Question about Infinity Reference 1211a Car Audio Amplifier
Protect light flashing/ticking
I had my Infinity 1211a mono amp hooked up to my 2.1 fared cap and 2 Infinity 12" subs and the amp worked for about a week untill it gave out and the protect light started flashing off and on and making a ticking noise while flashing unrhythmically... I left it all hooked up and occasionally the subs would kick on for a couple seconds right when my vehicle was started up but would die after that. Now the subs don't even kick on at all - not even for a couple seconds - but the protect light continues to flash. HELP PLEASE!!
  • 4 more comments
  • Anonymous Nov 05, 2007
    i have a 1868 legacy amp which everytime i turn it on i get a few seconds of sound before my protection lights cut on blocking everything
  • peyote 69 Apr 14, 2008
    i have an older jbl gtq 400 amp had a ground wire into the ground but the power light kept flashing on and off no sound another amp worked fine does this amp itself also have to be grounded to metal write me back jwalker19733@yahoo.com thanks
  • Anonymous May 04, 2008
    same problem but I have the 1210a
  • Anonymous May 22, 2008
    yes I had the same problem then the amp fried so if I could all you guys that is haveing this problem with the directed 2400d unhool the ampo or you are going to fry it
  • flypaper69 Jul 07, 2008
    so, im haveing the same problem when i turn my car on with the sub attached to the amp the protect light flashes and sub rumbles, if i disconnect the subs, the light comes off, my subs are wired corectly to check i tested on two sets.
  • Brazilx2k Feb 16, 2009
    Mine protect light is always on and the power light is flashing like aver 2 secs and subs bumps also could it be the fuse on the battery cable? mine is 500watts amp but i dont need much power..
Check your capacitor carefully(and connections),check your 30A fuses,u should have 4 guage wiring,if not that, pull your subs out the box, check the terminal wiring because they like to burn up before the voice coils.The coating will burn and crumble then the Small copper wire will burn up.
Posted on Aug 09, 2008
Transistors blown, change it
Posted on May 24, 2007
I had a similar problem happen to my friends car...he had a visonik amplifier with 2 12" infinity....he had the same ticking noise and the prtect light flashing on and off....i first of all changed all the fuses...then checked the subs...and they were both blown...the ticking stopped when i unhooked the subs...try that and find out if they are blown...hope this helps...
Posted on Feb 27, 2007
    Scholar:
  • 98 Answers
Yes make sure your powers and grounds are all ok. If you have round glass fuse in the power wire replace it even it it looks good. Ive seen those fuses melt the solder internally so they will be "blown" but look as if they ar eperfect.... if that does not help your amp needs repaired. go to my website at http://home.comcast.net/bigmikeselectronic/repair for more info. I may be able to repair it fo ryou or buy it form you as-is...
Posted on Nov 27, 2006
  • Mike Ryan
    Mike Ryan Sep 08, 2007
    hey heres some other things i should mention...
    Your ground wire and connection to the car body is just as important if not more important thasn the power wire!!! The ground wire should idealy be bolted somethere metal with a nice strong bolt. Use sandpaper or some other method to get the metal where the wire will bolt CLEAN BARE METAL!! SOme people dont realize that they use cheap krap wire. You cane use walmart 8 gauge wire to run a big stereo!!! I reccomend 4 gauge or larger quality wire, quality fuse holders,etc. I reccomend using either a circuit breaker or large blade type fuse for the power wire as the round glass fuses tend to melt internally so thry will look great but not conduct electricity at all..
    also one last thing DO NOT mount your amp on your speaker box. Not only does it make a thieves job easier, the vibration is VERY BAD for the sensitive components that are inside your amp...
  • Mike Ryan
    NO this amp was fine!!!! he had a problem with the power fuse... the solder in the ends of the fuse melted... it looked fine, but would barely conduct power causing ther amp to come on then abruptly cut off...I always reccomend large power wire and either a circuit breaker or blade type fuse for this exact reason..
    Yes most of the time when i amp goes into protect its either some shorted subs or just a fried amp but in this case the fuse fixed it.
    Problem Solver:
  • 18 Answers
This problem sound like you have too low of power going to your amp, test your battery and make sure its putting out enough power for at least the mininum amount of power that your amp requires, you can find that information in your manual or sometimes they post it on the amp itself. i hope this info helps
Posted on Oct 09, 2006
Just hooked up mtx 500d mono amp and 12 inch sub worked for a 1/2 hour then sub quite and led on top of amp just flashes.
either ur ohm load is way off ur pos n neg might be touchin or more than likely u blew u sub is it scratchy when u push in the middle of the cone ? does it push in at all?
May 14, 2010 | Car Audio & Video
I hooked up my two 10 inch JL Audio W3v2 2 ohms to a mono JL Audio 500.1 amp and the subs will not work. I have the subs wired in a series. I then hooked them up to my friends amp and the subs worked. Any...
try one at a time. if they work then try hooking them up differently. if none work, then check to see that your amp is not in protect mode. if amp is ok, then check to make sure you have your rcas connected to your amp. in other words, re-check all your wiring. if still nothing, try your amp on your friends car and vise versa.
Apr 01, 2010 | Jl Audio 10W3v2 Car Subwoofer
Your amp went in to power protect. You must adjust the settings on amp. This is usually very time consuming to get it right. Good Luck
Mar 24, 2010 | Car Audio & Video
Infinity 1211a @ 2 Ohms
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Jun 03, 2009 | Infinity Reference 1211a Car Audio...
I have a rockford fosgate p250.2 amp hooked up to two 12' subs but the amp is not powering on... instead the protect light is on and im not sure if its because its so cold outside... please help and thank...
Remove the load from the amplifier (subs) and the RCAs
Retry.
If the light stays on, there are internal problems with the amplifier, and it needs to be serviced.
If the amplifier works normally, attach the RCA's and power on again.
If it remains on, connect one sub, and then the other.
Your amplifier is a 2 channel amplifier rated at
60 Watt - 4 Ohm - 2 channel(s)
125 Watt - 2 Ohm - 2 channel(s)
250 Watt - 4 Ohm - 1 channel(s)
Your amplifier is not rated for a 2 ohm mono load.
If you have Single voicecoil subs wired in parallel, you have a 2 ohm mono load - your amplifier will eventually fail.
Jan 16, 2009 | Rockford Fosgate Punch P2502 Car Audio...
1211a amplifier
if your amp. work in bridge you can attach + 1st channel and + 2st channel to your sub woofer. by series 2 ohm you have 4 ohm sub woofer.
Sep 26, 2008 | Infinity Reference 1211a Car Audio...
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Trying to wire my amp to my subs
no thats not it you are lucky you havent burned it up like that. wire each speaker to its own source positive and negative, you loose power when you bridge an amp and use two speakers, its best to hook up without bridging you will get more volume that way.
Dec 18, 2007 | Infinity Reference 1211a Car Audio...
Problems with Infinity Amp 611A
are you running a large ground wire directly to the battery negative terminal?
Jun 03, 2007 | Infinity Reference 611a Car Audio...
Infinity Reference 1211a Car Audio Amplifier Logo
1,149 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Richard Lukszys
Richard Lukszys
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
