Question about Quartet gbc 3260X Shredder
3260x Wire connection
I took the top off and 3 of my wires got disconnected. I see where the go on U V W and have a Black Blue & Tan connector. Don't know which way the are connected. Any help?
  • Anonymous Dec 22, 2008
    exact same problem anyone know where youc an get a repair manual?
3 Suggested Answers
aviral_srms
  • 1216 Answers
SOURCE: i need a wiring diagram for a gbc 5260x. I made
gbc 5260x wiring diagram
Posted on Jul 20, 2011
  • 1833 Answers
As you need wiring diagram for a GBC 5260x, please follow "http://www.gbcconnect.com/assets/docs/5220S_5230S_5260X_PARTS_SHREDDER.pdf".
Here you find the exploded View of GBC 5260x.
Hope this will help you. Good Luck.
Posted on Jul 21, 2011
Black wire, white wire, and tan wire coming from ceiling. New fan has blue, black, white wire and green wire on the bracket how does it hook up
1. Have on hand either wire connectors or electrical tape
2. Look at the wires coming from your ceiling fan. The black wire from the ceiling fan is the hot wire that runs the motor and turns the fan blades. The white wire is neutral and completes the fan circuit. The blue wire is the hot wire for the ceiling fan light fixture. The ceiling fan motor does not have a ground wire.
3. Find the short green wire or the green ground screw on your ceiling fan hanging bracket. Attach the bare copper wire from your electrical box to the short green wire by twisting and orange wire connector to the two wires. If you only have a green ground screw, wrap the bare copper wire around this screw and tighten the screw against the bracket to secure the wire.
4. Match the end of the white insulated wire from the ceiling fan to the end of the white wire from your electrical box. Twist a wire connector onto the two wires to complete the neutral circuit.
5. Connect the black insulated wire from the ceiling fan to the black insulated wire from the electrical box. If you do not have a separate toggle switch on the wall to operate the ceiling fan and light separately, grab the blue wire and place it with the black wire from the fan motor and the black insulated wire from the electrical box. Twist a wire connector to all three wires. If you have the additional toggle switch, connect the two black wires together with an orange wire connector, and then match the blue wire and the red wire together. Twist another orange wire connector on the red and blue wires
Nov 11, 2017 | Dryers
I have 3 black, 1 tan, 1 gray wireing from ceiling. I have a wall switch that controls 2 ceiling fans in a mobile home . i want to connect a new ceiling fan that has 1 black, 1 white, 1 blue wireing.
The gray tan and the other wires usually have plug on the end and the plug into the fan unit when it's put together . The part the mounts to the ceiling should be blue black and white
Aug 28, 2014 | Cars & Trucks
On the 1995 tahoe the female plugin is three wires two orange and one black when pluged into the power seat plugin that is 4 wires to the seat swich the sear switch turns into a 6 wire to the 3 motors the...
The switch reverses polarity depending on which way you want the seat to move. The dark blue with tan wire and the tan wire are the two wires that control the seat forward and rearward motor. With the switch in the forwar position there should be power on the tan wire and ground on the dark blue with tan wire. With the switch in the rearward position it will be just the opposite. There will be power on the dark blue with tan wire N the tan wire will now be ground. This is the same for the other two motors. The rear tilt wil be the dark blue and dark green wires. The front tilt will be the yellow and light blue wire.
Sep 08, 2013 | Cars & Trucks
Want to attach a harbor breeze light kit to an existing hunter fan. switch housing has 3 white wires hooked together with a blue connector cap and a single black and white wire(labeled for light). there...
White to white ( single white ) & blue from light kit to Black with white stripe. Also make sure the black with white stripe coming out of TOP of fan is connected to the hot wire.
Aug 26, 2013 | Hunter 52" Ceiling Fan With Light And...
