for 10 minutes so all settigns are defaults.
Also remove PCI cards from PCI slot .
Then check.
Let me know if you need more assistanse.
thanks.
Aug 31, 2009 | HP w1907 LCD Monitor
5 sec after starting windows the monitor goes to sleep itself.
go to safe mode.. change the power settings for windows...
to go to safemode.. simply restart your computer.. then press f8 several times til you see the boot menu.,.. select safe mode.. from there.. you should be able to boot windows.. change the power settings in control panel
Jul 09, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
When the computer is turned on the monitor goes to sleep mode
Go to safe mode,select boot in vga mode.
If this allows you to start,
Click start,Run type desk.cpl
Screen Saver tab | click on Energy
Under desk or office settings frame, set all values to "never".
Then click
Advanced Options, you'll see a frame asking you what to do.
Just select the options to turn off sleep mode.
check that out.
If you can't start this way,you need to try another monitor to change the setting above.
Please rate this a fixya
Feb 14, 2009 | Computers & Internet
Wont work with new computer
Since this was a new out of the box computer, Safe Mode was not allowed. In order to change monitor settings (resolution), I had to use another monitor, in this case a newer CRT. With the CRT, the computer booted up, no problem. Once booted, I turned down the monitor resolution and saved. Now when the Princeton LCD was plugged in and the computer restarted, everything works fine. Now the resolution could be set to limits of the monitor.
Aug 19, 2008 | Princeton Digital VL173 Monitor
Unknown mode
Check the instructions for the default resolution for your monitor. Start your computer in the safe mode. In the safe mode, the resolution should come up at the minimum. Now go in to the screen properties and set the resolution recomended for your monitor.
When you start the computer normaly, it should now come up in the last setting that you put it in to while you were in the safe mode.
Jerry G.
Jun 03, 2008 | GoVideo TW1730 17 in. HD-Ready LCD...
SVA Monitor stuck in Analog Mode or Sleep Mode
Actually it was quite easy. I rebooted my computer in "safe mode" by restarting it and pressing the F8 key. At the start up windows gives you an option to toggle down to "enable VGA mode" and select it. After that, my computer recognized my monitor and it has worked fine ever since!
Mar 09, 2008 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Computers & Internet Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
