Question about Samsung Televison & Video
HLR5667 Samsung TV reverts to standby mode. Thereafter, TV does not respond to remote.
    Novelist:
    Champion:
  • 203 Answers
Replaced power supply board to fix that problem in the past and never heard back from customers. Must have worked. Good luck, Russmann.
Posted on Nov 05, 2008
Why does the lg crt tv model 21fs9rg am working on keep reverting to stand by after i have switched it on?
Could be a bad remote. turn the TV on and then take the batteries out of the remote to see if it shuts off. If not, you know that the remote is bad or the batteries are low. I would suspect the power supply next.
Jun 11, 2016 | LG Televison & Video
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
My Technika LCD32-229 is just over 12 months old and has suddenly decided not to respond to the remote or on/off control on the TV. If I turn of the power at the mains for 30 seconds or so, it will then...
HERE'S THE ANSWER TO YOUR PROBLEM:
The possible reason why your TV doesn't respond to your remote is probably the battery of your remote. Maybe it has been used up to it's fullest capacity, so try checking it up. In case, it has been used up, try to buy a new one.
The possible reason why your TV doesn't stay on is still your remote control. Maybe you have accidentally set it to "sleep mode." When it is set into sleep mode, it turns on just for a shorter time. It cannot stay on longer.
So, here's what you've got to do. Check your remote. When the remote works already, press the sleep button remote again. I hope it works for you.
Thanks.
Jul 23, 2011 | Televison & Video
I bought a used samsung tv model lnr32r5hdx/xaa and it didn't come with a remote, the controls on the tv do not respond except the power button. I have been reading about some shop mode and I have has...
Changing modes and resetting on tv internal video setting must resquire the tv original tv remote Try website like Remotes.com to buy the tv original remote.
Jul 03, 2011 | Samsung Televison & Video
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Oct 03, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Stuck on standby
Neovia Neo-3775: Standby Led permanently on amber when powered up with no screen or sound. Does not respond to remote or to TV controls.My problem is same as Ed's posted in 2009 - any ideas?
Jun 22, 2009 | Philips TP2785C 27" TV
Picture Mode reverts always to Dynamic after several minutes
The set was a store demo, and the options were set so they could not be adjusted. On instruction from Samsung I pressed MENU and VOLUME buttons on the side of the set and hold for 7 seconds The display reverts to Standard from Dynamic. The Remote Options button showed Store Demo, but now shows Standard. All memory functions seem to function now. Thanks for your help.
Watty2c
Jan 17, 2009 | Samsung LN32A330 32 in. LCD TV
Televison & Video Logo
61 people viewed this question
Jerry Greenberg
Jerry Greenberg