I am having trouble setting the timing on a 262(4.3l)chevy vortec engine 1995
You have to put the Ignition Control (IC) system in the bypass mode by disconnecting the "set timing" connector. This is a single wire sealed connector that has a tan with black striped lead. The location of the "set timing" connector with a Powertrain Control Module (PCM) controller is near the PCM connectors in the passenger compartment. Unplug connector (tan/black stripe) start engine set timing to 0 TDC, TURN OFF ENGINE, re-connect timing connector
Firing Order 1 - 6 - 5 - 4 - 3 - 2
Drivers side: 1 - 3 - 5
Passenger's side 2 - 4 - 6
Feb 09, 2010 | 1995 Chevrolet S-10 CA Edition
Where can i get the specs for ignition timing on a 1989 GMC K1500 Pickup
Note: The Timing Connector breaks out of the engine wiring harness conduit adjacent to the distributer. It is a single wire sealed connector that has a tan with black stripe lead.
Note: Timing specifications are listed on the Vehicle Emissions Control Information label under the hood. Always follow the Vehicle Emissions Control Information label procedures first before using the following procedure. PROCEDURE:
Set timing under the following conditions:
  • Normal operating temperature.
  • Air cleaner installed.
  • A/C "OFF".
  • Transmission in neutral.
  • Disconnect SET TIMING connector (tan/black wire) located in the harness close to the distributor. DO NOT disconnect the 4 wire connector at the distributor.
  • Connect timing light and adjust as necessary by loosening hold down bolt and rotating distributor.
Base Timing, with Manual and Automatic Transmissions: 00(TDC)
  • Tighten hold down and recheck the timing.
  • Stop the engine and connect SET TIMING connector.
  • Clear ECM trouble code by disconnecting ECM power source.
Nov 24, 2009 | 1989 GMC K1500
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
1989 plymouth horizon check engine light on
Code 34 is set when the computer does not detect a voltage to and through the speed control servo. The cruise control computer is built into the PCM, which grounds two windings in the servo mechanism to regulate the vacuum applied to the servo diaphragm.
Note: All Chrysler corporation fuel-injected engines have the computer circuitry and software for the cruise control system installed, even if there is no cruise control installed on the vehicle. If there is no cruise control installed on the care or truck, the computer will interpret this as an open winding and set code 34.
First: turn the key ON, turn the cruise switch ON, and look for +12 Volts on the dark blue/red wire that connects to the servo mechanism. This circuit is fed:
  • from the ignition switch through to 10 (dark blue wire)
  • from fuse 10 to the steering column (white/red wire)
  • through the clock spring to the cruise control ON/OFF switch on the steering wheel (white/red wire)
  • back through the clockspring to joint connect "C" (yellow/red wire)
  • to the brake lamp switch under the dashboard (yellow/red wire)
  • through the firewall from the brake switch (dark blue/red wire)
  • to the servo (dark blue/red wire) A break anywhere in this path (broken wire, bad brake switch, loose connector, etc.) will interrupt the 12 volt supply to the servo and set a fault code. Work backwards until you locate the break.
Turn the key OFF. Unplug the the connector from the servo and measure the servo coil resistances.
  • measure the resistance between the servo pin that connects to the tan/red wire and the servo pin that connects to the dark blue/red wire.
  • measure the resistance between the servo pin that connects to the light green/red wire and the servo pin that connects to the dark blue/red wire. The resistance in both cases should be above 0 ohms and less than infinity.
Disconnect the battery(s). Unplug the 60 pin connector from the PCM and check for continuity between the pcm connector and the servo connector for the tan/red wire (cavity 33) and the light green/red wire (cavity 53).
If no wiring problems are found, check the PCM connectors for corrosion, and reconnect. Reconnect the battery and test the circuit again. If the problem still exists, the PCM is probably bad. NOTE: Personally, if the truck was out of warranty I would try to find for a used servo before buying a new PCM.
Oct 16, 2008 | 1990 Plymouth Horizon
Quartet gbc 3260X Shredder Logo
49 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
