Question about Bernina Virtuosa 160
L board Two months ago I had my Bernina cleaned & the bobbin case replaced. Parts & labor cost $170. About a week ago, I began having problems. The foot pedal, when pressed down hard, stops the machine & then restarts. My husband thought there was a problem with the pedal itself. The repairman say he thinks it's the L board. He's not sure of the cost. He says somewhere between $150 - $300 with parts & labor. I'm upset. I am considering telling him to forget it & look for another machine. Is this a common problem with Berninas? Should it be this expensive? Should I cut my losses & get another machine? I'm afraid that after this, something else will go wrong.
  • 202 Answers
This could be a problem with the small circuit board inside your foot control or maybe the micro-switch bad or the micro-switch leverlinside is slightly bent or off. Possibly just the carbon contacts inside the footcontrol or built up carbon on the contacts. First take it to a dealer and try a differant (new footcontrol). Does it work now? If so it was a footcontrol problem. Circuitboard, micro-switch or carbon contacts. If a good foot control does not work, there is a checklist of service programs (tests) for the tech to run through and should have done before. There could be a bad wire, or pinched wire inside to look for. A good tech would an ohmeter first to find wire problems. Or possibly it doesn't have the latest software version in it and it needs to be installed. A speed calibration may cure this also. To be honest I'm leaning towards your husbands intuition and its the foot control. Try a differant one, like the tech should have. Then if none of the above works an L-print would be in order but maybe somewhere else. Good luck. Its still a good machine.
Posted on Aug 28, 2007
    Novelist:
    Scholar:
  • 84 Answers
Hi Tonette....I'm afraid that it is impossible for me to diagnose your current issue over the internet with any degree of confidence. However, I can educate you on typical norms for your specific situation and machine. Typical "tune-ups", also advertised as "clean, oil & adjust", range from $19.95 to $49.95. Of course, the 19.95 special is designed to get you in the door. Bernina Bobbin Cases do generally run on the 'higher' side of things, between 30 & 60 dollars. However, regardless of what Class any given Bernina is in, the electronic components all originate from the same manufacturers with similar benchmarks regardless of class. Replacement of any given electronic component, once accessed, is as simple as plug and play, with no adjustment or fine tuning required. As far as cutting your losses, in my opinion, you had already lost when you paid the 170.00
Posted on Aug 04, 2007
SOURCE:
I have a Bernina 770QE. The bobbin (black) is stuck in the bobbin casing (chrome). How do I get it to release?
Take the bobbin assembly loose and turn your hand crank and move it until the hook is at the top. Pull assembly apart and clean the assembly with qtip and sewing machine oil. It will likely be dirty that is causing parts to stick. If the bobbin spring feels weak it may be a good idea to replace it.
Aug 06, 2017 | Bernina Sewing Machines
The bobbin thread on my project is bunching when I embroider with my Bernina 880. Any suggestions? I have cleaned the area (machine was just serviced four weeks ago),
Since you just had it serviced, you may want to contact the technician to ask your question. Perhaps something was missed during service or there is a simple answer.
Oct 03, 2016 | Bernina Sewing Machines
How to tighten tension on a Bernina artista 170
Rotate screw on side of bobbin case clockwise
Sep 02, 2014 | Bernina Artista 170
Turned machine on, started to sew(about 4"), machine beeped, screen started flashing off & on, then it went off. Will not restart. Tried a new cord and that wasn't the problem
Look at your seam. If you have a bunch of balled up thread underneath the seam, part of the problem is operator error. Always always grasp the thread end while beginning the seam. I suspect that the thread gut bunched up under the material and caught up in the bobbin/shuttle area.
Remove the fabric, unplug the machine... get into the bobbin area, remove the bobbin, and if necessary clean threads caught up in the bobbin race/shuttle. reassemble and replace the bobbin... turn on the machine. Try again.
Nov 01, 2013 | Bernina Artista 170
I have a faithful 730 Bernina and currently the bobbin thread keeps breaking. Please advise what may be causing this. Thanking you.
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
here's a free manual
http://www.bernina.com/getdoc/48e8d09f-98f7-40ab-8663-a23663df4fae/Bernette_715_730_740E_manual
Sep 17, 2012 | Bernina Sewing Machines
Bobbin case needs fixing or replacing
Bobbin cases are readily available and should be replaced anyway after a fair bit of use, but just check that you've got reasonable thread tension on the old one before you junk it - it should be adjusted with a proper set of weights and the correct thread but you can usually get it about right by carefully adjusting the tension screw on the side that operates on the spring.
Jan 29, 2012 | Bernina Artista 170
My mother has a bernina 1008 and now that we have taken the bobbin casing out to clean it won't catch when threaded. Any ideas?
Are you threading the bobbin case correctly - the bobbin should rotate clockwise when pulling the thread out under the tension spring. Are you ensuring that the bobbin case is firmly clicked back into position when replacing it. Check your needle is OK. Did you remove the hook from the hook race when cleaning out - have you oiled the hook race ?
Jan 22, 2012 | Bernina Sewing Machines
How do you oil a Bernina 170?
Remove needle, needleplate, presser foot and bobbin case. Now take a lint brush and clean under the feed dogs and hook area. take the bernina oiler(must be bernina oil only) now place a drop just below where the bobbin case clip on and one small drop under the feed dog area. replace items, sew out a test sample and away you go
Apr 25, 2010 | Bernina Artista 170
Problem with bobbin thread!
Take out the bobbin race thing (behind the bobbin case) clean the area up. Oil the race, just a drop. Check the bobbin case for thread under the tiny spring (use tweezers if you see any). Make sure it's a good bobbin and that it unwinds clockwise. Up top, check your thread path and make sure you thread while presser foot is UP. Spool should also reel off clockwise. It's gotta be something like that. I have several of these machines (old Berninas, that is!) and there's almost never a problem.
Jan 30, 2009 | Bernina 1008
Bernina 180 - winding thread onto bobbin spool
If the bobbin winder spindle turns freely by hand and the macine runs fine with the foot controller then it may be the small motor that runs the bobbin winder that is at fault. If this is the case then your local service tech should be able to relace it. It is not a very costly part so don't be to worried.
Nov 02, 2008 | Bernina Artista 180
Sewing Machines Logo
273 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
