Question about GoVideo Televison & Video
Whenever I play a dvd a second time, it starts from where it left off ast time, and I have to rewind the dvd manually each time? How can it always start at the beginning of the dvd, each time I go to view it again?
  • 417 Answers
What you are describing is 'Last Scene Memory' function which is a feature of most DVD players. The player will not memorise the last scene if you switch of the player before playing the disc. This should Fixya!
Please remember to rate this solution.
Posted on Nov 05, 2008
I have a Suzuki SX4 and I have mistaken entering the lock code although I have the right one. Now radio is locked up. How can I make it work again with the right code?
wow no year?
the operators guide , this info is missing , and so is suzuki here.
some had the 6380 radie others 6400 in 2007
but ...
is it the ? Blaupunkt
Press BND/AST button about 3 seconds, three minus sign appear on the display. Use button 1 to set the 1st digit of the code, every time you press '1' the digit grows, then use '2' to insert the 2nd digit, and so on . After inserting all the digits, press again BND/AST 3 seconds to confirm the code and, if it' s the right, the radio is unlocked. The number on the left of the four '----' is the counter of times you made to enter the code.
2008 answer again 4 radios offered including XM sat.
Oper.guide. pages.
page 4.55 (see link and end for free lost guide)
http://newsbee.org/downloads/SX4_Owners_Manual.pdf
2008 verbatim
25829261-pfeiunw0a1xd3dwxxti5xtj3-2-1.jpg or pay 4 bucks and replace your lost oper guide?
https://suzukipitstopplus.com/Category/3-suzuki-service-manuals.aspx
Aug 19, 2015 | Suzuki Cars & Trucks
Video cassette player/recorder LGRC 689D wont rewind properly
The problem is in the idler assembly inside the machine, some use rubber that dry out and crack, or there is a spring loaded double clutch wheels that get weak over time. In order to fix this the idler assembly must be replaced.
May 04, 2012 | Televison & Video
I have a LG DVD 276. When I play a CD it always starts were I stopped last time. How do I get it to start ast the begining?
push the stop button then remove the cd, power off the player and then power it on again then press the eject button and insert the cd it will now start to the main selection.you can now select the play that what you need to select.
Oct 29, 2011 | LG DV276 Recorder
Dear Sirs, Recently, my Sharp dvd-video combi player has been encountering some problems regarding the playing of dvd's. When I watch a movie, in several occasions the movie will freeze up. And for...
the DVD unit in your sharp is a self contained unit. IT is only repaired by replacing the DVD as a assembly. the cost of replacing may exceed the cost of purchasing a new one.
The most likely cause of your problem is in the brass gear assy that runs the optical pick up in the traverse deck. IT is not an available part.
Feb 17, 2011 | Televison & Video
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
ERROR CODES E24 ~& E4 54037380 ON MY DVD RECORDER, CAN ANYONE TELL ME WHAT THESE MEAN, THANKS
If you are trying to record vhs tapes to the dvr side, first you need to get 1x up to 8x DVD-R dvds. You can find them on ebay. The machine has problems recognizing the up to 16x type. Put the blank DVD in and let it load. Then start playing (not dubbing but playing) the videotape for at least 6-8 seconds. If you have somewhat of a lead-in on the videotape you can let it go even 10 seconds. Only after the videotape has been playing for this period of time, press the dubbing button. If the error code does come up, rewind the tape and start again, but in most cases the error code will not happen if you do it like this.
Mar 31, 2008 | Sylvania SRD3900 DVD Player/VCR
VCR won't rewind
Soution #1 get nice but cheep VHS " rewind " macine.
2nd. Some machines have a special rubber wheel in the center,between the left [ take up or rewind ] & right [ play\record ] assemble. VERY diffiult to repair if u don't know what u are doing.
3rd. Find & REplace EVERY rubber band that u find in the machine.
Oct 18, 2007 | Sansui VHF6010 VHS VCR
Durabrand PVD709
You have a bad tact switch behind the front panel rewind button.
Sep 18, 2007 | Sony DVP-NS575P DVD Player
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Televison & Video Logo
99 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
