Ricoh 1232c Error SC571
I did get to clean the fusing unit and the overflow sensor, but the error SC571 is still coming back. Can some one tell me how to reset the unit
I read in a other web page "Reset the SC (set SP5-810 to 1) then turn the main switch off then on again"
I don't know what's that mean can you explain that to me how to do it.
Thanks
  • psda7 Nov 05, 2008
    Now I understand how it works. How do I do the Fusing reset (SP 5-810-1)
    witch buttons to press on the pad on the display screen.
    Thanks
  • 2,794 Answers
SP 1-930-1 Forces the oil pump to supply silicone oil up from the oil
tank to the tank in the oil supply unit. If the oil end
sensor detects oil in the oil supply unit, this SP will not start the pump.
SP 1-970-1 is an oil removal process mode for the transfer belt.
SP 5-810-1 is a fusing reset but if the sensor isn't working properly, the code could pop up right away.
Posted on Nov 05, 2008
Ricoh aficio service code sc571
solution found on copytechnet.com
sc571 on this machine means fuser oil overflow.
check the oil out sensor connector.
use sp5 810 to reset this and most other codes.
Apr 02, 2011 | Office Equipment & Supplies
Comment enlever message sc 570 sur ricoh 1232c
This error code is related to a Insufficient oil.
The fusing oil tank is in the rear of the machine.
You have to call Ricoh to supply the oil.
See you
Mar 29, 2011 | Ricoh Aficio 1232C Color Copier
ERROR SC 570 RICOH AFICIO 1232C HOW CAN I FIX
The machine has no fuser oil.
Fill the little tank at the back side of the machine. If the tank is full, check the tubes, oil pump, and oil sensor.
Reboot the machine to clear the SC.
The problem will be solved
Aug 10, 2010 | Ricoh Aficio 1232C Color Copier
Error codes SC548 ricoh mpc3500, how can you solve?
The error means - Fusing unit rotation error.
Check if the fusing unit(right door{hot unit}) ,if it is rotating properly.
There could also be a sensor on the frame or the machine which senses the fusing unit rotation,(the sensor sometimes comes off)(remove the fusing unit and check where the fusing unit is seated).
Also try cleaning the sensor with a blower or brush.
Feb 13, 2010 | Ricoh Office Equipment & Supplies
Machine showing sc 571
Check the fusing oil unit most likeley something wrong with that. if its new check to see that all the wrappings have been completely removed. ~~> Defective oil end sensor, Defective oil overflow sensor, Defective sensor cable, Oil supply unit not installed
Dec 16, 2009 | Ricoh Aficio 1232C Color Copier
Error code sc481 for ricoh copier 1232c
This is a "Transfer belt mark detection error" This means the transfer-belt in the PCU is torn or separated where it has a mark that flags a sensor telling the machine where the belt position is, The fix is to replace the entire PCU. 4 Screws that have arrows pointing to them surround the unit facing you when you open the front door will release the unit allowing you to insert a new unit and the code should go away ,, good luck!
Apr 30, 2009 | Ricoh Aficio CL3500N Laser Printer
How to clear error code SC571 on Ricoh 1232c copier
See thread I left you this morning on this. I hope it helps.
Press the yellow button. Press the 107 keys. Press and hold the red clear button for a few seconds until the service mode screen appears on the LCD display.
Oct 30, 2008 | Office Equipment & Supplies
Ricoh Aficio 1232c copier error code SC571
Enter SP 5-810 and set to 1, then switch off and on the machine.
Problem with copier Rex Rotary DSc232
571 A Fusing oil overflow
• The oil overflow sensor detects oil.
• When the machine covers are
closed, the oil supply unit is not
detected.
closed, the fusing unit is not
detected.
Possible causes :
• Defective oil end sensor
• Defective oil overflow sensor
• Defective sensor cable
• Oil supply unit not installed
Jul 08, 2008 | Office Equipment & Supplies
1,447 people viewed this question
k24674
